Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 11-16-2006, 10:18 PM   #151
WJM
Guest
Member#:
Originally Posted by EnterTheDragon View Post
Why would anyone even consider a Subaru for that much power?
Cuz no one has done it yet....
Thats why *I* would do it.
As for where the WJM would start....
EG33, go ahead and wet sleeve it and go 2MM over bore with appropriately thick sleeves. (end result of about 3.8L displacement)
Cosworth Crank.
Fully custom-newly cast and CNC machined heads with AVCS.
Mahle Pro (The box-in-box) pistons.
Some type of unobtainium rods.
AEM for the EMS
And supporting mods.
Take all that, shove it into a 1985 XT-DL (stripper model), flatbottom it, light weight it some more (2300 lbs fully loaded) and go to town.
Old 11-16-2006, 10:26 PM   #152
modaddict
Member#: 95840
sold to a good bud
awaiting next car
2.5 month bump?
modaddict is offline   Reply With Quote
Old 11-16-2006, 11:12 PM   #153
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Give it time...
MY build will be on a mustang dyno though
but mine won't be the one getting near 1000whp
Old 11-17-2006, 07:49 AM   #154
Silver '02 REX
Member#: 27963
2013 Focus ST2
PB
With 800 whp the Cobb Tuning Time Attack project shouldn't be too far off using an EZ30 and twin GT3071s
Silver '02 REX is offline   Reply With Quote
Old 11-17-2006, 11:35 PM   #155
LIGHTNINGDRIVER
Member#: 106001
2015 Bmw X5 50xdrive
i have a nasty setup and dont think i will even get to 1000 with nitros but i will try, , I think you would need the H6 and high rpm, with a huge turbo.
Just to have a dyno queen
LIGHTNINGDRIVER is offline   Reply With Quote
Old 11-18-2006, 12:04 AM   #156
Freon
Member#: 88322
2009 BMW 135i
Well with AWD any Subaru dyno queen should do at least halfway decent on a drag strip. I'd hope!
Freon is offline   Reply With Quote
Old 11-18-2006, 05:47 AM   #157
cbourbs
Member#: 117749
didn't turbotrix out of new jersey build an over 900 awhp sti on meth? i saw it in dsport magazine. at the time they only had 700hp, but they were hoping to get well over 900 on that setup, i'm not sure how much they spent on it though. they were planning to run something rediculous like 44 psi
cbourbs is offline   Reply With Quote
Old 11-19-2006, 02:53 PM   #158
rustyzipper
Member#: 79175
2004 FXT
Red
Tell him to choose a different platform to build.
The H6 will blow apart at ~500hp . I don't think that the subaru makes a motor that can do that . Maybe the sleeved 2.5 and such , but ... that is really absurd
$0.02
rustyzipper is offline   Reply With Quote
Old 11-19-2006, 03:02 PM   #159
Homemade WRX
Member#: 33782
96 bastard child
and where are you getting this from?...and if your answer includes stock block, please slap yourself
Old 11-19-2006, 03:25 PM   #160
WJM
Guest
Member#:
The H6 will blow apart at ~500hp.
Old 11-19-2006, 03:36 PM   #161
sicksubie
Member#: 101206
1992 Built, S/C'd,
6MT SVX #122 400whp
$0.02
Where are you getting this? I have 3 SVX's and have never heard of someone having issues with the motor outside of someone trying a 175 shot of NOS. Granted there is nobody that I know of that is pushing the 500whp mark, but there are a few S/C ones that are in the 380-415 range on stock motors with stock internals. I am in the middle of building an EG33 this winter. and if you have the time and the $$$$, 500whp is def a possibillity, but EM will pose the biggest problem.
sicksubie is offline   Reply With Quote
Old 11-19-2006, 04:10 PM   #162
rustyzipper
Member#: 79175
2004 FXT
Red
Well , I guess if that was the case , then I was wrongly informed. I actually have an H6 sitting behind the garage , but when I was doing research to build it , I constantly ran into that : A) would cost alot more than a 2.5 build B) could really only get 400hp ~500hp out of them reliably , and C) something else that made me steer away from it.
So I went with a 2.2t instead.
But if you guys say its possible, then I will have to do some more digging.
If it is possible, then how come you don't see more of them? $$ vs. hp gain? Easier to make hp on 2.5 ?
So , if that is the case , am I right in still saying that the H6 could not get 1000hp then ?
Granted , ANYTHING is possible, but attainable?
Old 11-19-2006, 04:25 PM   #163
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Pistons/rods/valvesprings....etc.etc.etc.
They make lots of power, however, it takes alot to take a NA engine to turbo.
Old 11-19-2006, 05:58 PM   #164
WJM
Guest
Member#:
Originally Posted by sicksubie View Post
...but EM will pose the biggest problem.
AEM will solve that.
While AEM doesnt make one that is plug and play for the SVX...every AEM has the capability to run anything from a single cylinder lawmower to any 12 cylinder engine. Wiring and setting it up is the slightly difficult part. But if you can assemble an engine from the ground up, then the AEM will not be a problem if you do a little research and if you can understand the AEM manual.
Old 11-19-2006, 06:22 PM   #165
fobiawrx
Member#: 91074
04 sti
white
perrins got a turbo h6 going on. pdx did a turbo h6 for a customer. phatsuby is doing a twin turbo h6. there was that twin 35r bug eye that was a h6. people all over are doing them. look around
fobiawrx is offline   Reply With Quote
Old 11-19-2006, 10:40 PM   #166
Homemade WRX
Member#: 33782
96 bastard child
yeah, rod, pistons and headwork (including cam)...but what drag car at this scale doesn't have that done anyhow
Old 11-24-2006, 03:26 PM   #167
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
44psi on Methanol isn't ridiculous as the equivalent gas octance rating is around 124. Also since the BTU content of methanol is half that of gasoline, you have to run twice the fuel volume. That equates to a ridiculous exhaust gas volume to spool your turbo. Add a h20-air IC and 50+ PSI would be no sweat until the intake charge drops to around 45ish degrees where methanol fails to vaporize. A 10% Mix of max octane race gas and 90% methanol could make that power EASY. Well more easily than gas ever could.
QuikWgn is offline   Reply With Quote
Old 11-25-2006, 03:49 PM   #168
LIGHTNINGDRIVER
Member#: 106001
i dont think ill be far off with cams, built 2.65L, gt42R turbo ,meth, 120 shot of nitros, 44 or so psi, and a bunch of other custom fabed parts, headers , 4 inch exhaust, etc, SAEM
Old 11-25-2006, 04:53 PM   #169
rustyzipper
Member#: 79175
2004 FXT
Red
holy ****!
Old 11-25-2006, 04:55 PM   #170
WJM
Guest
Member#:
Bench dyno says 850~900 at the wheels on that.
Old 11-25-2006, 05:15 PM   #171
CatfaceType-R
Member#: 81102
Originally Posted by Evil STI View Post
A Zoloft prescription would be money well spent for anyone that MUST have 1000whp in a Subaru.
hahhahah lol
CatfaceType-R is offline   Reply With Quote
Old 11-25-2006, 05:41 PM   #172
Homemade WRX
Member#: 33782
96 bastard child
I'd be interested to see if it could crack 1000whp...what are you spinning the 2.65 to?
Old 11-25-2006, 06:41 PM   #173
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
It'd be easier with a EJ22 based stroker @ 2.4L. The closed deck block will hold the boost way more reliably that an EJ25. And the reciprocating weight with a profile milled billet crank and TI Rods are substantially lighter than what you are gonna be swinging in the EJ25 setup. Redline is about 9750rpm with the EJ22 config which is about 130lbs of air(top of the pressure map with a gt42) Might wanna look at the Borg Warner S/R-200/300 turbo family which can support the required power level.
Old 11-25-2006, 08:26 PM   #174
cruiseh
Member#: 133170
i dont think this will crack 1000 hp, but it will make "enough"
http://www.rslibertyclub.org/forums/...ad.php?t=63712
cruiseh is offline   Reply With Quote
Old 11-25-2006, 10:04 PM   #175
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
It's going to be totally dependent on how much boost they can run through it and if they double o-ringed/dead-soft copper gasketed/big head studs/portwork the heads.
What is Variable Turbine Geometry and how does it work? ka mano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 10-22-2011 04:16 AM
Is 280 WHP possible on stock turbo 2.0 Rudywrx04 Newbies & FAQs 17 07-09-2008 09:29 PM
Help me out: is this dealer desperate and how firm do I stand? sonicblue Off-Topic 40 08-23-2007 12:37 PM
Who is using Motul 8100 and how do you like it? hauvis Service & Maintenance 9 09-05-2005 06:34 PM
What is this "tornado warning" and how am I supposed to feel about it? semabe Off-Topic 37 01-01-2005 06:24 PM
