Old 06-30-2006, 08:56 AM   #1
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Default AP help, please
My first thread "Should I Flash?" was straying from the point, and losing replies due to that. Sooo:
Low Voltage Error; part2: I tried flashing, didn't work. I attached jumper cables from my friend's car to my car; didnt work. I tried NOT turning off and flashing, and that yielded another error and said to try again. So I've tried everything. Cobb said maybe a new battery, but if I had jumper cables, a battery shouldnt be the problem. I had everything else off on the car, even e-brake so that light wouldnt come on, and still nothing. I'm thinking it's a problem with the DiagPort cable, and will call Cobb soon.
Is it safe to flash with the AP plugged into the AC wall charger?
C/N: Low voltage error no matter what I do. Can I plug AP into the wall charger (ac adapter) and flash?
ErasureWRX is offline   Reply With Quote
Old 06-30-2006, 09:15 AM   #2
Mr Nice Guy
Member#: 107224
2005 M3
Imola Red
I wouldn't risk using AC power when you flash unless it's on a UPS (if you can even do it that way) all it takes is a power outage or surge and possibly bye bye to your ECU. That happens around here in Central FL way too much for me to risk it. Don't know about where you live though. Just something to think about. I would call Cobb if you are having problems they really helped me out when the screen on my AP went bad. Very good people there. Good Luck.
Mr Nice Guy is offline   Reply With Quote
Old 06-30-2006, 09:24 AM   #3
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I'm in a very rural area of No.Va, and I don't think there's too many power surges/outages, but one can never be too careful. I guess my only logical next step should be calling them.
thanks!
Old 06-30-2006, 10:07 AM   #4
Mr Nice Guy
Member#: 107224
2005 M3
Imola Red
You can also use a Battery charger during programming. Some issue if power was lost but not as much I think since the battery would act as a buffer unless it's really low.
Old 06-30-2006, 10:09 AM   #5
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
So I can use the wall charger for flashing?
Old 06-30-2006, 10:29 AM   #6
Mr Nice Guy
Member#: 107224
2005 M3
Imola Red
No the AC adapter included w/ AP is not a battery charger. AP dosen't have a battery in it. I was referring to a Car battery charger hooked up to your WRX's battery while programming to supply the extra needed voltage if your batt is a little low. Also not a bad safety precaution if your battery isn't pretty new. You don't want it dying halfway through the programming. Good luck
Old 06-30-2006, 10:45 AM   #7
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I tried jumper cables, which should have the same effect, right?
Old 06-30-2006, 11:29 AM   #8
Mr Nice Guy
Member#: 107224
2005 M3
Imola Red
Jumper cables have high resistance since they are so long and use the alligator clips on both ends. You would at least have to have the other car running the whole time to even help at all. Even if you can get enough voltage through them you would have power that could fluctuate with engine RPM, accesories turning on etc. A battery charger would provide a much more stable supply of power. If you don't have one you could try going to a local auto parts store like AutoZone and have them test your battery. They'll even charge it for you for free. If it's on it's way out that may be your problem. Then just pick up a new one and you should be good to go. Hope this helps. Good Luck!
Old 06-30-2006, 01:31 PM   #9
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
It might be my battery. I don't know how long I've had it, could be the stock one , and it's a Duralast .
Thanks! Cobb didn't say why the jumper cables wouldn't work, so thanks for the explanation.
Old 06-30-2006, 01:44 PM   #10
johsti
Member#: 36049
2014 FXT Premium
Is your car even going into "test mode"? You haven't clarified that in your posts yet, unless I missed it. It is obvious when it is in test mode, because you will hear the fans/pumps cycling intermittently.
johsti is offline   Reply With Quote
Old 06-30-2006, 01:46 PM   #11
johsti
Member#: 36049
2014 FXT Premium
Also, most people that receive the "low voltage error" has nothing to do with the battery.
edit - ok, for some people it has nothing to do with the battery.
Old 06-30-2006, 02:17 PM   #12
subywrx
Member#: 81858
johsti - i read the owners manual online but i don't see where it states you have to charge the ap with the power adaptor. When should you charge the ap or how do you know it need charging?
subywrx is offline   Reply With Quote
Old 06-30-2006, 02:31 PM   #13
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
It goes into test mode, yes. Sorry for not making that clear
Old 06-30-2006, 05:35 PM   #14
johsti
Member#: 36049
2014 FXT Premium
I don't recall ever saying anything about the power adaptor or charging the AP.
If you're asking me if you need to charge it, the answer is no. Like someone else mentioned, the AP has no battery. You only need the power adaptor for when you sync the AP with your computer.
Old 06-30-2006, 05:49 PM   #15
subywrx
Member#: 81858
Thanks johsti
Old 07-02-2006, 10:54 AM   #16
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I attached a battery charger to my battery, charged it for about 3 hours, it said it was at full charge, then tried it, unsuccessful. I guess my car battery is on the way out?
Old 01-13-2007, 02:50 PM   #17
nomex ninja
Member#: 108222
2002 WRX stage-x
Midnight Black Pearl
Im having this same problem. I have tried all of the steps previously mentioned in this thread with no sucess. My car is going into test mode.
Any more info on this problem would be cool. - Enrico
nomex ninja is offline   Reply With Quote
Old 01-13-2007, 03:18 PM   #18
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Some people seem to be having problems with the under dash connectors/innit connectors... Make shure they snap in good... Also some OBD2 cabled seem to be faulty. See if you can borrow one...
wrxdrvr is offline   Reply With Quote
Old 01-14-2007, 03:35 PM   #19
nomex ninja
Member#: 108222
2002 WRX stage-x
^^^ thanks alot dude^^^
I was the connector
AP help please! 801_STi Rocky Mountains Impreza Club Forum -- RMIC 4 03-09-2009 01:18 AM
ap help please snobord1986 AccessPort 3 09-13-2007 03:19 PM
ap help-please! 02ej20 Engine Management & Tuning 6 12-29-2005 04:30 PM
AP help please brex16 Engine Management & Tuning 3 07-28-2005 11:51 PM
IL: for the people with AP, HELP please ms3p Mid West Subaru Owners Club Forum -- MWSOC 5 10-22-2004 12:19 PM
