Old 06-28-2006, 09:17 AM   #1
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Default Installing 2002 WRX sideskirts on 2006 2.5i !!HELP!!
I am going to get a body shop to do it, but from what I can tell the installation will require some drilling. Is this correct?
I see the back of the sideskirts I bought have small plastic pins. I am assuming the body shop will have to drill holes into my car so that the pins can clip into the car and hold the sideskirt, correct?
Paraskass is offline   Reply With Quote
Old 06-28-2006, 09:30 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
2.6i sedan right?
yes you will need to drill holes to fit properly
pins clip into grommets which are drilled and fit into the car on the sides
underneath, same scenario with 6 clips snapped into 6 grommets beneath the car
there is also one plastic clip at the very front of each sideskirt
to fit properly it's a little work, nothing too challenging
Jamie
Old 06-28-2006, 09:52 AM   #3
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Originally Posted by Subie Gal
2.6i sedan right?
Jamie
Yes, 2.5i sedan.
Thanks for the useful info.
I will get a subaru dealer to do it.
What about rust prevention once the holes are drilled? I am pretty sure the are going to be drilling into metal, correct? But on the other hand the grommets will be covering the holes...
Old 06-28-2006, 01:24 PM   #4
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
This is sounding damn complicated and the body shops want to charge me a lot for the installation.
I don't know what to do.
Old 07-16-2007, 10:21 PM   #5
pakeharugger
Member#: 131920
2006 Impreza 2.5i
so how many fasteners do we need total?
pakeharugger is offline   Reply With Quote
Old 07-16-2007, 11:04 PM   #6
Cky47
Member#: 132652
Make sure you tell the shop that they are clip on stock skirts not aftermarket fiberglass ones.
Cky47 is offline   Reply With Quote
Old 07-24-2007, 10:08 PM   #7
dv@der
Member#: 140565
2007 2.5i Sedan
Crystal Gray
dv@der is offline   Reply With Quote
WRX sideskirts on 07' 2.5i 11wbc Interior & Exterior Modification 2 05-26-2008 10:34 AM
2006 wrx springs on 2006 2.5i? Nuke209 Brakes, Steering & Suspension 2 05-20-2008 06:37 PM
2004 2.5RS Oil Pan on 2006 2.5i?? Boosted WRX STi Normally Aspirated Powertrain 3 01-19-2007 10:03 PM
2002-2006 sideskirts fit 2006 2.5i Paraskass Member's Car Gallery 13 09-06-2006 12:17 AM
Install 04 WRX axleback on 06 2.5i? cstyker1111 Newbies & FAQs 3 05-03-2006 05:16 PM
Message Board Statistics All times are GMT -4. The time now is 12:57 AM.
