Old 07-01-2006, 05:58 AM   #1
trippen-wagon
Member#: 85086
Default AP FP16G low boost
ok so i have a 02 wrx wagon 4eat
AP FP16G MT map
FP16G
STI injectors
fuel pump
i did every thing the map notes said to do with this install exept the sti intercooler which i plan on doing
now i'm only geting 12-14 psi and some times 16 in 4th gear
and yes the resrictor pill is in the right place
i've check to make sure every thing is tight like three times
i've put over 300 miles on the map to see if it will learn and still no change
talked with COBB and they suggested shortening the waste gate arm and i did, and kept doing it tell it couldn't go any more which i think is crazy because i see no reason why it should have to be crancked all the way down, still no change
i don't know were to go from here
would the intercooler cause this or maybe bad injectors
can bad injectors even cause low boost
they are sti injectors like the map says to use
i have searched every were for a week
some one please help
also i know the map says gp16g mt, but i talked with COBB about useing the map on a 4eat and they said its fine
trippen-wagon is offline   Reply With Quote
AP fp16g low boost trippen-wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-01-2006 02:09 PM
Low Boost in STI with AP? Poppa smurf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-21-2004 01:56 AM
Cobb AP STG1 Low Boost? Sperm Engine Management & Tuning 13 10-15-2004 09:35 AM
Well the Cobb Ap didn't solve it. High temp/low boost Valhakar Engine Management & Tuning 9 09-30-2004 10:09 AM
AP and low boost WrxWonderWagon Engine Management & Tuning 7 09-26-2004 10:01 PM
