Old 10-18-2001, 01:19 AM   #1
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Question low compression pistons?
Thinking about turboing an '02 2.5 TS, but it seems the weak point of forced-induction 2.5's is the pistons... anyone know of lower compression 2.5 liter pistons and how much? thanks!
SoobATV is offline   Reply With Quote
Old 10-18-2001, 01:21 AM   #2
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
Kcz is offline   Reply With Quote
Old 10-18-2001, 01:44 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
The week point of Turboed EJ25s is Engine Management. Mostly when people have to little or none.
However for absolute maximum power output a good solid set of low compression pistons are in order. If you have been following Shivs Project Impreza in Sport Compact Car, you will know that you can get plenty of power out of fully stock internals by properly tuning literally everything through good engine management.
I am anxious to see what they will do next with the car. It seems like they have pushed it as far as it will go on stock internals. What will they do next?
If you really want lower compression pistons I think ISR Performance could help you out. They also carry forged rods and stuff like that for other internal strengthening. How about a Forged Crank, Closed Deck Block, Forged Con Rods, Ported and Polished Cylinder Heads with Turbo Cams, New Rockers, and a Bored Throttle Body. That would really help make some massive power too.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 10-18-2001, 04:03 PM   #4
outback motorsports
Member#: 4084
Default rods and pistons
we carry 6 diff. piston configs for 2.5 depending on head style.h-beam rods arp 2000 bolts $525 per set.give us a call see ya steve 714 994 5222
outback motorsports is offline   Reply With Quote
Low compression pistons for a ej25d smahala1286 Subaru Conversions 1 12-29-2005 10:51 AM
Low compression pistons IMPEZER22 Private 'Wanted' Classifieds 2 06-03-2005 05:08 PM
Low compression pistons for ej25 AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 5 02-03-2004 07:05 PM
what to buy? low compression pistons or short block? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-10-2002 11:31 AM
a 450hp turbo w/ low-compression pistons?? what happens to the power??? FuJi K Normally Aspirated Powertrain 7 03-06-2001 08:22 AM
