Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 12-20-2013, 04:37 PM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Smile Turbo blankets don't like heat? (pics)
Pulled out my motor, started taking off the blanket and it just felt apart to million pieces in my hands
so what's a good blanket that lasts?
Hyper is online now   Reply With Quote
Old 12-20-2013, 04:48 PM   #2
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
I guess that is the DEI one?
http://designengineering.com/categor...rbo-shield-kit
"This shield is not designed to be removed after it has been through heat cycles. After the fibers have been heated they lose their initial flexibility. This does not reduce the thermal properties of the shield. Be aware of this before you decide to remove the shield."
No Limit Motorsport is offline   Reply With Quote
Old 12-20-2013, 04:51 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
oops
I am still surprised the holding material got torn/melted
Old 12-20-2013, 10:05 PM   #4
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
the turbo blanket I have had for years and removed and reinstalled a lot of times was purchased years ago from boost logic.
john 1badSTI is offline   Reply With Quote
Old 12-20-2013, 10:09 PM   #5
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
ptp turbo blanket. mines been on for 3 years and looks like new still.
http://www.ptpturboblankets.com/
Old 12-21-2013, 01:40 AM   #6
LOGMEISTERFLEX
Member#: 318274
2004 WRX Wagon
^^ I second for ptp, have the lava and it works great
LOGMEISTERFLEX is offline   Reply With Quote
Old 12-21-2013, 03:03 AM   #7
mitch808
Member#: 10228
2002 Subaru WRX
Heat does a number on the insulation. Take it on/off and heat cycle it a few hundred times, don't expect it to last.
Its expected to replace them at some point, as it will wear overtime. But if you never remove it, many will never notice its disintegrating.
mitch808 is offline   Reply With Quote
Old 12-21-2013, 10:46 AM   #8
sidewayz
Member#: 5810
2001 S366 2.5RS
I have never seen any of the diapers hold up... PTP full blankets are amazing tho
sidewayz is offline   Reply With Quote
Old 12-21-2013, 03:12 PM   #9
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
placed an order on ptp
thanks for the tip
Old 12-22-2013, 09:25 AM   #10
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
How many times have you removed it? You won't notice until you do. My PTP lava blanket tie wire buttons pulled right off after some serious heat cycling and the material is definitely more brittle and friable. It's all spelled out in the PTP instructions. Many heat cycles = dead blanket if you removed it often.
