Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-29-2006, 08:34 PM   #1
04works
Member#: 91493
2006 STi
Default utec w/ automatic. somethings wrong?
i have a 2004 wrx( w/ 2002/2003 ecu, early production car) with the following mods.
utec
vf39
modded 810 injectors
dp
up
exhaust
fmic
bov
fuel pump
wb 02
-my problem is that this is the 2nd time i've taken it to the track, and the best i can pull out of it is anywhere from a 15 sec. to a 25 sec. 1/4 depending on how bad it falls on it's face during the run?
-does anyone know why my car is falling on its ass. it hits up to about 16 psi, then when the car wants to shift naturally, i falls on its ass, almost feels like a misshift(not possable because it's an automatic.
- is there something w/ an automatic trany that messes up the utec? PLEASE HELP, this is killing me. thanks , anthony I POSTED LOGS
I'M RUNNING CLOSED LOOP!!!
04works is offline   Reply With Quote
Old 06-29-2006, 08:52 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yes the automatic can have an issue if using the open loop fueling. I believe in the manual it says that in rather large bold letters.
cdvma is offline   Reply With Quote
Old 06-30-2006, 01:37 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You cannot run UTEC OLF with an automatic
mick_the_ginge is offline   Reply With Quote
Old 06-30-2006, 11:44 AM   #4
04works
Member#: 91493
2006 STi
not running ol. i'm running a closed loop fuel & boost map
Old 06-30-2006, 12:25 PM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Do you have a log of this happening?
Old 06-30-2006, 12:28 PM   #6
04works
Member#: 91493
2006 STi
yeah, just not w/ me. i'll post it later today
Old 06-30-2006, 06:48 PM   #7
04works
Member#: 91493
2006 STi
anyone?
Old 06-30-2006, 07:05 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Ya me..... You're running big injectors with the utec to not be using olf. When was the last time you checked the a/f ratio at boost? Who tuned your car? Where's the log?
Old 06-30-2006, 07:10 PM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Not sure, I am not a UTEC user because of the issues with tuning. But I was at the Track about a week ago with the AP Stage 2 and my best time was 14.8. The Automatics seem to have a problem hitting target boost at the drag strip. I can hit boost just fine on the highway if I mash the gas. But at the track I couldn't get it over 14.5 psi. Hell, it wouldn't even let me launch at full boost like it has let me on the street.
You definitely have more mods than my g/fs 04 WRX, and we are pulling faster times than you. So something is wrong. Maybe we could diagnose it better if you had some logs of your runs. At your power level, are you sure you aren't slipping the clutches in the transmission? I have heard you shouldn't go over 300 crank horsepower without transmission mods on the autos.
Old 06-30-2006, 07:36 PM   #10
04works
Member#: 91493
2006 STi
I'll get the logs when i get my other comp. back. but my afrs are right where there supposed to be i think. under full throttle, it reads rich on the utec, and 10.1 i believe on the aem wb 02
Old 07-01-2006, 11:34 AM   #11
jabbott
Member#: 73054
2002 WRX 2.5, 4eat
yea something is wrong, I ran low 13's with a stock turbo, intercooler and stock cat back.
First check to see that the maf scaller is turned on and open loop fuel is off. If olf is on, it will kill your tranny quick.
It is normal for the motor to sound like it's misfiring during shifts cause basically it is! The ecu shuts down cylinders during shifts as to not over power the tranny. Thats why olf doesn't work with an auto. When in open loop the signal telling the ecu it's shifting is no longer sent to the ecu for some reason.
Check that and post your logs cause something isn't right. oh and 10.1-1 is pretty rich. Shoot for like 11.0-1
You might wanna look into a problem with your boost control (i.e. boost map, bleeder valve etc.) I have had 3 different turbos and setups and have never had a problem building or holding boost. At the track or on the street.
jabbott is offline   Reply With Quote
Old 07-03-2006, 12:49 PM   #12
04works
Member#: 91493
2006 STi
Old 07-07-2006, 09:18 AM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by 04works
logs, guy, logs. get them posted.
Old 07-12-2006, 08:01 PM   #14
04works
Member#: 91493
2006 STi
Old 07-14-2006, 07:04 PM   #15
04works
Member#: 91493
2006 STi
run # 1
heres the logs... Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count AFR Ign#1 Inj#1 Ign Fuel Boost MAF
psig V % deg duty deg % (CL) V
00 +0.0 0.6 0 00 00 14.8 +30.0 0.0 ECU. -4.1 ECU. 0.6
598 -8.8 1.2 0 00 00 15.5 +16.4 1.0 ECU. -4.1 ECU. 1.1
651 -8.8 1.2 0 00 00 15.5 +16.6 1.0 ECU. -4.1 ECU. 1.1
599 -8.3 1.8 7 00 00 15.4 +14.5 20.1 ECU. -4.1 ECU. 2.0
1084 -6.3 1.8 14 00 00 13.8 +19.9 3.0 ECU. -4.1 ECU. 1.8
1506 -4.7 2.0 15 00 00 13.5 +24.0 5.0 ECU. -4.6 ECU. 2.0
1736 -2.8 2.2 15 00 00 14.5 +27.2 5.7 ECU. -6.6 ECU. 2.0
1838 -1.4 2.2 15 00 00 14.3 +29.0 6.5 ECU. -6.6 ECU. 2.1
1849 -1.6 2.3 15 00 00 14.7 +29.7 6.3 ECU. -6.6 ECU. 2.1
1898 -1.8 2.3 15 00 00 14.3 +29.9 6.3 ECU. -6.6 ECU. 2.1
1895 -1.4 2.5 50 00 00 14.7 +29.3 10.4 ECU. -6.6 200.00 2.2
1975 -1.0 2.5 71 10 00 14.4 +29.3 58.4 ECU. -6.6 252.00 2.2
1977 -0.2 2.5 78 10 00 12.9 +28.6 7.3 ECU. -6.9 266.00 2.3
1935 +0.4 2.5 81 10 00 15.4 +27.1 7.2 ECU. -6.8 271.00 2.2
2067 +0.8 2.5 82 10 00 14.9 +28.5 7.8 ECU. -6.6 272.00 2.3
2174 +1.2 2.6 82 10 00 15.0 +28.4 8.4 ECU. -6.6 272.00 2.4
2252 +1.2 2.5 84 10 00 14.9 +28.8 8.4 ECU. -6.6 314.00 2.4
2403 +1.4 2.6 84 10 00 14.9 +29.1 9.9 ECU. -6.6 314.00 2.4
2517 +1.9 2.7 85 10 00 14.7 +28.7 11.1 ECU. -6.6 370.00 2.5
2683 +1.9 2.7 86 10 00 14.5 +27.9 10.2 ECU. -6.7 372.00 2.6
2883 +2.3 2.9 87 20 00 14.4 +27.2 12.9 ECU. -6.6 374.00 2.6
3100 +2.7 2.9 88 20 00 14.3 +23.9 12.9 ECU. -6.7 376.00 2.7
3277 +3.1 3.0 88 20 00 14.7 +23.5 13.6 ECU. -6.8 376.00 2.8
3494 +3.9 3.1 88 30 00 14.5 +24.8 14.7 ECU. -5.9 376.00 2.9
3732 +4.7 3.2 88 30 00 14.7 +24.7 18.2 ECU. -6.2 376.00 3.0
4001 +5.3 3.3 88 30 00 14.1 +23.2 18.3 ECU. -6.4 376.00 3.2
4312 +6.5 3.5 88 40 00 14.0 +20.2 37.1 ECU. -5.5 376.00 3.4
4553 +8.4 3.8 88 60 00 rich +14.9 49.6 +20.3 -5.2 376.00 3.7
4708 +10.2 3.9 88 70 00 rich +16.1 56.9 +19.7 -5.3 376.00 3.7
5065 +12.5 3.9 88 70 00 rich +18.4 58.6 +19.5 -5.5 376.00 3.7
5291 +13.7 4.0 84 70 00 rich +18.9 58.9 +20.5 -5.5 368.00 3.8
5678 +14.1 4.1 84 70 00 rich +19.5 68.0 +21.7 -5.5 368.00 3.9
5889 +14.3 4.1 83 70 00 rich +21.2 65.8 +22.0 -5.4 366.00 3.9
5899 +13.9 4.1 82 70 00 rich +21.4 72.5 +22.0 -5.4 364.00 3.9
6242 +14.1 4.2 83 70 00 rich +22.5 71.5 +22.0 -5.4 366.00 4.0
5737 +13.3 3.9 34 00 00 rich +24.3 33.4 ECU. -6.6 ECU. 3.6
6060 +11.0 3.4 15 00 00 12.5 +33.0 33.4 ECU. -6.6 ECU. 3.0
4616 +6.5 3.4 10 00 00 21.1 +26.8 33.4 ECU. -6.6 ECU. 2.6
3716 +2.7 2.9 22 00 00 12.9 +31.0 17.6 ECU. -6.6 ECU. 2.9
3885 +1.0 3.3 53 00 00 rich +24.8 22.3 ECU. -6.6 252.00 3.0
3972 +1.4 3.4 54 00 00 rich +23.3 25.1 ECU. -6.6 256.00 3.2
4140 +4.5 3.5 55 00 00 rich +20.9 28.3 ECU. -6.6 260.00 3.3
4535 +7.4 3.8 55 00 00 rich +16.8 25.2 ECU. -6.6 260.00 3.5
3866 +9.2 3.6 54 00 00 15.1 +17.8 25.2 ECU. -6.6 256.00 3.0
3310 +10.6 3.3 55 00 00 rich +18.6 23.4 ECU. -6.6 260.00 3.0
3346 +11.2 3.3 54 00 00 rich +18.9 24.1 ECU. -6.6 256.00 3.0
3356 +11.4 3.3 55 00 00 rich +19.3 22.4 ECU. -6.6 260.00 3.0
3363 +11.2 3.3 57 00 00 rich +19.6 23.0 ECU. -6.6 268.00 3.1
3394 +11.2 3.2 59 00 00 rich +19.6 18.7 ECU. -6.6 276.00 3.0
3367 +11.2 3.3 62 60 00 14.5 +19.2 16.9 +17.6 -5.5 284.00 3.1
3450 +11.4 3.3 65 60 00 13.9 +18.2 18.7 +17.5 -5.3 290.00 3.1
3353 +11.6 3.3 66 60 00 14.8 +17.5 18.4 +17.0 -5.4 292.00 3.1
3439 +11.4 3.3 68 60 00 14.7 +17.8 19.2 +16.9 -5.3 296.00 3.2
3457 +11.6 3.4 68 60 00 14.9 +17.4 21.5 +16.5 -5.1 296.00 3.2
3516 +11.9 3.4 69 60 00 14.5 +17.8 19.8 +16.4 -5.2 298.00 3.2
3546 +12.1 3.4 70 70 00 14.7 +17.4 19.3 +16.1 -5.1 300.00 3.2
3599 +12.1 3.4 70 60 00 14.6 +17.7 19.4 +16.4 -5.2 300.00 3.2
3623 +12.7 3.4 71 70 00 14.8 +18.0 27.4 +16.5 -5.1 306.00 3.2
3711 +12.7 3.5 71 70 00 rich +17.6 28.1 +16.5 -5.1 306.00 3.3
3757 +13.1 3.5 72 70 00 rich +17.7 28.0 +16.6 -5.0 312.00 3.3
3775 +13.3 3.5 72 70 00 rich +17.7 30.8 +16.6 -5.0 312.00 3.4
3844 +13.3 3.5 72 70 00 rich +17.4 31.0 +16.8 -5.0 312.00 3.3
3889 +13.5 3.6 73 70 00 rich +17.7 31.1 +16.8 -5.0 318.00 3.4
3935 +13.9 3.6 73 80 00 rich +17.6 31.1 +16.6 -5.0 318.00 3.4
3968 +14.3 3.6 73 80 00 rich +17.6 29.8 +16.6 -5.0 318.00 3.4
3992 +14.5 3.6 73 80 00 rich +17.7 32.1 +16.9 -5.0 318.00 3.4
4060 +14.7 3.6 73 70 00 rich +17.6 31.9 +17.1 -5.0 318.00 3.4
4089 +14.5 3.6 73 70 00 rich +17.6 34.9 +17.1 -5.0 318.00 3.4
4130 +14.1 3.6 71 70 00 rich +16.8 42.6 +17.1 -5.0 306.00 3.5
4140 +13.7 3.7 69 70 00 rich +16.6 39.4 +17.4 -5.0 298.00 3.4
4192 +14.1 3.7 68 70 00 rich +16.4 40.6 +17.1 -5.0 296.00 3.5
4240 +13.9 3.6 65 80 00 rich +16.4 41.7 +16.9 -5.0 290.00 3.5
4278 +13.9 3.7 63 70 00 rich +15.9 43.2 +17.6 -5.0 286.00 3.4
4268 +14.5 3.7 63 70 00 rich +15.2 43.5 +17.4 -5.0 286.00 3.5
4380 +13.9 3.7 65 70 00 rich +15.5 43.5 +17.5 -5.1 290.00 3.5
4374 +13.9 3.7 67 70 00 rich +15.0 44.9 +17.9 -5.1 294.00 3.5
4409 +13.9 3.7 71 70 00 rich +14.6 48.0 +18.4 -5.1 306.00 3.6
4492 +13.5 3.8 71 70 00 rich +14.5 52.2 +18.5 -5.1 306.00 3.5
4510 +13.5 3.9 72 70 00 rich +14.9 51.2 +18.5 -5.1 312.00 3.6
4516 +13.7 3.9 73 80 00 rich +15.6 48.3 +18.1 -5.2 318.00 3.6
4636 +13.9 3.8 76 70 00 rich +15.8 52.3 +18.6 -5.2 336.00 3.6
4604 +14.1 3.8 75 70 00 rich +16.4 54.5 +18.8 -5.2 330.00 3.7
4541 +14.1 3.8 76 70 00 rich +15.2 49.4 +18.9 -5.2 336.00 3.6
4610 +13.9 3.9 77 70 00 rich +15.2 56.1 +18.8 -5.2 342.00 3.7
4668 +14.1 3.9 77 70 00 rich +16.1 55.6 +19.0 -5.2 342.00 3.7
4701 +14.3 3.9 77 80 00 rich +16.4 56.9 +18.8 -5.4 342.00 3.7
4734 +14.9 3.9 76 80 00 rich +16.3 54.9 +18.4 -5.2 336.00 3.7
4728 +15.3 4.0 76 80 00 rich +16.7 57.6 +18.3 -5.3 336.00 3.8
4823 +15.5 4.0 76 80 00 rich +17.2 57.9 +18.5 -5.2 336.00 3.7
4909 +15.5 3.9 76 80 00 rich +17.3 59.3 +18.7 -5.3 336.00 3.7
4880 +15.1 3.9 76 80 00 rich +18.2 59.2 +18.7 -5.3 336.00 3.8
4830 +15.1 4.0 78 80 00 rich +18.3 58.4 +18.8 -5.3 348.00 3.8
4901 +15.1 4.0 75 80 00 rich +18.8 61.7 +18.6 -5.4 330.00 3.8
4923 +14.7 4.0 72 80 00 rich +19.1 60.3 +19.0 -5.5 318.00 3.8
4967 +15.1 4.0 72 80 00 rich +19.3 60.7 +18.8 -5.5 328.00 3.8
5035 +15.3 4.0 72 80 00 rich +20.8 61.4 +18.1 -5.5 328.00 3.8
5027 +15.5 4.0 72 80 00 rich +19.6 58.5 +18.3 -5.5 328.00 3.7
5112 +16.1 4.0 71 80 00 rich +21.1 62.1 +18.7 -5.5 328.00 3.8
5120 +15.7 4.0 69 80 00 rich +21.4 60.0 +19.2 -5.5 316.00 3.8
5112 +15.3 4.0 47 00 00 rich +20.3 56.8 ECU. -6.6 ECU. 3.7
4930 +12.7 2.8 5 00 00 rich +37.6 12.9 ECU. -6.6 ECU. 3.4
4604 +6.5 3.4 0 00 00 rich +7.7 19.7 ECU. -6.6 ECU. 3.1
4235 +0.6 3.1 0 00 00 13.8 +7.8 19.7 ECU. -6.6 ECU. 2.8
3631 -5.5 2.8 0 00 00 lean +8.0 19.7 ECU. -6.6 ECU. 2.5
3223 -9.4 2.3 0 00 00 24.5 +10.3 19.7 ECU. -6.6 ECU. 2.0
3223 -10.0 2.1 0 00 00 24.2 +11.3 19.7 ECU. -6.6 ECU. 2.0
3186 -10.4 2.2 0 00 00 24.5 +11.5 19.7 ECU. -6.6 ECU. 2.3
3183 -10.8 2.3 0 00 00 24.5 +11.5 19.7 ECU. -6.6 ECU. 2.1
3141 -11.2 2.3 0 00 00 24.2 +11.4 19.7 ECU. -6.6 ECU. 2.1
3138 -11.6 2.3 0 00 00 24.5 +11.4 19.7 ECU. -6.6 ECU. 2.1
3100 -11.8 2.2 0 00 00 24.5 +11.3 19.7 ECU. -6.6 ECU. 2.1
3072 -12.0 2.2 0 00 00 24.2 +11.4 19.7 ECU. -6.6 ECU. 2.0
3060 -12.0 2.1 0 00 00 24.5 +11.4 19.7 ECU. -6.6 ECU. 2.0
3022 -12.0 2.1 0 00 00 24.2 +11.5 19.7 ECU. -6.6 ECU. 2.0
3000 -12.0 2.1 0 00 00 24.5 +11.5 19.7 ECU. -6.6 ECU. 1.9
2989 -12.0 2.1 0 00 00 24.5 +11.4 19.7 ECU. -6.6 ECU. 1.9
2976 -12.0 2.1 0 00 00 24.2 +11.5 19.7 ECU. -6.6 ECU. 1.9
2957 -12.0 2.1 0 00 00 24.2 +11.4 19.7 ECU. -6.6 ECU. 1.9
2957 -12.0 2.1 0 00 00 lean +11.6 19.7 ECU. -6.6 ECU. 1.9
2896 -12.0 2.0 0 00 00 lean +11.5 19.7 ECU. -6.6 ECU. 1.9
2861 -12.2 2.0 0 00 00 lean +11.4 19.7 ECU. -6.6 ECU. 1.9
2834 -12.2 2.0 0 00 00 lean +11.5 19.7 ECU. -6.6 ECU. 1.9
2824 -12.4 2.0 0 00 00 24.5 +11.6 19.7 ECU. -6.6 ECU. 1.9
2808 -12.4 2.0 0 00 00 24.2 +11.5 19.7 ECU. -6.6 ECU. 1.9
2789 -12.2 2.0 0 00 00 24.2 +11.5 19.7 ECU. -6.6 ECU. 1.8
2741 -12.2 2.0 0 00 00 24.5 +11.6 19.7 ECU. -6.6 ECU. 1.8
2707 -12.2 1.9 0 00 00 lean +11.6 19.7 ECU. -6.6 ECU. 1.8
Old 07-14-2006, 07:05 PM   #16
04works
Member#: 91493
2006 STi
run #2
641 -8.5 1.3 0 00 00 14.8 +13.4 2.1 ECU. -4.1 ECU. 1.2
656 -8.8 1.3 0 00 00 14.8 +13.6 1.8 ECU. -4.1 ECU. 1.2
631 -9.0 1.3 0 00 00 14.8 +13.3 1.8 ECU. -4.1 ECU. 1.2
635 -9.0 1.3 0 00 00 14.8 +13.4 1.6 ECU. -4.1 ECU. 1.2
676 -8.8 1.3 0 00 00 14.8 +13.3 1.9 ECU. -4.1 ECU. 1.3
656 -8.3 1.2 0 00 00 15.1 +12.9 1.3 ECU. -4.1 ECU. 1.1
614 -8.3 1.2 0 00 00 15.1 +12.2 1.3 ECU. -4.1 ECU. 1.1
650 -8.3 1.2 0 00 00 15.1 +12.9 1.0 ECU. -4.1 ECU. 1.1
637 -8.5 1.2 0 00 00 15.1 +14.1 1.5 ECU. -4.1 ECU. 1.2
647 -8.5 1.2 0 00 00 15.2 +14.4 1.3 ECU. -4.1 ECU. 1.2
652 -8.5 1.2 0 00 00 15.2 +13.9 1.3 ECU. -4.1 ECU. 1.1
655 -8.5 1.2 0 00 00 15.2 +13.3 1.3 ECU. -4.1 ECU. 1.1
635 -8.5 1.2 0 00 00 15.1 +13.0 1.0 ECU. -4.1 ECU. 1.1
659 -8.5 1.2 0 00 00 15.0 +12.6 1.5 ECU. -4.1 ECU. 1.2
653 -8.5 1.3 0 00 00 14.8 +13.4 1.5 ECU. -4.1 ECU. 1.4
774 -7.7 2.0 8 00 00 14.6 +16.1 6.9 ECU. -4.1 ECU. 1.9
1262 -5.9 2.0 16 00 00 rich +19.0 3.4 ECU. -4.1 ECU. 2.0
1603 -3.9 2.1 18 00 00 14.6 +20.9 6.1 ECU. -4.8 ECU. 2.0
1806 -2.0 2.2 18 00 00 14.3 +25.4 6.1 ECU. -6.6 ECU. 2.1
1850 -1.2 2.3 18 00 00 15.0 +28.3 7.4 ECU. -6.6 ECU. 2.1
1932 -1.2 2.3 18 00 00 14.5 +31.4 7.8 ECU. -6.6 ECU. 2.1
1950 -1.0 2.3 18 00 00 14.7 +31.4 6.6 ECU. -6.6 ECU. 2.2
1964 -1.0 2.3 18 00 00 14.8 +31.8 8.0 ECU. -6.6 ECU. 2.2
1975 -1.0 2.3 18 00 00 14.8 +31.8 8.1 ECU. -6.6 ECU. 2.2
2041 -0.8 2.4 44 00 00 14.8 +31.0 13.7 ECU. -6.6 ECU. 2.3
2011 -0.2 2.5 61 10 00 14.9 +29.6 73.7 ECU. -6.6 232.00 2.3
2038 +0.2 2.4 72 10 00 12.1 +28.5 4.9 ECU. -6.6 254.00 2.4
2033 +0.6 2.5 75 10 00 15.4 +28.3 64.1 ECU. -6.6 260.00 2.3
2099 +1.0 2.5 80 10 00 14.7 +28.5 8.5 ECU. -6.6 270.00 2.4
2200 +1.0 2.5 82 10 00 15.6 +28.4 8.1 ECU. -6.6 272.00 2.4
2326 +1.4 2.6 82 10 00 14.7 +28.8 9.3 ECU. -6.6 292.00 2.4
2445 +1.7 2.6 83 10 00 15.1 +28.0 8.9 ECU. -6.7 366.00 2.5
2564 +1.9 2.7 84 10 00 14.3 +29.0 9.5 ECU. -6.7 368.00 2.6
2750 +2.1 2.7 83 10 00 14.3 +28.2 12.0 ECU. -6.8 366.00 2.6
2976 +2.3 2.9 82 20 00 14.6 +26.2 14.4 ECU. -6.5 364.00 2.7
3153 +2.7 3.0 84 20 00 14.1 +24.2 13.8 ECU. -6.8 368.00 2.8
3350 +3.3 3.1 84 20 00 14.3 +23.9 16.2 ECU. -6.4 368.00 2.9
3599 +4.1 3.2 84 30 00 14.7 +24.9 17.3 ECU. -6.1 368.00 3.0
3835 +5.1 3.3 83 30 00 15.1 +23.8 20.0 ECU. -6.3 366.00 3.2
4151 +6.3 3.5 82 40 00 13.8 +22.0 21.5 ECU. -5.5 364.00 3.4
4438 +7.8 3.7 79 50 00 14.9 +15.2 25.2 +20.0 -5.2 354.00 3.5
4755 +9.2 3.9 75 60 00 rich +15.7 54.6 +20.7 -5.2 330.00 3.7
4887 +11.0 4.0 73 70 00 rich +18.2 57.8 +19.9 -5.4 318.00 3.7
5307 +12.7 4.0 72 70 00 rich +20.7 57.7 +20.0 -5.5 328.00 3.8
5509 +12.7 3.8 35 00 00 rich +23.7 34.7 ECU. -6.6 ECU. 3.6
5621 +11.9 3.5 18 00 00 rich +29.5 27.8 ECU. -6.6 ECU. 3.0
5995 +9.0 3.6 30 00 00 16.4 +32.3 30.1 ECU. -6.6 ECU. 3.4
6071 +6.8 3.8 36 00 00 rich +31.6 34.8 ECU. -6.6 ECU. 3.5
5333 +5.7 3.7 36 00 00 16.7 +28.3 36.1 ECU. -6.6 ECU. 3.3
4591 +5.1 3.5 37 00 00 17.6 +23.4 36.1 ECU. -6.6 ECU. 3.2
4438 +6.3 3.5 46 00 00 rich +20.6 31.9 ECU. -6.6 ECU. 3.3
4486 +7.0 3.6 48 00 00 rich +20.4 32.4 ECU. -6.6 ECU. 3.3
4151 +7.6 3.5 49 00 00 rich +21.6 28.7 ECU. -6.6 ECU. 3.2
4219 +8.4 3.6 52 00 00 rich +20.3 22.9 ECU. -6.6 248.00 3.3
4340 +9.2 3.7 54 00 00 14.8 +17.5 26.1 ECU. -6.6 256.00 3.4
4450 +10.6 3.7 55 00 00 13.5 +15.4 27.0 ECU. -6.6 260.00 3.5
4591 +11.4 3.8 56 00 00 13.9 +15.9 26.4 ECU. -6.6 264.00 3.5
4755 +11.9 3.8 57 00 00 14.7 +16.3 30.8 ECU. -6.6 268.00 3.6
4894 +12.7 3.9 56 00 00 14.4 +17.2 29.9 ECU. -6.6 264.00 3.5
4916 +12.5 3.9 56 00 00 14.5 +18.8 30.8 ECU. -6.6 264.00 3.6
5073 +12.5 3.9 54 00 00 14.3 +20.2 32.8 ECU. -6.6 256.00 3.6
5159 +12.5 3.9 54 00 00 15.0 +21.1 33.7 ECU. -6.6 256.00 3.6
5376 +12.1 3.9 53 00 00 15.1 +21.7 33.5 ECU. -6.6 252.00 3.7
5491 +12.3 4.0 53 00 02 14.5 +21.3 30.7 ECU. -6.6 252.00 3.7
5592 +12.5 4.0 53 00 10 14.5 +20.3 31.7 ECU. -6.6 252.00 3.7
5649 +12.9 4.0 53 00 00 14.6 +20.6 32.1 ECU. -6.6 252.00 3.8
5837 +13.7 4.0 52 00 00 14.9 +21.3 48.1 ECU. -6.6 248.00 3.8
5889 +13.1 4.1 49 00 00 rich +22.2 45.1 ECU. -6.6 ECU. 3.8
6060 +12.1 4.0 46 00 00 rich +24.2 46.2 ECU. -6.6 ECU. 3.8
6105 +11.0 4.0 46 00 00 rich +25.3 45.0 ECU. -6.6 ECU. 3.8
6242 +9.6 4.0 46 00 00 rich +28.8 46.4 ECU. -6.6 ECU. 3.7
6207 +10.0 4.0 46 00 00 rich +29.4 44.9 ECU. -6.6 ECU. 3.8
6138 +10.2 4.0 47 00 00 rich +27.2 42.3 ECU. -6.6 ECU. 3.6
4859 +10.4 3.7 49 00 00 16.8 +18.8 36.8 ECU. -6.6 ECU. 3.4
4374 +10.4 3.5 50 00 00 rich +19.5 32.1 ECU. -6.6 240.00 3.3
4486 +9.8 3.7 54 00 00 rich +17.7 34.4 ECU. -6.6 256.00 3.5
4591 +10.2 3.8 55 00 00 rich +14.9 35.2 ECU. -6.6 260.00 3.5
4547 +10.8 3.8 56 00 00 13.7 +15.4 26.9 ECU. -6.6 264.00 3.5
4610 +12.3 3.8 57 00 00 14.7 +15.7 28.4 ECU. -6.6 268.00 3.5
4623 +13.3 3.8 57 00 00 14.6 +16.3 29.9 ECU. -6.6 268.00 3.5
4688 +13.7 3.8 57 00 00 14.2 +15.6 27.9 ECU. -6.6 268.00 3.5
4755 +13.9 3.8 57 00 00 14.7 +14.6 29.7 ECU. -6.6 268.00 3.5
4768 +13.5 3.9 57 00 00 14.7 +14.8 30.5 ECU. -6.6 268.00 3.6
4873 +13.7 3.9 57 00 00 14.8 +16.0 31.3 ECU. -6.6 268.00 3.6
4859 +13.5 3.9 57 00 00 14.4 +16.3 27.8 ECU. -6.6 268.00 3.6
4930 +13.5 3.9 57 00 00 14.6 +18.8 33.7 ECU. -6.6 268.00 3.6
4960 +13.7 3.9 57 00 03 14.9 +18.4 31.2 ECU. -6.6 268.00 3.5
5096 +13.3 3.9 56 00 09 15.2 +18.4 34.4 ECU. -6.6 264.00 3.6
5144 +13.3 3.9 56 00 01 14.1 +20.7 30.9 ECU. -6.6 264.00 3.6
5112 +13.5 3.9 55 00 01 14.8 +21.8 32.5 ECU. -6.6 260.00 3.6
5104 +13.3 3.9 52 00 00 14.5 +20.9 33.6 ECU. -6.6 248.00 3.6
5232 +13.7 3.9 52 00 01 14.2 +21.7 33.9 ECU. -6.6 248.00 3.6
5274 +13.3 3.9 52 00 01 14.9 +21.2 32.3 ECU. -6.6 248.00 3.7
5232 +13.3 3.9 50 00 06 15.1 +19.6 33.9 ECU. -6.6 240.00 3.7
5385 +13.3 4.0 49 00 00 14.5 +19.5 33.9 ECU. -6.6 ECU. 3.7
5385 +12.9 3.9 50 00 00 15.1 +20.8 31.9 ECU. -6.6 240.00 3.6
5385 +12.9 3.9 50 00 11 14.8 +19.5 35.5 ECU. -6.6 240.00 3.6
5428 +11.9 4.0 50 00 11 14.8 +19.1 34.4 ECU. -6.6 240.00 3.7
5564 +11.6 4.0 50 00 00 14.7 +18.7 33.7 ECU. -6.6 240.00 3.7
5518 +11.4 4.0 49 00 00 14.7 +19.2 34.5 ECU. -6.6 ECU. 3.7
5574 +11.4 4.0 50 00 02 14.5 +19.3 35.4 ECU. -6.6 240.00 3.7
5707 +11.9 4.0 49 00 00 14.8 +18.9 39.1 ECU. -6.6 ECU. 3.7
5621 +11.4 4.0 49 00 00 14.9 +20.4 36.3 ECU. -6.6 ECU. 3.7
5707 +11.0 4.0 47 00 00 rich +20.9 52.0 ECU. -6.6 ECU. 3.7
5630 +11.4 3.9 46 00 00 rich +21.6 50.5 ECU. -6.6 ECU. 3.6
5747 +10.6 3.9 42 00 00 rich +22.4 53.1 ECU. -6.6 ECU. 3.6
5688 +9.6 3.8 34 00 00 rich +28.4 44.3 ECU. -6.6 ECU. 3.4
5393 +6.1 3.6 0 00 00 rich +7.6 32.0 ECU. -6.6 ECU. 3.2
5402 +0.6 3.2 0 00 00 rich +7.5 23.9 ECU. -6.6 ECU. 3.0
5411 -4.1 3.0 0 00 00 rich +7.5 19.8 ECU. -6.6 ECU. 2.7
5316 -8.8 2.8 0 00 00 rich +8.4 17.6 ECU. -6.6 ECU. 2.6
5058 -10.8 2.8 0 00 00 rich +10.5 17.6 ECU. -6.6 ECU. 2.6
4368 -11.2 2.7 0 00 00 22.7 +10.8 17.6 ECU. -6.6 ECU. 2.4
3695 -11.6 2.5 0 00 00 lean +11.2 17.6 ECU. -6.6 ECU. 2.2
3553 -11.6 2.2 0 00 00 24.2 +11.0 17.6 ECU. -6.6 ECU. 2.0
3538 -11.6 2.2 0 00 00 24.5 +11.2 17.6 ECU. -6.6 ECU. 2.0
3565 -11.6 2.2 0 00 00 lean +11.3 17.6 ECU. -6.6 ECU. 2.1
3542 -11.6 2.2 0 00 00 24.2 +11.2 17.6 ECU. -6.6 ECU. 2.1
3534 -11.8 2.2 0 00 00 24.5 +11.2 17.6 ECU. -6.6 ECU. 2.0
3472 -12.0 2.2 0 00 00 24.5 +11.3 17.6 ECU. -6.6 ECU. 2.0
3465 -12.0 2.1 0 00 00 24.5 +11.3 17.6 ECU. -6.6 ECU. 2.0
3457 -12.0 2.1 0 00 00 24.5 +11.4 17.6 ECU. -6.6 ECU. 2.0
3411 -12.0 2.1 0 00 00 24.5 +11.5 17.6 ECU. -6.6 ECU. 2.0
3422 -12.0 2.1 0 00 00 lean +11.4 17.6 ECU. -6.6 ECU. 2.0
3377 -12.0 2.1 0 00 00 lean +11.4 17.6 ECU. -6.6 ECU. 1.9
3340 -12.0 2.1 0 00 00 lean +11.3 17.6 ECU. -6.6 ECU. 1.9
3310 -12.0 2.0 0 00 00 lean +11.4 17.6 ECU. -6.6 ECU. 1.9
3264 -11.8 2.0 0 00 00 24.5 +11.4 17.6 ECU. -6.6 ECU. 1.9
3239 -12.0 2.0 0 00 00 24.2 +11.4 17.6 ECU. -6.6 ECU. 1.9
3189 -11.8 2.0 0 00 00 24.5 +11.5 17.6 ECU. -6.6 ECU. 1.9
3159 -12.0 2.0 0 00 00 24.2 +11.3 17.6 ECU. -6.6 ECU. 1.9
3095 -12.2 2.0 0 00 00 24.2 +11.5 17.6 ECU. -6.6 ECU. 1.9
3072 -12.2 2.0 0 00 00 24.5 +11.5 17.6 ECU. -6.6 ECU. 1.9
3027 -12.4 2.0 0 00 00 24.2 +11.4 17.6 ECU. -6.6 ECU. 1.9
2989 -12.2 2.0 0 00 00 24.5 +11.4 17.6 ECU. -6.6 ECU. 1.8
2955 -12.2 2.0 0 00 00 lean +11.6 17.6 ECU. -6.6 ECU. 1.8
2931 -12.2 2.0 0 00 00 24.5 +11.6 17.6 ECU. -6.6 ECU. 1.8
2858 -12.2 2.0 0 00 00 24.5 +11.5 17.6 ECU. -6.6 ECU. 1.8
2839 -12.2 1.9 0 00 00 lean +11.4 17.6 ECU. -6.6 ECU. 1.8
2805 -12.2 1.9 0 00 00 24.2 +11.6 17.6 ECU. -6.6 ECU. 1.8
2748 -12.2 1.9 0 00 00 24.5 +11.5 17.6 ECU. -6.6 ECU. 1.8
2743 -12.2 1.9 0 00 00 lean +11.7 17.6 ECU. -6.6 ECU. 1.8
2712 -12.2 1.9 0 00 00 24.0 +11.6 17.6 ECU. -6.6 ECU. 1.7
2626 -12.2 1.9 0 00 00 24.5 +11.7 17.6 ECU. -6.6 ECU. 1.8
2606 -12.2 1.9 0 00 00 24.2 +11.6 17.6 ECU. -6.6 ECU. 1.8
2568 -12.2 1.9 0 00 00 24.2 +11.6 17.6 ECU. -6.6 ECU. 1.7
2510 -12.2 1.9 0 00 00 24.0 +11.7 17.6 ECU. -6.6 ECU. 1.7
2500 -12.2 1.9 0 00 00 lean +11.7 17.6 ECU. -6.6 ECU. 1.7
2442 -12.0 1.9 0 00 00 lean +11.6 17.6 ECU. -6.6 ECU. 1.7
2392 -12.0 1.9 0 00 00 24.5 +11.7 17.6 ECU. -6.6 ECU. 1.7
2359 -12.2 1.8 0 00 00 24.5 +11.7 17.6 ECU. -6.6 ECU. 1.7
2357 -12.0 1.8 0 00 00 24.2 +11.8 17.6 ECU. -6.6 ECU. 1.7
2306 -12.0 1.8 0 00 00 24.5 +11.8 17.6 ECU. -6.6 ECU. 1.7
2287 -11.8 1.8 0 00 00 24.5 +11.8 17.6 ECU. -6.6 ECU. 1.7
2258 -11.8 1.8 0 00 00 lean +11.9 17.6 ECU. -6.6 ECU. 1.6
2222 -11.8 1.8 0 00 00 lean +11.8 17.6 ECU. -6.6 ECU. 1.6
2204 -11.8 1.8 0 00 00 24.2 +11.9 17.6 ECU. -6.6 ECU. 1.6
2167 -12.0 1.7 0 00 00 24.2 +11.8 17.6 ECU. -6.6 ECU. 1.6
2142 -12.0 1.8 0 00 00 24.2 +11.8 17.6 ECU. -6.6 ECU. 1.6
2097 -12.0 1.7 0 00 00 24.2 +11.9 17.6 ECU. -6.6 ECU. 1.6
2072 -11.8 1.7 0 00 00 24.2 +11.8 17.6 ECU. -6.6 ECU. 1.6
2048 -11.8 1.7 0 00 00 24.2 +11.9 17.6 ECU. -6.6 ECU. 1.6
Old 07-14-2006, 07:09 PM   #17
04works
Member#: 91493
2006 STi
run # 3
1581 -4.3 2.1 32 00 00 14.5 +23.4 6.0 ECU. -5.6 ECU. 2.1
1696 -3.2 2.2 33 00 00 15.1 +26.5 6.4 ECU. -6.3 ECU. 2.1
1887 -1.4 2.3 27 00 00 13.5 +30.6 7.5 ECU. -6.6 ECU. 2.2
1963 -0.6 2.3 24 00 00 14.6 +31.7 7.7 ECU. -6.6 ECU. 2.2
1985 -0.8 2.3 21 00 00 13.8 +32.2 6.7 ECU. -6.6 ECU. 2.2
1985 -0.8 2.3 21 00 00 14.5 +32.5 6.9 ECU. -6.6 ECU. 2.2
1985 -0.8 2.3 20 00 00 14.8 +32.5 8.1 ECU. -6.6 ECU. 2.2
2008 -0.6 2.4 21 00 00 14.4 +32.8 6.6 ECU. -6.6 ECU. 2.2
2017 -0.6 2.4 21 00 00 14.6 +32.9 7.0 ECU. -6.6 ECU. 2.2
2042 -0.4 2.3 21 00 00 14.8 +32.8 6.9 ECU. -6.6 ECU. 2.2
2037 -0.4 2.4 21 00 00 14.5 +33.2 7.1 ECU. -6.6 ECU. 2.2
2046 -0.2 2.4 23 00 00 12.4 +33.2 6.8 ECU. -6.6 ECU. 2.2
2057 -0.2 2.4 23 00 00 14.6 +33.3 7.0 ECU. -6.6 ECU. 2.2
2074 +0.0 2.4 23 00 00 14.9 +32.8 8.0 ECU. -6.6 ECU. 2.2
2071 +0.2 2.4 24 00 00 14.7 +33.1 8.5 ECU. -6.6 ECU. 2.2
2061 +0.2 2.4 23 00 00 14.6 +33.1 8.2 ECU. -6.6 ECU. 2.2
2066 +0.0 2.3 15 00 00 14.2 +33.2 6.0 ECU. -6.6 ECU. 2.2
1982 -0.2 2.3 14 00 00 14.4 +32.8 7.2 ECU. -6.6 ECU. 2.1
1707 -1.4 1.6 0 00 00 13.5 +8.6 4.0 ECU. -4.8 ECU. 1.3
1072 -3.7 1.8 0 00 00 rich +14.2 2.4 ECU. -4.1 ECU. 1.5
817 -5.1 2.1 13 00 00 rich +23.0 18.5 ECU. -4.1 ECU. 2.2
1312 -4.9 2.1 28 00 00 rich +18.9 3.9 ECU. -4.1 ECU. 2.1
1639 -3.4 2.2 39 00 00 15.7 +21.6 4.0 ECU. -6.3 ECU. 2.2
1913 -1.0 2.4 44 00 00 14.9 +29.6 6.6 ECU. -6.6 ECU. 2.2
2044 +0.8 2.5 44 00 00 15.5 +31.0 8.0 ECU. -6.6 ECU. 2.3
2065 +0.8 2.5 44 00 00 14.5 +31.0 8.2 ECU. -6.6 ECU. 2.2
2089 +0.8 2.5 44 00 00 14.4 +31.0 8.2 ECU. -6.6 ECU. 2.2
2117 +0.8 2.5 46 00 00 14.6 +31.0 21.9 ECU. -6.6 ECU. 2.3
2153 +1.0 2.6 60 10 00 12.8 +29.8 7.7 ECU. -6.6 230.00 2.3
2085 +1.2 2.5 63 10 00 21.4 +29.6 8.0 ECU. -6.6 232.00 2.3
2033 +1.7 2.5 66 10 00 14.8 +29.6 9.2 ECU. -6.6 240.00 2.2
2124 +1.7 2.5 70 10 00 14.6 +29.5 8.3 ECU. -6.6 250.00 2.3
2250 +1.9 2.6 71 10 00 14.9 +30.3 9.0 ECU. -6.6 252.00 2.4
2360 +1.9 2.6 72 10 00 15.1 +30.7 8.6 ECU. -6.6 252.00 2.4
2478 +2.1 2.6 72 20 00 14.8 +30.7 10.6 ECU. -6.6 254.00 2.4
2616 +2.3 2.7 72 20 00 14.6 +29.4 10.1 ECU. -6.6 359.00 2.5
2775 +2.3 2.8 72 10 00 14.7 +30.2 12.1 ECU. -6.8 356.00 2.6
2965 +2.5 2.9 57 00 00 14.7 +27.6 14.5 ECU. -6.6 221.00 2.7
3208 +2.5 3.0 50 00 00 14.2 +26.4 15.8 ECU. -6.6 240.00 2.8
3377 +2.9 3.0 49 00 00 14.5 +26.1 15.1 ECU. -6.6 ECU. 2.8
3603 +3.3 3.1 49 00 00 14.8 +27.0 17.6 ECU. -6.6 ECU. 2.9
3766 +4.1 3.2 48 00 00 15.3 +25.5 17.3 ECU. -6.6 ECU. 3.0
3183 +4.9 3.0 44 00 00 16.5 +23.8 19.9 ECU. -6.6 ECU. 2.8
3016 +5.5 3.0 44 00 00 rich +23.0 19.2 ECU. -6.6 ECU. 2.8
3011 +5.9 3.1 44 00 00 rich +21.9 18.6 ECU. -6.6 ECU. 2.8
2992 +6.1 3.1 57 00 00 rich +21.3 20.1 ECU. -6.6 ECU. 2.8
3046 +6.1 3.1 65 40 00 rich +21.1 19.4 ECU. -6.3 305.00 2.9
3089 +6.5 3.2 67 40 00 rich +20.8 20.4 ECU. -6.3 325.00 2.9
3183 +7.2 3.2 69 40 00 rich +21.1 14.7 ECU. -6.3 340.00 3.0
3242 +7.8 3.2 70 40 00 14.3 +21.0 15.2 ECU. -6.3 350.00 2.9
3303 +8.0 3.2 70 40 00 14.5 +21.0 17.3 ECU. -6.3 350.00 3.0
3422 +8.4 3.3 71 40 00 14.8 +21.4 17.0 ECU. -6.1 350.00 3.0
3479 +8.8 3.3 71 50 00 14.5 +21.1 19.6 +17.2 -5.3 353.00 3.1
3576 +9.2 3.3 75 50 00 14.3 +20.6 18.4 +17.0 -5.2 359.00 3.2
3671 +10.0 3.4 81 60 00 14.6 +20.2 18.3 +17.0 -5.1 374.00 3.3
3766 +10.8 3.5 83 60 00 14.8 +19.1 23.2 +17.1 -5.0 384.00 3.3
3898 +11.4 3.6 84 60 00 14.8 +18.0 22.4 +17.1 -5.0 386.00 3.5
4011 +12.5 3.6 87 70 00 15.0 +17.6 24.9 +17.0 -5.0 390.00 3.4
4095 +13.5 3.7 88 80 00 14.7 +16.4 28.7 +16.9 -5.0 396.00 3.5
4295 +14.9 3.8 89 90 00 14.4 +13.4 27.5 +16.0 -5.0 398.00 3.5
4415 +15.5 3.8 89 90 00 15.0 +12.3 30.1 +16.7 -5.1 398.00 3.6
4522 +16.1 3.8 89 80 00 14.9 +13.2 29.9 +17.6 -5.2 398.00 3.7
4642 +16.1 3.9 89 80 00 14.7 +13.6 31.1 +18.1 -5.2 398.00 3.7
4837 +15.5 4.0 89 80 00 14.8 +15.2 32.0 +18.5 -5.3 398.00 3.7
4967 +15.7 4.0 89 80 00 15.0 +16.9 32.9 +18.5 -5.4 398.00 3.8
5073 +15.5 4.0 88 80 00 14.5 +13.5 33.7 +18.4 -5.5 396.00 3.8
5112 +15.1 4.0 89 80 00 14.3 +13.8 34.2 +19.2 -5.5 396.00 3.8
5257 +15.1 4.1 89 80 00 14.8 +15.6 38.0 +20.0 -5.5 396.00 3.9
5420 +15.1 4.1 89 80 00 12.7 +15.4 50.7 +20.1 -5.5 396.00 3.9
5546 +15.1 4.1 88 80 00 rich +16.1 51.4 +20.5 -5.5 396.00 3.9
5659 +15.1 4.1 89 80 00 rich +16.1 53.2 +21.7 -5.5 392.00 3.9
5827 +15.1 4.2 88 70 00 rich +16.4 49.8 +22.0 -5.4 392.00 4.0
6006 +14.5 4.2 89 70 00 rich +17.4 51.4 +22.0 -5.4 396.00 4.0
6172 +14.7 4.3 88 80 00 rich +18.0 57.5 +21.6 -5.4 392.00 4.0
6253 +15.1 4.3 88 80 00 rich +18.0 58.3 +21.1 -5.4 392.00 4.0
6422 +15.3 4.3 89 80 00 rich +20.3 54.9 +21.5 -5.4 396.00 4.0
6459 +15.5 4.3 88 80 00 rich +21.0 55.6 +22.2 -5.4 392.00 4.0
6523 +14.9 4.3 89 70 00 rich +21.2 57.4 +23.0 -5.4 396.00 4.1
6693 +14.7 4.3 89 80 00 rich +21.1 60.0 +23.0 -5.4 396.00 4.0
5249 +14.3 4.1 89 70 00 13.7 +15.5 53.9 +19.8 -5.5 396.00 3.8
4681 +14.9 3.9 89 80 00 rich +14.3 47.8 +18.2 -5.2 398.00 3.6
4734 +15.5 3.9 89 90 00 rich +14.6 43.4 +18.0 -5.2 398.00 3.7
4714 +15.9 3.9 89 90 00 rich +15.4 44.4 +18.0 -5.3 398.00 3.7
4796 +16.1 3.9 90 80 00 rich +15.3 57.1 +18.2 -5.4 400.00 3.7
4649 +15.7 3.9 91 80 00 rich +14.7 59.8 +18.5 -5.2 400.00 3.8
4668 +15.5 4.0 92 80 00 rich +13.9 60.1 +18.4 -5.2 400.00 3.8
4728 +16.1 4.0 88 90 00 rich +14.8 57.8 +17.2 -5.2 396.00 3.7
4768 +16.5 4.0 79 90 00 rich +15.3 59.1 +17.0 -5.2 377.00 3.8
4775 +17.2 4.0 66 90 00 rich +15.4 60.3 +17.4 -5.2 330.00 3.7
4930 +16.7 3.9 36 00 00 rich +17.8 36.8 ECU. -6.6 ECU. 3.2
4474 +11.4 3.7 0 00 00 rich +7.6 19.2 ECU. -6.6 ECU. 3.2
4323 +5.1 3.2 0 00 00 rich +7.7 17.0 ECU. -6.6 ECU. 2.9
3862 -1.4 3.0 1 00 00 rich +13.0 20.0 ECU. -6.6 ECU. 2.6
3233 -6.9 2.2 1 00 00 rich +38.2 8.6 ECU. -6.6 ECU. 2.0
3171 -8.1 2.3 10 00 00 rich +38.8 7.9 ECU. -6.6 ECU. 2.4
3320 -6.5 2.7 20 00 00 12.7 +32.2 14.9 ECU. -6.6 ECU. 2.5
3370 -4.3 2.9 31 00 00 12.2 +30.5 71.2 ECU. -6.6 ECU. 2.7
3394 -1.8 3.0 43 00 00 rich +28.5 13.8 ECU. -6.6 ECU. 2.8
3384 +0.8 3.0 50 00 00 14.5 +26.3 12.7 ECU. -6.6 240.00 2.8
3425 +2.3 3.1 51 00 00 15.2 +26.7 16.8 ECU. -6.6 246.00 2.9
3457 +3.5 3.2 50 00 00 14.5 +25.7 16.9 ECU. -6.6 240.00 2.9
3461 +4.9 3.2 50 00 00 14.5 +24.9 16.2 ECU. -6.6 240.00 3.0
3497 +5.9 3.2 50 00 00 14.9 +23.8 16.2 ECU. -6.6 240.00 3.0
3538 +6.8 3.3 50 00 00 14.4 +23.1 18.5 ECU. -6.6 240.00 3.1
3561 +8.0 3.3 49 00 00 14.8 +22.4 19.1 ECU. -6.6 ECU. 3.1
3607 +9.2 3.3 44 00 00 14.7 +22.2 18.2 ECU. -6.6 ECU. 3.1
3642 +10.0 3.3 40 00 00 14.8 +22.5 16.5 ECU. -6.6 ECU. 3.1
3639 +10.6 3.2 37 00 00 15.0 +24.6 18.7 ECU. -6.6 ECU. 3.0
3639 +10.4 3.2 38 00 00 14.8 +25.3 18.9 ECU. -6.6 ECU. 3.0
3631 +10.2 3.3 55 00 00 14.8 +24.5 20.6 ECU. -6.6 270.00 3.0
3631 +10.0 3.3 62 50 00 13.8 +21.7 20.2 +17.0 -5.1 310.00 3.2
3667 +10.0 3.4 62 50 00 14.4 +20.2 20.4 +17.0 -5.1 310.00 3.3
3671 +10.8 3.5 70 60 00 14.7 +19.3 ---.- +16.9 -5.1 350.00 3.3
3753 +11.4 3.6 73 70 00 rich +18.1 31.2 +16.9 -5.0 359.00 3.4
3787 +12.7 3.6 75 70 00 rich +16.6 31.4 +16.4 -5.0 365.00 3.4
3787 +13.9 3.6 62 80 00 rich +17.0 25.5 +16.0 -5.0 310.00 3.4
3663 +13.5 3.2 14 00 00 12.9 +22.9 17.9 ECU. -6.6 ECU. 1.8
3336 +9.0 3.4 0 00 00 rich +17.1 15.6 ECU. -6.6 ECU. 3.0
3316 +3.1 3.1 0 00 00 rich +11.7 15.6 ECU. -6.6 ECU. 2.8
3229 -3.2 2.8 0 00 00 18.6 +8.5 15.6 ECU. -6.6 ECU. 2.6
3217 -9.0 2.7 0 00 00 lean +8.5 15.6 ECU. -6.6 ECU. 2.4
3205 -10.6 2.6 0 00 00 24.0 +8.5 15.6 ECU. -6.6 ECU. 2.3
3150 -11.4 2.5 0 00 00 24.2 +8.6 15.6 ECU. -6.6 ECU. 2.2
3126 -11.8 2.2 0 00 00 24.5 +11.5 15.6 ECU. -6.6 ECU. 2.1
3083 -11.8 2.2 0 00 00 24.5 +11.5 15.6 ECU. -6.6 ECU. 2.1
3103 -11.8 2.2 0 00 00 24.2 +11.4 15.6 ECU. -6.6 ECU. 2.1
3024 -12.0 2.2 0 00 00 24.5 +11.4 15.6 ECU. -6.6 ECU. 2.0
2984 -12.0 2.2 0 00 00 24.2 +11.5 15.6 ECU. -6.6 ECU. 2.0
2918 -12.2 2.1 0 00 00 24.2 +11.5 15.6 ECU. -6.6 ECU. 2.0
2901 -12.2 2.1 0 00 00 24.2 +11.5 15.6 ECU. -6.6 ECU. 2.0
2873 -12.2 2.1 0 00 00 24.2 +11.5 15.6 ECU. -6.6 ECU. 1.9
2815 -12.2 2.1 0 00 00 24.2 +11.5 15.6 ECU. -6.6 ECU. 1.9
2782 -12.2 2.1 0 00 00 lean +11.5 15.6 ECU. -6.6 ECU. 1.9
Old 07-14-2006, 07:11 PM   #18
04works
Member#: 91493
2006 STi
any help would be great, thanks
Old 07-14-2006, 08:14 PM   #19
hippy
Member#: 36528
2002 Impreza Wrx
Code:
Lean running you are. Blow engine you will. Open loop fueling you need, but use cannot. Reflash get you.
Old 07-14-2006, 08:33 PM   #20
04works
Member#: 91493
2006 STi
Code:
i think that was part of the log after my car took a crap, so i took my foot off the gas and coasted through?
Old 07-14-2006, 11:39 PM   #21
hippy
Member#: 36528
2002 Impreza Wrx
It doesn't matter when the engine breaks if it breaks. If I was you, I'd look into a reflash. This might not be what's causing your problems, but if you keep ignoring your cel light it will probably be a problem sooner or later. Not that this is what's causing the hesitation(except for when there's knock), but it can't be helpin. Ya might wanna check your spark plugs cause I hear knock can change the gap.
I dunno what to tell ya about the car not wantin to move though. I've heard that's why you can't use olf with automatics, but if your open loop fueling is tuned off........
peace
Old 07-15-2006, 08:52 AM   #22
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You don't seem to ever go wide open either.
Old 07-16-2006, 08:49 PM   #23
04works
Member#: 91493
2006 STi
thats usually because after i get on it, the car takes a crap on the run, i get chicken and back off, sometimes i even try to race it again half way down the track to see if any different results, but none, it still takes a crap???
Old 07-16-2006, 08:54 PM   #24
04works
Member#: 91493
2006 STi
not sure if this matters with my overall problem, but i am running a map for a Stage 4 FMIC closed loop basemap that i got from www.projectwrx.com all i have done is mess w/ the boost to hit target boost. a freind helped me w/ setting up everything else. would a brand new professional tune and map help substancably? thanks again
Old 07-16-2006, 08:55 PM   #25
hippy
Member#: 36528
2002 Impreza Wrx
Does it feel like your tranny is the problem, or is the engine taking a crap? Does the cel flash when it happens?
Utec with Automatic trymyrex21 Engine Management & Tuning 3 04-12-2005 08:07 PM
New Forester owner here noticing some nuances .. something wrong? lupohki Forester Forum 5 05-04-2001 10:36 AM
Chat - Am I doing something wrong? Mike Smith Tri-State Area Forum 5 01-31-2001 10:25 AM
Trying to install TEINs, is something wrong here??? Help!!! Andrew Technical Forum Archive 7 10-03-2000 10:19 AM
Hey, Idiot, there is something wrong with the car... RandyF North West Impreza Club Forum -- NWIC 4 07-13-2000 01:59 PM
