Old 07-01-2006, 05:31 PM   #1
GT40R
Member#: 86365
Default Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!!
I have 3 cel codes if u can please help me trouble shoot...
P0335-Crankshaft Position Sensor Circuit Malfunction,
P0111- Intake Air Temperature Sensor Range/Performance Problem
Po112-Intake Air Temperature Sensor Circuit Malfunction (Low Input)
I already replaced the MAF sensor and the Crankshaft Position Sensor to a brand new one from the dealer. I am still having the same issues...The car doesn't want to hold a good idle, and when I am driving and I go into any kind of boost the car starts to sputter really bad and starts popping. The cel light isn't always on, it comes on here and there when it wants to. If anyone has had this problem please give me some kind of input...
PM me or IM me at jdmver8ej20
contact: (626) 285-1481 I would highly apreciate it
Thanx, Nasif
Current Mods...
ver.8 Spec-C longblock, Gt35R, 800cc injectors, ect ect.
GT40R is offline   Reply With Quote
Old 07-03-2006, 12:43 PM   #2
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Probably a Loose ground on the intake manifold.
Clark
AZScoobie is offline   Reply With Quote
Old 07-05-2006, 10:50 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I had the tail of an oversize hose clamp (it was on the bov return hose if I remember right) rub up against the wires on my throttle pos sensor. Eventually the tail wore it's way through the wires and wreaked all kinds of havoc. I got similar codes (I think these sensors are all tied in on the same wire harness). You may want to try and make sure there are no exposed wires in addition to the advice given in the above post.
TyranosaurusWRX is offline   Reply With Quote
Aem Intake Temp. Sensor... 555 Engine Management & Tuning 4 01-08-2008 03:26 PM
Intake Temp Sensor Dave_MacKinnon Engine Management & Tuning 21 07-17-2006 11:10 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
Link plus with intake temp sensor? Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-18-2003 09:18 PM
