Old 10-22-2000, 03:17 PM   #1
martin shepard
Guest
Member#:
Post Help installing fog lts
I need help getting the wire harness routed through the firewall in my 96 legacy wgn. Any help would be appreciated.
Old 10-22-2000, 06:41 PM   #2
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Post
There should be a whole in the side of the firewall structure way up above the fuse panel on the drivers side this whole in turn comes out way back in the corner of the fender on that side. There is should be one rather large whole with a rubber plug in it. The best way to find it is to pull the fender skirt out some and run your hand back towards the door. You should be able to see/feel the wiring from the main fuse box under the hood where. The empty hole is just above where those wires go in. That's how it is on my 98GT anyway.
pleiades is offline   Reply With Quote
Old 10-22-2000, 06:55 PM   #3
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Post
Old 10-23-2000, 05:27 PM   #4
martin shepard
Guest
Member#:
Thumbs up
Thanks for the reply. I really appreciate it. The instructions call for running the harness all the way from the fuse box to the middle of the dash then through the firewall. Man talk about a load of work. I thought Id have to tear the dash apart to get to it. Thanks again.
help installing fog lights 0325ts Electrical & Lighting 2 05-12-2004 03:12 PM
help installing hella 500 in rs fog slots turbocolin Interior & Exterior Modification 4 04-25-2004 07:18 AM
need help installing replica fog light cover SFimpreza411 Bay Area Impreza Club Forum -- BAIC 7 01-21-2004 11:40 PM
Need help with fog cover install ninrex Interior & Exterior Modification 4 05-08-2002 10:03 PM
help installing hella 500 fog lights on 2002 wrx? PARAMEDIC Interior & Exterior Modification 2 01-21-2002 08:11 AM
