Old 10-18-2001, 09:20 AM   #1
Nick
The Godfather
Member#: 2
2015 STI Launch Ed.
Rally Blue Pearl
Talking How TO Turbo your car!
Well I've got some very good news.
For those that don't know... I have a 99RS with a Minnam Turbo and Vishnu Performance TEC-II and all the goodies that go along with it.
I just went to the dealer for my 30K service the other day. I found a really good Subaru Tech at one of the dealerships down here. Anyway... he went over the whole car.
Most important bits of info:
The transmission fluid (never been changed before) was fine... nearly (meaning 1 or 2 specs) no metal on the magnetic plug.
The compressions was just fine.
#1 - 190psi
#2 - 195psi
#3 - 190psi
#4 - 200psi
Which means in order of how the cylinders were getting abused pre-vishnu fuel rails is correct.
The pressure drops slightly in the path the cylinders get fed which is 4,2,1,3. (200, 195, 190, 190)
But I think my engine as just over 21K TEC-II turbo'd miles is living proof that if you set your system up correctly the car can, and will, last a very long time.
-Nick
P.S. Watch my car not start now when I leave work!
Nick is offline   Reply With Quote
Old 10-18-2001, 10:17 AM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
congrats, I hope to have similar luck, albeit without the TECII system. How much boost do you run?
STiShawn is offline   Reply With Quote
Old 10-18-2001, 10:55 AM   #3
MPREZYA
SCIC
Member#: 85
Nick a real test would be a leak down not a Compression test .
MPREZYA is offline   Reply With Quote
Old 10-18-2001, 11:17 AM   #4
RS'ted
Member#: 3234
Glad to hear it, Nick ! I've been tempted to make a similar post lately, just 'cause I'm so pleased with the way my car is running and how absolutely reliable it has been. I've got the same setup you do, running 10 psi on my '00. I average ~100 miles per day in my car and just passed the 46k mile mark, 27k with a turbo. My compression tests the same as yours, between 193 and 205 on all cylinders. The amazing thing is the "better than stock" driveability. Installing the Wintec2 chip made things so much easier for me due to the auto-tune feature. Just pick an A/F ratio target and drive The weather has gotten quite cold here a few times recently and it has run flawlessly whether the temperature is 30 degrees or 90 degrees. I'm totally satisfied with this car.........well, maybe a little better choice of gear ratios and a limited slip front diff would be nice
Ken M
RS'ted is offline   Reply With Quote
Old 10-18-2001, 11:26 AM   #5
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
No, it's not a WRX...
Nick-
That's great to read...somebody actually bragging about turbo reliability. Couple questions: How much boost are you running? How often do you drive the car hard and really engage the system?
Thanks.
MINDGAME is offline   Reply With Quote
Old 10-18-2001, 11:43 AM   #6
efoo
Member#: 80
17K turboed miles and counting. Of course, now that I've said this, my motor will mysteriously self-destruct as soon as I start it this evening too.
MY99 2.5RS, 7psi, TEC-II, dyno verified 230hp, 245ft/lb at the wheels
oh yeah, 26mpg highway, 20mpg city. I need to work on that though. Shiv is claiming he gets 30mpg highway! Hm.
-Edwin
efoo is offline   Reply With Quote
Old 10-18-2001, 12:36 PM   #7
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I have almost 40k turbocharged miles. 30k on the last motor and about 10k on this one. It's only fair to mention that the last motor had over 150k when it went out.
5psi, no engine management and spiking boost way too much on the first motor.
For motor #2, there's a better up pipe, resolved the boost spike with a deltagate wastegate, intercooler, and still need to hook up the Field SFC.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-18-2001, 01:07 PM   #8
shiv
Member#: 607
Just set your AFR targets during cruise conditions to 17:1. The TEC-II's AFR bar graph (in the engine monitor screen) won't go back and forth rich/lean anymore. It will stay on the first two or three "LEDS" instead. It's a lean burn engine so treat it like one Keep advance during these conditions in 35-45 degree range (between 2500 and 4000rpm-- more rpm the more advance)
Just make sure that the car goes rich and less advanced as you transition to heavier load (maybe above 85kPa or so)
And then keep your foot out of the gas until the next fill-up!
Cheers,
shiv
shiv is offline   Reply With Quote
Old 10-18-2001, 01:13 PM   #9
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
Shiv-
Is it true that you won't be making anymore complete 2.5 turbo kits after this first group buy you are organizing? I was planning on purchasing one from you (with electronics), but didn't want to move on it until after the ski-season. Will you have availability in the Springtime? How 'bout plans for a kit running a TEC-III next year?
Thanks.
Old 10-18-2001, 02:27 PM   #10
cvcsmkr
Member#: 10465
91 Syclone
Only 1 color
hey nick,
i am down here in florida with you. and i am looking for a good tech for the unexpected problems i might have after my turbo. anyways, which dealership is he at and whats his name. appreciate it.....cvcsmkr
cvcsmkr is offline   Reply With Quote
Old 10-18-2001, 03:57 PM   #11
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation
Nick don't send cvcsmkr to Cartech...they suck, do sloppy work and rip you off
10K turbo miles in this car 212K in original car...1.8L ECU, 1.8L tranny, runs rich, but the motor is SO strong & smooth
Scoobyslack1 is offline   Reply With Quote
Old 10-18-2001, 04:34 PM   #12
Nick
The Godfather
Member#: 2
2015 STI Launch Ed.
Rally Blue Pearl
I'm running about 9.5 psi on a daily driver.
I only put about 30-50 miles a day on the car... and a portion is moderate traffic so the car sees a decent amount of stop and go.
I don't really push the limits of the car to often, but I'm no stranger to WOT. I DO NOT baby the car either. But it sees no track use though.
It's just nice not to have to drive the car WOT or 1/4 throttle about 90% of the time. The car has gobs of power pretty much all through the range.
Don't worry ScoobySlack I wasn't talking about CarTek. I was talking about this guy Tim (the only Subaru tech) at the Delray Beach Subaru Service Department. He's old school subaru and he's from Canada. So you gotta trust him, eh?
I don't like there warranty/service manager though... woman who is a PITA. Next time she gives me lip for staying with the car in the service bay I think it will be time to get her business card and make a few calls to SOA.
-Nick
Old 10-18-2001, 04:58 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
#1 - 190psi
#2 - 195psi
#3 - 190psi
#4 - 200psi
Why does that seem so high to me? Not that high is a bad thing, but... hmmmmm...
The specs on a MY00/01 with 10:1 compression is 165-180psi for compression tests, but you've got a MY99 that is 9.7:1 pushing around 190-200psi. Thats either a hell of a fluke (and a damn good short block to start with) or I'm mistaken.
Well damn... congrats, Nick! I wish my motor was in anywhere near as good shape as yours!
Old 10-18-2001, 05:21 PM   #14
shiv
Member#: 607
Compression specs in the workshop manual are always lower than what they really are in the field. Probably because the OEMs want to keep people from making warranty claims until things are seriously bad. From what I've seen, normal MY99 numbers are 185-200psi. Normal MY00 are ~5-10psi higher. Of course, a lot depends on the kind of gauge you use and at what altitude you are at. Also, depends on how hot the engine/oil/etc,. is.
Cheers,
shiv
Old 10-18-2001, 06:57 PM   #15
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
that and the starter spins the engine at a faster RPM than is specified in the FSM for the compression test. higher RPM = higher compression reading.
ColinL is offline   Reply With Quote
Old 10-18-2001, 09:49 PM   #16
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Tuning...tuning
Awe, it's all in the tuning. Not everyone's engine blew up. Remember 59k-110k of turbo/nitrous power. Woohoo!
Congrats Nick! That's impressive man. I hope everyone has just as much tuning prowess as you. I've always wanted a Tech II. *sigh* Still do! $$$ is running to low though.
Kevin Thomas is offline   Reply With Quote
Old 10-18-2001, 10:15 PM   #17
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
I hear shiv is working out a deal so that he can take Visa, Mastercard, and souls... now you can sell your soul for a Tec-II and Vishnu Turbo Kit!
iodine23 is offline   Reply With Quote
Old 10-18-2001, 11:25 PM   #18
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Great to see a thread like this.
You have offically returned the plans of a Turbo to my cars future.
Cost wise, Staying NA was going to be just as expensive as doing the turbo and engine managment correctly.
YAY !! I can go back to my turbo dreams
Cheers,
_chris
WRSport is offline   Reply With Quote
Old 10-18-2001, 11:30 PM   #19
RS-LOVER
Member#: 4463
2000 Impreza RS
Blue Ridge Pearl
Talking
I will sell my soul for a Vishnu turbo kit! J/K But I'm still wishing for one thats for sure. I hope they will be still for sale around spring time. Then I will be one of the Vishnu crew!
RS-LOVER is offline   Reply With Quote
Old 10-18-2001, 11:58 PM   #20
kaos200
Member#: 2692
SHIV, if you see this you have email
kaos200 is offline   Reply With Quote
Old 10-19-2001, 12:24 AM   #21
WRSport
Member#: 2060
00 2.5RS Coupe
I second Rovers request for a happy springtime Vishnu turbo kit part #2. No need for special prices. Just a chance at picking up the new kit.
Even if shiv's saying no more, we can all count on SHIV to come through, right? Afterall, he said he would offer a kit, and wholla, some lucky individuals are now drooling once again in anticipation of the new kits. Vishnu performance allways comes through so why would anything change, right
You dont have to promise, but at least let us hope Shiv that ya might change your mind.
Cheers,
_Vishnu Turbo in 2002
Old 10-19-2001, 12:27 AM   #22
Andrew
Member#: 1170
2005 STi
too....tempting......
Andrew is offline   Reply With Quote
Old 10-19-2001, 01:10 AM   #23
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
be neat to compile a list of RS-t s and their status currently...
ie leak down adn compressions... and quarter mile times and other details... maybe Kevin Thomas? since you already have that 1/4 mile time... hehe just be interesting... to see different setups and such...
Hok
HOK is offline   Reply With Quote
Old 10-19-2001, 02:30 AM   #24
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
[don't mind the tangent, guys ]
shiv - Doesn't that seem strange to you, though? I mean, you're a numbers guy... if you're starting with atm in the cylinder, compress it 10x, wouldn't you end up with (10*atm)-atm ~132psi?
But then, looking at it again theoretically, aren't you even lower then that since the cylinder needs to create a vacuum to pull in a full cylinder's worth of air and the valve probably actually closes before it gets to atm within the cylinder, or even possibly the valve stays open for a small amount of the compression stroke?
Seems to me that a motor that compression tests to 175psi would, by those theories, be running about 12.9:1 compression.... *shrug* Most likely I'm missing something, but I can't figure out what.
Old 10-19-2001, 02:42 AM   #25
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Atmospheric pressure at sea level is 14.7psi.
Ben
bsquare is offline   Reply With Quote
How to make your car faster and reduce the stress on your transmission Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 04-13-2011 01:29 PM
How not to turbo your car. Danny5 Normally Aspirated with bolt-on Forced Induction Powertrain 175 09-26-2003 09:37 AM
Where to learn how to tune your car acss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-16-2002 09:23 PM
How to 'Chips' your car toerag Interior & Exterior Modification 7 11-28-2001 10:56 AM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 05:34 PM
