Old 07-02-2006, 06:36 PM   #26
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Originally Posted by 8Complex
Side note: You could always tweak the dyno correction factors to help out. Talk to Crawford, they know how to do it.
-- Dave
AcquaCow is offline   Reply With Quote
Old 07-02-2006, 06:56 PM   #27
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Why one huge turbo? Twin GT35r will make 1000whp. I like the 3.0l idea with titanium rods/pins and heads to rev to 10k... All realistic. Dry sump it so oil wont be an issue. I can see 50k in just the engine.
Scoobie Steve is offline   Reply With Quote
Old 07-02-2006, 07:18 PM   #28
EnterTheDragon
Member#: 6511
Why would anyone even consider a Subaru for that much power?
EnterTheDragon is offline   Reply With Quote
Old 07-02-2006, 11:03 PM   #29
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Originally Posted by renegade_
What kind of engine would he be running @ 12,000 RPM? He would have to run an all forged engine, and even then, would a 2.5L engine really be able to handle that kind of output? I mean, AE86 1.6L race prepped engines can do it, but that's because there is less rotational mass since the pistons are small and lower displacement. The only engines I know which can have that kind of redlines are 4A-GE's.
Well, I know for a fact that one member was running a stock EJ22T block to 10krpm. I was just mainly stating it that way because if he's going for horsepower, there ARE easier ways of getting the power then shoving a ton of boost into it. 1000hp at the stock RPM levels? That would take a LOT of doing, for sure.
Old 07-02-2006, 11:18 PM   #30
keaniegenie
Member#: 94494
2005 Element 92x
I think 50k will be short. considering the guy is probably close to $10k just for EM and tranny for this setup, $40k for a motor and turbo setup for this power is really steep.
I have a hard time thinking of any Subie setup that would support this. H6 is probably on the right track, but can somebody get one to rev above 10k? Getting there WITH nitrous would be hard enough.
keaniegenie is offline   Reply With Quote
Old 07-02-2006, 11:42 PM   #31
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Here is a simple bolt on 1000hp upgrade:
dexterous is offline   Reply With Quote
Old 07-02-2006, 11:43 PM   #32
SnowMann
Member#: 79996
2005 LGT Ltd.
GRP
A twin turbo SBC will make 1000whp pretty easily.
SnowMann is offline   Reply With Quote
Old 07-03-2006, 12:45 AM   #33
dexterous
Member#: 23553
2014 WRX - Daily
In all seriousness I think this is your answer: http://forums.nasioc.com/forums/show...9&page=1&pp=25
Old 07-03-2006, 01:35 AM   #34
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Well, I found out that Simon at PPG said that their 6 speed dogbox could eat 1000HP for breakfast and ask for seconds, so that solves that problem. Wether the rest of the driveline could hold or not is another question as no one has run that much HP through the aftermarket driveshaft, axles, etc. Thanks for the serious and funny ideas as this is more of a what if question than anything else.
Old 07-03-2006, 01:44 AM   #35
keaniegenie
Member#: 94494
2005 Element 92x
I assumed a PPG 6-speed dogbox would do the trick. Even with a Unabomber discount , that's still around $6k. Assuming stock axles and driveshaft are good for that power (pretty hefty assumption), you're still going to break 10k for the em and clutch, right?
The good thing is since it's AWD, the axles don't need to be as strong as a 1000whp RWD car. The driveshaft may be too weak. You may need to get an ACPT, if their CF shaft is good for that power.
1000whp with nitrous is hard enough, but reasonably do-able. 1000whp is usable anyways unless you're going to run 1/4 mile runs, and if that's the case, just do a fully built, stroked ej22t w/ nitrous and you'll get there within budget and reason.
Old 07-03-2006, 02:17 AM   #36
4wdwrx
Member#: 72042
2002 V7 Impreza
"Blue Mammoth" Returns
Well... 450ftlbs. at 12,000rpm would yeild you 1028hp. I think you really need to think RPM's if you're thinking big numbers, otherwise the sheer amount of torque you'll need to make will blow up things that no one has every dreamed of blowing up.
damn.. thats like F1 technology... o wait didnt subaru develope a F1 boxer engine.. hmmm..
4wdwrx is offline   Reply With Quote
Old 07-03-2006, 02:31 AM   #37
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
http://www.jalopnik.com/cars/retro-a...bay-123914.php
That'd be a step in the right direction if you could get your hands on one.
amukaoen is offline   Reply With Quote
Old 07-03-2006, 04:58 AM   #38
thunder_sti
Member#: 68315
04 Stock internals
520awhp-C16 425awhp-93o
$50,000 that might just be enough for engine / swap / internals / turbo/compatiba;ity/ correct specs/ and Labor.....
...Labor is a killer...
thunder_sti is offline   Reply With Quote
Old 07-03-2006, 09:34 AM   #39
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I guess the customer specifically does NOT want a roll cage, so drag racing is out. I assume this will just be a dyno queen. And remember kiddies, this is a theory question more than anything as I have no hand in the the sale, just starting some discussion on what it would take. Personally, I'm inclined to think it would take more money, but the potential buyer has already talked to another Subaru shop that said they could get him 1000 WHP for $40,000. I'm thinking on that.
Old 07-03-2006, 12:12 PM   #40
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
True, but don't forget your drivetrain losses! I hate to be a stickler, but I have to admit that I'd sure love to have a 2.7% sap instead of ~30%!
LetItSnow is offline   Reply With Quote
Old 07-03-2006, 12:36 PM   #41
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
just buy a supra and it could be had for much less money
SubyDuz is offline   Reply With Quote
Old 07-03-2006, 12:37 PM   #42
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Complex has the right idea though, I think. You can avoid a lot of costs and development stuff by moving the hp way, way over to the right on the plot. it's the torque that breaks stuff.
We all know that there are a couple vendors here who offer 8500rpm units from the 2.5.
What if you destroked the 3.0L and went after the rpms?
BadTrip is offline   Reply With Quote
Old 07-03-2006, 12:54 PM   #43
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Some very interesting info in this thread:
http://forums.nasioc.com/forums/show....php?t=1038296
Here's a couple key points:
"This is a stock H6 motor except for the addition of Supertec Forged H6 8:1 CR pistons. The stock valve train components are a very limiting factor in pushing the motor, so this initial tune is just to help develop maps."
"Given the valve train limitations (the exhaust valve springs are only 15 lbs), I didnít want to push the boost up above 14psi. I started at about 8psi, which quickly netted about 330whp. Upping to 10psi netteted 370whp, and 12psi over 400whp. At about 13psi, I was able to get ~420whp and about ~400 ft-lbf torque. I was very happy to get 400whp at only 12psi on pump 92 octane without the motor even breaking a sweat. At this low boost level, I could run AFRs anywhere from 11.1 to 12.5:1 without knock. "
"Here you can see the injector duty cycle, boost, and knock levels. With a peak injector duty of about 55%, 100% duty would be in the theoretical 730-750whp range. " <<Now throw in alk injection and you could be getting in the ball park, no?
Old 07-03-2006, 01:07 PM   #44
keaniegenie
Member#: 94494
2005 Element 92x
A shop said that? I'm thinking they mean $40k in parts, labor NOT included
Old 07-03-2006, 01:20 PM   #45
GOT AWD
Member#: 111838
2006 STI
WRB blue
^ very true but look at it this way. The shop that builds the 1000hp subbie think of all the attention they would get and media from everyone on nasioc would be at there website in a minute. Thus bringing in more traffic for them so they dont have to charge labor on this one build if they know it will reap some HUGE benefits.
GOT AWD is offline   Reply With Quote
Old 07-03-2006, 02:03 PM   #46
JoshP
Member#: 94350
easy just slap one of these bad boys in there.
JoshP is offline   Reply With Quote
Old 07-03-2006, 02:04 PM   #47
nightia
Member#: 93538
2005 STI
This reminds me of the early 80ís when Formula One was running exotic turbo configurations with exotic fuels to get some silly horsepower figures.
I just think the tweaking for an engine like this is going to be a nightmare, especially if you've only got one engine/transmission to play with. Itíll get damaged more than once before you hit 1000 hp. Cost over runs for something like this are going to be immense, given a $50,000 budget. 650-750 hp is probably more realistic. I fear the last 250 hp may be pushing it to far, without a Nitrous setup.
Look at the engineering issues the engineers working on the mighty Bugatti Veyron had to overcome, cooling etc.
nightia is offline   Reply With Quote
Old 07-03-2006, 02:15 PM   #48
keaniegenie
Member#: 94494
2005 Element 92x
To some extent, but the problem with demo cars is it takes installer's time away from current customer jobs, and you hope to get more business from the work to more than compensate for the lost time/labor. Most shops that spend a ton of time on demo cars later regret doing the job. Especially with a lofty goal like 1000whp without nitrous, which may never be achieved.
Old 07-03-2006, 04:05 PM   #49
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
As far as cooling goes....run it on alcohol....just the drag guys do. No cooling needed.
Old 07-03-2006, 04:28 PM   #50
JBLU24
Member#: 97503
someone post this on the srt4 forums so we can get some proven setups people...
JBLU24 is offline   Reply With Quote
What is Variable Turbine Geometry and how does it work? ka mano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 10-22-2011 05:16 AM
Is 280 WHP possible on stock turbo 2.0 Rudywrx04 Newbies & FAQs 17 07-09-2008 10:29 PM
Help me out: is this dealer desperate and how firm do I stand? sonicblue Off-Topic 40 08-23-2007 01:37 PM
Who is using Motul 8100 and how do you like it? hauvis Service & Maintenance 9 09-05-2005 07:34 PM
What is this "tornado warning" and how am I supposed to feel about it? semabe Off-Topic 37 01-01-2005 07:24 PM
