Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 07-01-2006, 06:29 PM   #1
GT40R
Member#: 86365
Default Crankshaft Position Sensor Air Intake Temp Sensor CODES!!
I have 3 cel codes if u can please help me trouble shoot...
P0335-Crankshaft Position Sensor Circuit Malfunction,
P0111- Intake Air Temperature Sensor Range/Performance Problem
Po112-Intake Air Temperature Sensor Circuit Malfunction (Low Input)
I already replaced the MAF sensor and the Crankshaft Position Sensor to a brand new one from the dealer. I am still having the same issues...The car doesn't want to hold a good idle, and when I am driving and I go into any kind of boost the car starts to sputter really bad and starts popping. The cel light isn't always on, it comes on here and there when it wants to. If anyone has had this problem please give me some kind of input...
PM me or IM me at jdmver8ej20
contact: (626) 285-1481 I would highly apreciate it
Thanx, Nasif
Current Mods...
ver.8 Spec-C longblock, Gt35R, 800cc injectors, ect ect.
GT40R is offline   Reply With Quote
Old 07-01-2006, 06:38 PM   #2
Sitkeh
Member#: 119015
The 02 Crank sensor is poorly designed. It can slip partially off by looking at it.
Sitkeh is offline   Reply With Quote
Old 07-01-2006, 06:40 PM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Are you using deltadash to read your codes?
Soon2Bgreat is offline   Reply With Quote
Old 07-01-2006, 06:43 PM   #4
GT40R
Member#: 86365
yea I am using delta Dash..
Old 07-01-2006, 06:46 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Check to see if it's in demo mode
Old 07-01-2006, 06:59 PM   #6
GT40R
Member#: 86365
what's Demo mode??
Old 07-01-2006, 07:06 PM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Originally Posted by GT40R
what's Demo mode??
Pretty much what it sounds like Responded to your PM...i could be wrong though.
Old 07-01-2006, 07:09 PM   #8
Sitkeh
Member#: 119015
Like valet mode on a UTEC? I never knew the stock ecu had such a thing.
btw: Reset key at battery. Comes in handy.
Old 07-01-2006, 07:13 PM   #9
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
No it's like a demonstration...like it's not hooked up to your ecu and simply demonstrating what the interface looks like, much like AEM/Autronic/Motec etc. have for their standalones.
I don't know if his is hooked up to his ecu...i know when i had mine in demo mode that is exactly the codes it threw. Other values won't jive though and he can always check the codes against another obd2 scanner. This may not be his problem.
Old 07-02-2006, 09:39 AM   #10
GT40R
Member#: 86365
do u think it might be the tuning?? I recently swapped out a new block, but it's the same ver8 Spec-C block...I figured since its the same block the tuning should still be all good right?? or would I have to Re-tune?? I'm just really bugged out about these cels it's throwing....what can I do to trouble shoot it?? anyone....
Old 07-02-2006, 01:04 PM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I think ya bent the crank sensor mount and borked the MAF plug or wiring
Uncle Scotty is online now   Reply With Quote
Old 07-02-2006, 02:33 PM   #12
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
How do you get the deltadash to come out of demo mode???
Blackpantherwrx is offline   Reply With Quote
Old 07-02-2006, 06:07 PM   #13
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
If it's in demo mods there is something wrong with the connection, or you don't have the key plugged in, or you've used up your licenses or there is some reason why it's not hooked up to your ecu.
Uncle- He was in demo mode it's not really throwing those codes.
Aem Intake Temp. Sensor... 555 Engine Management & Tuning 4 01-08-2008 04:26 PM
Intake Temp Sensor Dave_MacKinnon Engine Management & Tuning 21 07-17-2006 12:10 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 11:50 AM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 07:03 PM
Link plus with intake temp sensor? Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-18-2003 10:18 PM
