Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 07-06-2006, 02:22 AM   #76
Homemade WRX
Member#: 33782
96 2.4L LR 35R
00 F250 7.3L toy hauler
Originally Posted by sponaugle
Hey, that's me!
The topic of 1000whp has been something we have been discussing for some time. Adding something like Alky injection only allows the engine to make the most of the available air, not create horsepower where additional air is not available.
With the H6 at 3.0L, there are two limiting factors that make 1000whp challenging. First, the longer stroke puts some limits on RPM (as does the VERY heavy variable lift buckets). The second is of course the amount of boost you would need.
As a rough calculation, 3.0Ls at 85% eff at 6500rpm at 40psi yeilds about 70 lbs/min of air. Using something around 10-11hp/lb/min of air gets you about 700hp.
If you jump the boost to 50psi, you are talking about 80lb/min, or a bit over 800hp.
You would then need a turbo that can flow that kind of air at those pressure ratios. A 40 couldn't do it, but a 42R could. You would be at the top of the PR map at 50psi, but still workable. If you then added a 200 shot of NOS, you would be in the right ballpark.
If you really wanted 1000hp with no NOS, you would need something on the order of 60psi at 7000 rpm, which would be very very hard to do on any normal turbo. Even looking at a GT60, there is not enough PR height.
If you could rev to 8000rpm at 45psi, you would be at 90+ lb/min, which might be tweakable to 1000hp.
If you could increase VE at high RPM to 92%, 8000 rpm at only 40psi would be close to 1000hp, and right on the GT42 map.
Just some food for thought. Even with a turbo, displacement makes a big difference.
Jeff
I love actually cramming the numbers and looking at the actual science side of things...but seeing the quick numbers you through down, I'm wondering what the displacement of that guys 2200 whp small block was...also what rpm he was turning and how many pounds he was running...
Old 07-06-2006, 02:23 AM   #77
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
LS-2 or LS-1 in a Gen 3 RX-7...
I would love that car....
Wait 50Gs....LS-7 (new Z06 engine code I think) with a Lingenfelter TT kit in a Gen 3 RX-7.
Matt
PA04STI is offline   Reply With Quote
Old 07-06-2006, 02:25 AM   #78
Homemade WRX
Member#: 33782
96 2.4L LR 35R
Matt
lingenfelter has been building all the C6's or the "lingenfelter corvettes" as NA (testing wise at least)...although I'm sure they have priced out FI ones though...
Old 07-06-2006, 10:58 AM   #79
InfamousDX
Member#: 25413
2009 junior screwed!
Originally Posted by marylandecstasy
mm..k for jokes I had an idea..
http://www.turboneticsinc.com/turbo_thumper.htm
By the time this baby spooled up................ yeah, it wouldn't spool up. Ever.
106mm turbo... not too bad. Supras can do it... I'm sure that could eventually get spooled.
More Hot Topics on NASIOC...
Old 07-06-2006, 02:57 PM   #80
bboy
Member#: 56468
04 Improved STI
Dirty White
You could spool with nitrous, but it would never be a track car. Earlier F1 cars managed these HP levels on small displacement, but they had a whole lot more head room for RPM.
Old 07-06-2006, 02:59 PM   #81
MarylandEcstasy
Member#: 103518
3d Custom Flyers
www.intuition-designs.com
Are you serious? You had me then!
MarylandEcstasy is offline   Reply With Quote
Old 07-06-2006, 03:29 PM   #82
GetSideways
Member#: 44665
03 wrx sedan
platinum
Matt
Just do an rx-7 4 rotor.....sounds like an f-16....
GetSideways is offline   Reply With Quote
Old 07-06-2006, 04:00 PM   #83
doug*E*fresh
Member#: 116794
02 wrx
sedona red
twin turbo ls1 enough said or helion single turbo 03 cobra motor in a probe would be sweet
doug*E*fresh is offline   Reply With Quote
Old 07-06-2006, 05:14 PM   #84
Homemade WRX
Member#: 33782
96 2.4L LR 35R
no more like a blender...
Old 07-06-2006, 05:22 PM   #85
InfamousDX
Member#: 25413
i agree
http://videos.streetfire.net/search/...3D584C8FE5.htm'
This oen sounds ncie though.
http://videos.streetfire.net/search/...A5B216E68E.htm
Old 07-06-2006, 06:03 PM   #86
InfamousDX
Member#: 25413
actually yea.. it might be slightly big....
http://videos.streetfire.net/recentv...aa0463e4d5.htm
Old 07-06-2006, 06:19 PM   #87
babyblue22681
Member#: 51981
03 very fast wrx
blue
24 psi and im not really sure what the displacement was. from 3000 to 8000 he was above 1000 hp... with a roof of like 8800 rpm..
babyblue22681 is offline   Reply With Quote
Old 07-07-2006, 03:55 PM   #88
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
That was the sound of the turbo? Friggin sick if it was.
wcbjr is online now   Reply With Quote
Old 07-07-2006, 04:01 PM   #89
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
In terms of HP, RPM and displacement are equal. There were 1.5L F1 motors back in the turbo days with 16000 rpm redlines, 1000hp, and 45+psi of boost.
If someone really wants 1000whp, they just need to decided which variable they want to push the most. Obviously the 8 cylinder guys often push the displacement, as a 8.0L Viper motor at 20psi could probably reach 1000hp, but at 120lb/min of air, you are talking about twin GT35Rs. On the flip side taking your 2.5L motor and reving it to 10,000 rpm at 50psi would be in the same power range, but you would need a 2.5L that can rev to 10k and handle 50psi.
Of course NOS changes all of this. Many many of the large HP drag cars are using NOS to get significant 'displacement' advantages, especially at lower rpms as the amount of NOS injected with a fixed pressure and nozzel size is a fixed volume at all RPMS, which means much more per cylinder at lower RPM.
Jeff
PDXTuning is offline   Reply With Quote
Old 07-07-2006, 04:19 PM   #90
Crazykev
Member#: 93667
'03 Cusco Tarmac'd
PE1818 331whp/331wtq
I'm throwing this in here just to see if this helps at all. My buddy held the 2.0L turbo no NOS record 3 years ago with a Talon that was running a T-88 if I remember correctly and he put down 966 WHP at Buschur Racing. I don't think Scott was running more than 46psi or so?
Crazykev is offline   Reply With Quote
Old 07-07-2006, 04:48 PM   #91
2rexy
Member#: 98859
2004 Wrx
Java BLack
1000 hp is obtainable with the B9 Tribeca motor, it's an H6.
2rexy is offline   Reply With Quote
Old 07-07-2006, 04:52 PM   #92
modaddict
Member#: 95840
I am D M0NEYZ
Daddy!
modaddict is offline   Reply With Quote
Old 07-07-2006, 05:35 PM   #93
Homemade WRX
Member#: 33782
96 2.4L LR 35R
yeah, the BMW's (4 cylinder same base engine as the 318)used to get to 1500hp in qualifying and would detune to 1200 hp for the races...the Renault's (have to take a pic of one across the street) put out a little less as a tt 1.5L v6...
regardless they also didn't run on gasoline...there is some fun chemistry with those motors...
I already know how I'd get the rev's and displacement...not using a 6 because of the lack of head developement...
Old 07-07-2006, 05:37 PM   #94
SloRice
Member#: 44351
2004 Mitsubishi Evo
640whp 9.91@146
^^^bahahahaha!!!1!1!!!
SloRice is offline   Reply With Quote
Old 07-07-2006, 06:48 PM   #95
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
A T-88 is a large turbo indeed. As with the above examples, the critical variables that can make hp are all somewhat well know, with the excpetion of the efficiency and BSFC. Those are something that vary based on many many variables.
For example with a 2.0L motor at 10,000, if you could achieve 95% fill efficiency at 46psi or so you could get something in the 90-95 lb/min flow. With that kind of air, on the right kind of gas, I would expect you could get 900-1000hp, if not a bit more.
The amount of power you can get out of a lb of air would certainly be dependent on the fuel used. Using something like C16, I suspect the conversion might be as higher, perhaps something in the 12-13 hp/lb range. With more extreme fuels, this can be much higher of course.
Last, but not the least, All of these common claims are based on Chassis dyno numbers, which are less then consistant.
For example, if SAE corrections were turned on, 900whp can become 966 very quiuckly. As well, a small error in RPM setup (RPM reading slightly higher) can add 50hp very quickly at such high rpms.
Just food for thought of course.
If a customer wants 1000whp, he can get it. There isn't that much to the science. There is more to the reliablity part for sure.
Jeff
sponaugle is offline   Reply With Quote
Old 07-07-2006, 06:49 PM   #96
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Very true indeed. Cams are still a bit off, and headwork is being explored. This is a pretty new motor to the performance scene, and I suspect more power can be made cheaper elsewhere (2.5, 2.6, 2.8L H-4s, etc)
Jeff
Old 07-07-2006, 08:10 PM   #97
Jeremy@Cobb
Member#: 106514
This is the block that would be of choice! Sleeved EZ30R
I wish I had pictures of our ported heads to show with the block and components.
Jeremy@Cobb is offline   Reply With Quote
Old 07-07-2006, 08:15 PM   #98
modaddict
Member#: 95840
I am D M0NEYZ
Daddy!
^^^^^^^^^^^^talk about an open deck!
Old 07-08-2006, 12:15 AM   #99
wldbllrdr
Member#: 119538
1,000 hp. Buy a Mustang. P56 that is.
wldbllrdr is offline   Reply With Quote
Old 07-08-2006, 01:53 AM   #100
InfamousDX
Member#: 25413
Wow... now that's a new pic.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 02:49 PM.
