Old 10-17-2001, 11:19 PM   #1
driver8
Member#: 6997
Question Turbo fuel efficiency question
Curious about fuel efficiency of the turbo. Specifically, is there a significant difference in fuel consumption in a lower gear at ~3500rpm or in a higher gear at ~2500rpm (assuming your traveling at a constant speed)?
So if maintaining a constant speed at 3500rpm, is it better to upshift (for fuel efficiency) or just stay in the lower gear (and enjoy acceleration when needed)? Thanks.
driver8 is offline   Reply With Quote
Old 10-18-2001, 09:59 PM   #2
driver8
Member#: 6997
Bueller? Bueller? anyone?
Old 10-18-2001, 10:33 PM   #3
rkkwan
Member#: 5596
2010 Honda Fit Sport
Don't ask me to explain it, but I'm certain that you'll use less fuel running at a lower rpm and higher gear.
-Ray
rkkwan is offline   Reply With Quote
Old 10-18-2001, 10:39 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
You're asking us to make a lifestyle judgement for you. We'll be happy to do that, but first you'll need to tell us more about yourself.
Jon [in CT] is offline   Reply With Quote
Old 10-18-2001, 10:59 PM   #5
driver8
Member#: 6997
no, but thanks for the offer Jon. At least I know where to turn if it ever comes to that.
Normally, I like to stay in the lower gear to minimize affect of turbo lag and have the acceleration readily available. - it's a lifestyle choice. I drive a lot of miles and was curious if there were inherent efficiencies of a turbo system (read: rationalizing my lifestyle choice).
Anyway, it's probably as simple as this:
higher rpm's = higher turbo rpm = more air = more fuel
Thanks again.
Old 10-18-2001, 11:22 PM   #6
Silver_Bell_WRX
Member#: 7677
2005 WRX
You have answer your own question. With the turbo spooled up the car will use more gas.
Silver_Bell_WRX is offline   Reply With Quote
Old 10-19-2001, 08:17 AM   #7
AlexM_UK
Member#: 6825
1999 Impreza Turbo
I would like to know the answer to this too...
I think that by using more rpm you are getting closer to peak volumetric efficiency (torque peak) so economy is potentially better, but this is offset by increased friction and pumping losses (nearly closed throttle at cruise).
Anyone know?
Cheers,
A.
AlexM_UK is offline   Reply With Quote
Old 10-19-2001, 08:31 AM   #8
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Higher gear, lower rpm is best for gas mileage. That's why 6-speed transmissions typically make 6th essentially unusably high except for highway cruising at low rpm.
Also, with a turbo, staying off boost will improve mileage in direct proportion to the decrease in fun.
Ben
bsquare is offline   Reply With Quote
Old 10-19-2001, 08:38 AM   #9
driver8
Member#: 6997
bsquare,
i disagree. it's not direct - it's exponential!
increasing turbo fuel efficiency moonzie Baja Forum 5 06-12-2007 12:36 PM
Question on NA vs Turbo fuel efficiency G.Subramaniam Normally Aspirated Powertrain 4 08-07-2006 06:00 PM
fuel efficiency question nhmtns Newbies & FAQs 3 09-18-2005 05:04 PM
300ZX Twin Turbo Fuel pump Question. BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-31-2001 04:13 PM
turbo fuel pressure questions bttune2.5rs Normally Aspirated Powertrain 5 03-01-2001 12:47 AM
