Welcome to the North American Subaru Impreza Owners Club Wednesday August 27, 2014
Old 02-03-2011, 06:29 AM   #326
Asymmetry
Member#: 92646
MY03 WRX Toaster
Originally Posted by GC8WSI View Post
The only time it goes away is when I accelerate or if I put the clutch in.
I'm thinking it's the clutch or flywheel...
Read post 315, I solved the issue, its the clutch disc that causes the rattle.
Asymmetry is offline   Reply With Quote
Old 03-22-2011, 03:26 PM   #327
ColinP
Member#: 31534
2005 WRX Wagon
Very good information here! I have the Exedy HD clutch and I've been having the same decel noise issues ever since I installed it. I'm going back to OEM next time around!
Originally Posted by Asymmetry View Post
SOLVED
Many thanks to lots of people here in that posted here and on REXNET (Australia). I had this problem for three years with an Exedy HD clutch, which is the same as a exedy “OEM replacement” but with a different pressure plate (clutch cover).
Good and bad news to people, the problem seems to be the disc springs on exedy clutch. The thing is that exedy "OEM replacement" is NOT OEM! Please see pics below. The real OEM clutch has smaller springs with two extra coils, another spring inside (dual spring) with a subaru part number written on it.
I basically followed the Subaru part of service bulletin (may 1st, 03 NUMBER:03-51-02R) and ordered for my 04 WRX wagon, 5MT 2L turbo
Shopping list
Flywheel: 12342AA071
Clutch Disc: 30100AA881
Clutch cover: 30210AA630
Bearing: 30502AA080
Bolts (need 8 ) 800508310
However I suspect that most people can get away with just the clutch cover and disc replacement. Also I found that redline oil will aggravate the problem, more so if you run heavyweight. I had LWSP in the box and when I flushed it out the rattle decreased but was still there. I suspect due to the friction modifiers causing gear backlash, in short LWSP is too thick for the box, diffs are now quieter as well since switch back to OEM castrol. Also lightweight flywheels will cause this issue but thats been addressed in this thread already.
The real OEM clutch is feather light and grips, its like the new MY08-10 clutch. Not only does it not rattle but it so much smoother, grips better, responded so much better (might also be due to the updated OEM flywheel) and very light. Joy to drive, I can finally go downhill with being embarrassed and drive in traffic without getting a sore knee.
Out with the old
in with the new
ColinP is offline   Reply With Quote
Old 03-23-2011, 05:43 AM   #328
Asymmetry
Member#: 92646
MY03 WRX Toaster
^ no worries, PM replied
I got my real OEM clutch and associated parts from
http://www.subarugenuineparts.com/
Old 04-08-2011, 06:48 PM   #329
tryfe
Member#: 169008
2005 WRX
i've noticed this problem since switching to mobil 1 0w-30 last month....it never did it before...gotta remember to see if it goes away when i switch back to 5w-30. It only does it when decelerating in first or second gear..
tryfe is offline   Reply With Quote
Old 04-19-2011, 12:57 PM   #330
aknightly_wrx
Member#: 279779
2004 Impreza WRX
Java Black Pearl
I was encountering the same noise when decelerating in 04 wrx and I put my front tires to 40 psi and rear to 36 and now have no noise
aknightly_wrx is offline   Reply With Quote
Old 04-19-2011, 06:19 PM   #331
tryfe
Member#: 169008
2005 WRX
Yeah. I put air in my tires yesterday as well. I did 42/40 & it seems to have made the noise disappear some....pretty odd.
Old 04-28-2011, 09:11 AM   #332
tryfe
Member#: 169008
2005 WRX
so the rattle came back & i set tire pressure to 44/40 which didn't remedy it. finally i was able to hear the rattle with the car idling and went under the hood to locate the noise. the sound is coming from under my turbo heat shield so i'm pretty sure it's actually the wastegate chattering. i'm gonna go tighten the wastegate arm a tad in hopes that the chatter goes away.
It only chatters when at low boost at around 2200-3200rpm. I hope the sound lessens because it's really irritating.
Old 04-28-2011, 09:52 AM   #333
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Are you guys nuts? Do you have any idea how high that is once the tires are warm??
NitroTrike is offline   Reply With Quote
Old 04-28-2011, 10:13 AM   #334
tryfe
Member#: 169008
2005 WRX
I set mine when the tires are already warm.
Old 04-28-2011, 12:47 PM   #335
abehanna
Member#: 249152
2006 WRX 18G-XT
Dom Tuned OBP
This could be your actual heat shield causing the noise... The welds attaching the heat shield to the downpipe often break (happened to me after going to an aftermarket dp) and it caused the rattling sound you are talking about...
abehanna is offline   Reply With Quote
Old 04-28-2011, 04:27 PM   #336
tryfe
Member#: 169008
2005 WRX
I plan on removing the turbo heat shield Saturday if this horrendous rain stops. Once the car warms up, the sound is gone. I got an Invidia dp ready to put in so if it's the shield on the downpipe, i'll have to live with it for a bit longer as I wait for the the uppipe & header to come in.
Old 05-21-2011, 02:08 PM   #337
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Is this the decelleration noise that is happening to others? My car just started doing it today, it only has 26xx miles on it.
You have to listen closely to hear it, the wind noise is almost louder than it and it's quieter than the decelleration whine. It happens almost exactly at 1900-1800 rpms.
mrkyle3 is offline   Reply With Quote
Old 05-24-2011, 12:49 PM   #338
P-Train
Member#: 279233
2008 WRX
YouTube - ‪2011 deceleration grind‬‏
Thats the same noise I've been getting and I've only got 30K on it
P-Train is offline   Reply With Quote
Old 11-23-2011, 08:01 PM   #339
fast_lanz
Member#: 190686
02 WRX JDM V8 Swap
Hi,
Is everything still great? No deceleration noise around 3k? I noticed when I had my clutch replaced with the exedy OEM clutch as per your pic1 "the non-subaru part number" there was no noise for a while but I guess as things wore in I'm back to square one.
Thinking about getting the "official" subaru parts if your problem is still resolved.
Thanks...
fast_lanz is offline   Reply With Quote
Old 11-23-2011, 10:35 PM   #340
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
i have an 02 wrx and changed my clutch to the exedy oem replacement. i get the decel noise just like eeryone here! so the problem is that exedy did not make an oem style clutch? so the only way to fix the problem is to get an oem clutch from subaru? how much are they there anyways since they always rape their prices
filipin0y is offline   Reply With Quote
Old 11-24-2011, 12:00 AM   #341
2011OBPWRX
Member#: 296791
2011 wrx
0w and 5w are the cold temp viscosities, they are both 30 at operating temp. Doubt this has anything to do with it.
2011OBPWRX is offline   Reply With Quote
Old 11-24-2011, 03:35 PM   #342
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
Have there been any reports of automatics with this problem? My 4EAT '02 WRX definitely has a deceleration noise...any slight throttle input makes the whine go away.
OrbitalEllipses is offline   Reply With Quote
Old 01-28-2013, 01:20 PM   #343
acsitler
Member#: 341875
2013 WRX
Plasma Blue Pearl
This is exactly the noise I have in my 2013 WRX with less than 1500 miles on it. Any new info?
acsitler is offline   Reply With Quote
Old 02-09-2013, 11:21 PM   #344
guitardeek
Member#: 335808
2013 WRX
Glad I found this thread. My car is doing the same thing at just below 2k RPMs and decelerating, too. I told the dealer to look at it when I took it in for the 3000 mile oil change, and they claimed it was a heat sheild beneath my gear box. They told me they tightened it, seemed to go away for a day or so, then come back. I don't know what to think. Kind of makes me nervous, especially since it started at less than 1000 miles.
guitardeek is online now   Reply With Quote
Old 02-10-2013, 01:45 PM   #345
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
I posted the video a few posts above almost two years ago. I now have about 21k miles on my car and have had 0 issues with my transmission. I think it's just normal noisy subaru transmissions. I also occasionally have a small "grab" when pushing into third gear that lasts a split second then it goes right in. From what I've read this is also another quirk of the transmission. Don't fret over it. For a sub $30k car with performance like ours it's reasonable to expect the transmission to not be at BMW/porsche levels in terms of its smoothness. At least they hold power fairly well after the LGT gears were thrown in.
Old 02-10-2013, 11:36 PM   #346
Jdub.csu
Member#: 283784
2013 EVO X GSR
I have had this problem on my 2012 wrx since I bought it. Sometimes it sounds fine sometimes it doesn't. I did put in a Perrin Pitch Stop mount when I put in a new TMIC and it helped immensely. My next stop will be getting rid of the slop in the drive-line by going to a carbon fiber drive shaft, and upgrading the tranny mount.
Jdub.csu is offline   Reply With Quote
Old 02-11-2013, 09:22 AM   #347
ragejed
Member#: 76817
2005 WRX
50K later on my 2005 WRX and I still have the noise, tranny still works lol. I gave up and just accept the subaru love.
ragejed is online now   Reply With Quote
Old 02-11-2013, 10:33 AM   #348
PSBeachBum
Member#: 279870
2005 WRX Wagon
i had a smiliar problem. It was more of a rattle while idle and in neutral. Push the clutch in and it went away. Also made sound accelerating/decelerating in 1st. I replaced the throwout bearing and took a look at where the throwout mounts to the pressure plate. There is a little o-ring clip thingy and it seemed to be really loose and wiggly. So i took this off and bent out the metal tabs holding it in and reinstalled everything. Noise is gone. not sure if the throwout fixed this or the o-ringy clip thingy
PSBeachBum is offline   Reply With Quote
Old 02-20-2013, 09:07 PM   #349
guitardeek
Member#: 335808
2013 WRX
Just took mine back into the dealership for a second time to see what they'd say and get it documented in case it is an issue in the future. Seems like they were quite thorough while they had it jacked up and couldn't replicate the sound. They took two rides with multiple people, but it may have been hard to hear since it was raining. Will let you know if anything develops in the future. The first time I had it in they said they tightened up a heat sheild. Here's to hoping it's nothing!
Old 02-21-2013, 01:15 AM   #350
Jdub.csu
Member#: 283784
2013 EVO X GSR
Mine told me it "something all of them do since they drove multiple cars that do it" anyways got it documented incase
Deceleration Noise Issues: Clutch Only. WRX Pilot Warranty Issues & SOA Problems 147 12-20-2002 08:41 PM
Deceleration Noise Issues: Clutch Only Dat Southern California Impreza Club Forum -- SCIC 13 04-19-2002 04:44 AM
Decelerating noise Blindeye_03 Brakes, Steering & Suspension 8 04-11-2002 05:28 PM
Deceleration noise similar to WRX liberty Warranty Issues & SOA Problems 1 02-13-2002 09:44 PM
Deceleration Noise Poll (popular demand) FargoRS Warranty Issues & SOA Problems 0 12-06-2001 11:43 AM
