Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-27-2006, 10:38 PM   #1
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Default Can Ecutek remove TGV CEL after sensor removal?
I would like to totaly remove the TGV system and not have to use the aps adaptor kit. But I never heard a firm response if a reflash can eliminate these engine codes.
thanks
Luke
lukeskywrx is offline   Reply With Quote
Old 06-28-2006, 02:06 PM   #2
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
thanks
Luke
We have tested the standard method EcuTeK has given with no success. Currently on 02-05 WRX's we have not seen it work properly yet. EcuTeK has offered a new version of the TGV removal in the software which we are trying out.
Cheers,
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 06-29-2006, 12:01 PM   #3
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
The ECUtek flash I have from PDX removed the TGV code....at least I'm guessing it did because I don't have TGV's and I don't have a check engine light.
SloRice is offline   Reply With Quote
Old 06-29-2006, 12:20 PM   #4
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
That is probably because you have an USDM STi ECU which is much different from the 02-05 WRX ECU's. In conjunction with the EcuTeK software being different between the USDM STi's and 02-05 WRX's this changes how the TGV deletion works on the STi's and WRX's.
We have begun testing on the TGV removal with EcuTeK on the early USDM WRX's TGV CEL code removal (02-03 WRX's). So far it is moving in the right direction but we need to do some further testing to make sure it will work in most any situation.
Cheers,
CEL after AC removal? (P0186) twizzstyle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-24-2009 04:10 PM
Uppipe EGT sensor removal. CEL fix? Gro Harlem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-21-2009 01:53 PM
Anyone know where I can find a o2 sensor removal tool? sportz135 New England Impreza Club Forum -- NESIC 13 10-24-2005 11:43 AM
Can Ecutek remove tumbler delete CEL ? ronf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-17-2005 02:26 PM
After Silencer Removal/Filter upgrade, CEL? FiSHxBFG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-12-2001 11:16 PM
