Old 06-29-2006, 09:48 PM   #1
SatanasoSTI
Member#: 96396
2005 STI
Default Anti-lag Map question ?
Can someone make a map (AP) for anti-lag be nice if we ca use it I love the sound the rally cars make.
SatanasoSTI is offline   Reply With Quote
Old 06-29-2006, 10:41 PM   #2
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
how often can you afford to replace your turbo? that said i use FFS and LC on my utec, and both are great fun...
shikataganai is offline   Reply With Quote
Old 06-29-2006, 11:15 PM   #3
JoshP
Member#: 94350
sure ill get right on it
JoshP is offline   Reply With Quote
Old 06-29-2006, 11:22 PM   #4
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
mabe a little harsh, but I'm sure he just wants an example, but I doubt anyone has one.
Sko is offline   Reply With Quote
Old 06-30-2006, 01:06 PM   #5
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
AP does not support this functionality. Currently you'd have to go standalone or Utec for that.
Drac9 is offline   Reply With Quote
Old 07-01-2006, 12:03 AM   #6
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Impreza WRX STi
My PDX maps are almost lag free. .about the best youll find. Other than that. . get an NA motor.
ADR 04STi is offline   Reply With Quote
Old 07-01-2006, 05:05 AM   #7
koochman
Member#: 108407
16 WRX Limited
Pure Red
ADR do you understand what anti-lag is?
koochman is offline   Reply With Quote
Old 07-20-2006, 12:15 PM   #8
thejean
Member#: 17763
Satanaso, I am looking into this option as well.
thejean is offline   Reply With Quote
Old 07-20-2006, 01:25 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
If it was as easy as using a certain map, everyone would do it(or maybe I'm missing something and you already knew this?). At the least, you'd probably need to have the throttle body open a given amount(more then normal at no throttle) at all times. Running boost all the time would wear parts, and use gas like it was nothing.
peace
Old 07-20-2006, 01:53 PM   #10
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
and, rally cars have an anti-lag system, not mearly a map. It is complicated but yeah, kills turbos.
Leonardo is offline   Reply With Quote
Old 07-21-2006, 12:56 AM   #11
Gethin
Member#: 2998
You guys REALLY need to read up on ALS. So much misleading info in this thread.
And, yes, ALS can be done with a map and a turn of a screw.
G.
Gethin is offline   Reply With Quote
Old 07-21-2006, 02:13 AM   #12
TheBlackRex
Member#: 101090
2002 WRX w/ VF39
Midnight Black
Anti Lag systems create and explosion in or just after the turbo. This creates a high velocity of gas that spins the turbo (even if past becuase gases are sucked into the explosion). They do this using injectors and/or a spark plug to ignite gases in the exhaust track. Think of it as turning a turbo into a rotary motor. The turbo won't last that long.
In a map they might run the car so rich that extra fuel explodes when it hits the turbo, but this is not a true anti-lag system and can be more destructive.
TheBlackRex is offline   Reply With Quote
Old 07-21-2006, 03:05 AM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
why does it kill the turbo exactly? kills the bearings?
Old 07-21-2006, 11:04 AM   #14
thejean
Member#: 17763
Big time heat.
Old 09-06-2006, 01:18 PM   #15
thejean
Member#: 17763
G.
I got the map part figured out but what screw are we talking about? Idle control valve or throttle body plate?
Old 09-06-2006, 01:54 PM   #16
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
I found some good info on ALS
http://www.rallycars.com/Cars/bangbang.html
fishheadback is offline   Reply With Quote
Old 09-06-2006, 02:16 PM   #17
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
ALS does NOT KILL TURBOS. Why this keeps propogating is beyond me.
cdvma is offline   Reply With Quote
Old 09-06-2006, 03:24 PM   #18
thejean
Member#: 17763
Mild ALS perhaps. Very agressive ALS can be much harder on a turbo though. What I am most concerned about is my EGT probe blowing apart and flying through the turbo. I am catless as well so no worries there.
Old 09-06-2006, 03:39 PM   #19
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I don't know what you consider mild or agressive but I know of at least one privateer Group N rally team that uses ALS and doesn't chew their VF turbos. Used two turbos in a season because the first was burnt when an oil line came off. I believe there is also more cast iron manifolds cracked than turbos blown from ALS. Certain turbos can take inlet temps very well (IHI comes to mind) while others are good at running without a pressure relief valve so some are cut out for ALS more than others.
Old 09-06-2006, 03:50 PM   #20
thejean
Member#: 17763
I agree, ALS success depends largely on the turbo design as well as the agressiveness of the programming (i.e., boosting to 1 psi off throttle vs say 20 psi or something like that).
Related question... what idle speed would result in the throttle body being about 25% open on a stock EJ20?
Old 09-06-2006, 04:02 PM   #21
EarlQHan
Member#: 90215
I was talking to one of the VSC guys when Travis Pastrana was at SOS a few weeks ago. They said, even with the anti-lag, their turbos last a whole season as they are tuned more for reliability than peak performance. So I figure a mild ALS set up that can be turned on and off would lead to a decent turbo lifespan.
EarlQHan is offline   Reply With Quote
Old 09-06-2006, 04:30 PM   #22
hippy
Member#: 36528
2002 Impreza Wrx
They also use turbos which might cost 5 times more then turbos we use, and are ment to handle the abuse. There are many things people might not think about when they're conceptualizing antilag systems, and many of them can be bad for the longevity of parts. I'm no expert on antilag systesm(I'm a big newbie actually), but one thing that comes to mind is compressor surge. Just a random thought I guess.
peace
Old 09-06-2006, 05:28 PM   #23
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
About 4,000rpm
PaulRex is offline   Reply With Quote
Old 09-06-2006, 06:08 PM   #24
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Originally Posted by PaulRex View Post
About 4,000rpm
No way in hell. Put your foot down on the gas 1/4th of the way in neutral and you will see it bounce redline since there is no load on the engine.
powerlabs is offline   Reply With Quote
Old 09-06-2006, 06:26 PM   #25
thejean
Member#: 17763
Yikes, that seems a little high. I wonder if I can get away with less...
Who else wants Anti-Lag map? neverendingmods AccessPort 17 08-13-2007 09:02 PM
Serious Anti-Lag questions, rotary idle, materials, turbo? LqSilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-06-2006 03:30 PM
Flashing Anti-theft map question chlnOrSlpn? AccessPort 2 03-17-2006 02:04 AM
Serious Anti-Lag questions, rotary idle, materials, turbo? LqSilver Engine Management & Tuning 0 03-02-2005 12:44 AM
anti-lag maps........ shortfuseWRX Engine Management & Tuning 10 12-19-2003 01:14 PM
