Old 06-29-2006, 06:44 PM   #1
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Angry AP instructions retarded or just me?
I'm trying to install my Cobb AP right now and can't even get past the 1st step of install: connecting the testmode connectors. I can't find 'em. I see no green connectors at all. However I do see a few wide white connectors just hanging and what looks like a previously installed alarm system (not working) seeming to be done kinda sloppy. I've been under the dash for about 30 mins looking and sweating and steaming. Can Anyone help?
PS
I also tried looking under the pass. side dash for the connectors as suggested but to no avail.
that1dude is offline   Reply With Quote
Old 06-29-2006, 06:46 PM   #2
dvang
Member#: 84188
05 legacy
caravan full of kids now
your just retarded
and dont get pissy you asked
its in there go back and look again
dvang is offline   Reply With Quote
Old 06-29-2006, 06:47 PM   #3
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Thanks, a lotta help. But yes I did ask for that.
Old 06-29-2006, 07:20 PM   #4
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
ok IM retearded... I found the connectors butt.... then the AP said it wasn't reading my ECU. I tried turning the key on/ off a few times but nothing. Then i disconnected the AP and tried to start from the beginning... Now the car won't go into test mode so I can't remap and I can't start the car( and I did try disconnecting the batt.). Please help!
Old 06-29-2006, 07:24 PM   #5
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
You should probably call COBB.
LetItSnow is offline   Reply With Quote
Old 06-29-2006, 07:28 PM   #6
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Yea the tech line was my next stop... thx
Edit: Shoulda thought of that first, duh.
Old 06-29-2006, 07:59 PM   #7
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Did you connect the initilization connector?
If it says low voltage hook up a battery charger during the flashing.
And you do have a instruction manual right? If not here you go: http://www.accessecu.com/support/ap-usersguide-wrx.pdf
boundy3 is offline   Reply With Quote
Old 06-29-2006, 08:57 PM   #8
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Have a Nice Day?
Yes and Yes. The tech line guy suggested I disconnect the batt. for up to 45 mins so I did. During this time, the test conns and initialization conn. were connected. Before reconnecting the batt, I disconnected the test conns but not the initialization one (if that matters). After reconnecting the batt, I turned the key on expecting (hoping) that it would go into test mode. Fuel pump turns on but runs constantly not cycling on/off, fan isn't on and CEL isn't flashing but solid. I try to start: crank- no start. Now it's too late to call Cobb again and my car's refusing to wake up. Any other troubles I could try shooting?
PS
It never said low voltage but I didn't even try reconnecting the AP itself after re-hooking the batt because the car wasn't in test mode.
Old 06-29-2006, 09:04 PM   #9
hondaeater69
Member#: 60324
in the steps listed you didn't mention reconnecting the test mode connectors after disconnecting the neg bat cable. Perhaps you should give it a rest until you can contact cobb, you CAN fubar your ECU if the steps aren't followed properly.
Old 06-29-2006, 09:08 PM   #10
k mier
Member#: 98000
05 sti [email protected]
Green test connectors were behind the steering wheel. Mine were loose, probably flashed from the previous owner. When the battery is disconnected tap the brakes a couple times this should drain any remaining stored power. Do not let the battery voltage drop too low during flash, put a charger on it to be sure. You do not want to stop for anything during the flash. Mine would hang around, IIRC, ~22% and ~70%, give it time, it should continue.
When the car goes into test mode, the fans kicking on and off and changing speed are the most obvious signs.
And yes, the "constructions" as my boy calls them, could be better.
I have heard of bad cables.
k mier is offline   Reply With Quote
Old 06-29-2006, 09:24 PM   #11
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
edited
Old 06-29-2006, 09:29 PM   #12
intence
Member#: 58477
. Member #1 of
the witty MS Crew
the older instructions are retarded. the one on their website is more direct. the newer cobbs probably have the same directions as on their website.
intence is offline   Reply With Quote
Old 06-29-2006, 09:32 PM   #13
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
The test connectors weren't together while the batt was unhooked but reconnected after the battery was. Right now i just have the battery disconnected and I hope it will just reflash itself to stock (since no AccessECU data was downloaded to my ECU) so I can get to work in the morning. The last thing I want is FUBAR.
Old 06-29-2006, 09:32 PM   #14
boundy3
Member#: 54598
2004 WRX Sedan
I also remember reading somewhere that there is also a set of green connectors that could be disconnected under the drivers kick plate (the plastic cover where the carpet meets the door) or around that area under the carpet. It is very rare for them to be disconnected but this may be a case of that. You may want to try researching that more, or look under that carpet area.
Good Luck
Old 06-29-2006, 09:46 PM   #15
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Good Luck
Actually these other connectors might be under the passenger kick plate. It should be covered in the instructions.
Old 06-29-2006, 10:04 PM   #16
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
^^^ I don't think that's it, cuz the car did go into test mode the first time I tried to install it.
Could the ECU be fried if the lights, fuel pump, radio, ect still work?
Old 06-29-2006, 10:33 PM   #17
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
Provided your battery is good, and you didn't get anywhere in the flash process as you say... go back to your car... reconnect the Batt. make sure the WHITE connector is in place. Then connect the two green connectors (mine were up high to the left, had to get on the ground to fiddle with them.)
Put the key in, turn it to the "ON" position... but do not start the engine... look at the key hole carefully and you will know what I mean. Once in the "ON" position, you will hear the noises, and you will see the CEL doing it's thing. Plug in your AP at this point.
It should turn on, and ask you to press "OK" to pick a map. Select your map, press "OK" again, and since you are an 03, you will need to turn the Key to the "OFF" position, then back to the "ON" position, (without turning the engine on) you then have 3-10 secods to press the "OK" button to begin your flash...Be sure to have the AP handy before you turn the Key to the "OFF" position!!!
And don't leave any of the connectors in the car... I don't think the car will start with either the green ones together, or the white one (for 03)
ThrawlWRX is offline   Reply With Quote
Old 06-29-2006, 10:51 PM   #18
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Have a Nice Day?
What if I didn't have the AP handy when I turned the key off because I had to connect it to its harness first...?
Oh shi wait; I think I do remember seeing the AP reflashing for a few seconds before it encountered the initial error. But maybe it was saying "initializing" tho...errmm.
Old 06-29-2006, 11:10 PM   #19
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
hurting....
This guy is selling his Stock 2003 ecu with ECUtek license...tuned for vf34 and pinks for 400... cheaper than the dealer will charge you for a new one.
http://forums.nasioc.com/forums/show...light=2003+ecu
Old 06-29-2006, 11:48 PM   #20
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Unhappy
(*disbelief*)Uh, are you trying to put it to me nicely? Does that mean I'm focked? I don't have pinks or a VF but are you suggesting I buy this ECUtek, send it somewhere to get reflashed for my car and sell the AP? Or have I rendered the AP usless as well? WTF, 1st electrical type of project I've ever tried and I kill my car /
I'm sticking to nuts and bolts only from now on! (not really) This is the excact reason I love classic cars. NO COMPUTATORS.
Old 06-29-2006, 11:59 PM   #21
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
To be honest, I'm not sure what to tell you. If you put your car back to the way it was stock (plug wise) and it won't start... I would either ask cobb for a suggestion... or start looking for a new ECU which will cost you a pretty penny(at least 500 new), I would check Ebay every day. Is this your daily driver?
Old 06-30-2006, 12:01 AM   #22
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Haha, yes it's my DD.
Old 06-30-2006, 12:16 AM   #23
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
Try starting the car with that initialization connecter out.
Old 06-30-2006, 12:17 AM   #24
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
from your descriptions... your ECU "should" be fine.
As a test, put everything back the way it was, green plugs appart, the white plug out, the AP unplugged. put your batt back on. And Cross your fingers.
Old 06-30-2006, 12:25 AM   #25
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
the i.c. WAS out.
Is microsoft.com/office slow for others or just me? -=C=- Off-Topic 7 04-14-2004 10:44 AM
Does anyone have a problem with Wagonmaster or just me? svxr8dr Off-Topic 115 11-20-2003 09:25 PM
LIfe pooping on me, or just me outlook? docwhorocks Off-Topic 7 08-06-2003 01:38 PM
is it a weed or just me milkman Interior & Exterior Modification 0 07-10-2001 01:23 AM
Subaru of SC unresponsive to Email or just me? tmblue Bay Area Impreza Club Forum -- BAIC 5 03-31-2001 04:22 AM
