Old 10-18-2001, 11:20 AM   #1
rallynut
Member#: 885
Question 14" rims fit a 97 GT?
Anyone know if 14" rims clear the brakes on a 1997 Legacy GT? Tried searching the forum but it had a problem with 14" as a search term.
rallynut is offline   Reply With Quote
Old 10-18-2001, 12:03 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
subaru 15" wheels won't fit, so i'm pretty sure 14" won't either...
ben
Benjamin Tang is offline   Reply With Quote
Old 10-18-2001, 12:19 PM   #3
rallynut
Member#: 885
15" won't fit? Are you kidding? I am *almost* positive that several local guys have 15" rims for the winter. There is easily more than an inch of clearance on the 16" stock rims, from an eyeball measurement anyway. I suppose I'll have to roadtrip and find out. I will let you all know unless someone knows for sure (by trial fitting).
Old 10-18-2001, 01:12 PM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
OE Subaru 15" steel wheels as well as older style 15" GT alloy wheels will fit the '97GT. 14"'s definately won't (unless you degrade your 2 pot front calipers to single pot calipers)
GTBGUY is offline   Reply With Quote
Old 10-18-2001, 01:47 PM   #5
Benjamin Tang
Member#: 4496
2009 Forester
red
i'm basing what i said on personal experience. have a 95 ls that had the stock 15" 5-spoke alloy wheels with the smaller single-pot front brakes/rotors. i upgraded to my00/01 outback brakes in the front, which are the same as the gt, and my 15" wheels would not mount over the calipers, which resulted me in getting 16" gt wheels.
perhaps it was my style of 15" factory wheel that would not work...?
ben
Old 10-18-2001, 03:20 PM   #6
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Benjamin Tang - You're correct b/c you've upgraded to '00/'01 Outback brakes, which are equal to the '02 WRX brakes as well. 15's won't fit over those, as they are larger than the '96-up GT brakes.
The Outbacks starting in 2000 uses larger front brakes b/c it's heavier.
Old 10-18-2001, 04:14 PM   #7
Benjamin Tang
Member#: 4496
2009 Forester
red
why is it people tell me that the pre-my99 2-piston gt calipers are the same as the my00-up outback?
ben
Old 10-18-2001, 04:18 PM   #8
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
They tell you that so you won't feel left out. Just keep pretending they are the same and you'll feel better!
janikphoto is offline   Reply With Quote
Old 10-18-2001, 04:28 PM   #9
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Benjamin Tang - Calipers are the same, the rotor sizes aren't. All the 2 pot Subaru Calipers used in North America are the same. Those calipers are used on '98-up RS, WRX, Outback, GT etc. Only the size of the rotors differ. Your original L rotors < original GT/RS/Forrester rotors < '00-up Outback and the new WRX.
Since you did a whole conversion, you got the mounting brakets from the '00-up Outback, which allows you to use the larger rotor.
Old 10-18-2001, 04:42 PM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
oic... i'm gonna get this straight one of these days
i guess i was lucky... when i went to the wrecking yard i asked for either gt or outback stuff, thinking all the time that everything was the same, and they only had the one outback...
ben
Old 10-19-2001, 11:18 AM   #11
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Subaru 15" Outback wheels fit an RS which I believe has the same brakes as an Outback or GT (pre-00) anyway. I sold my '97 Outback alloys to an RS guy who wanted them for rallying/rallycross so I know they fit...
Doug
dvancleve is offline   Reply With Quote
Will 14" rims fit on a 03TS matty2.5 Tire & Wheel 0 12-04-2008 01:30 PM
borla header part # 17183 fits 97 gt? andruuu Legacy Forum 2 10-13-2003 12:26 PM
Will 14" OEM 7-Spoke Alloys work/fit on a GT? sovereignmk1 Legacy Forum 10 01-01-2003 04:25 PM
What type of rims fit on 97 Impreza Outback? Chapel Brakes, Steering & Suspension 2 04-05-2002 12:03 PM
will a 91-94 turbo legacy lsd fit on a 97 GT? 2.5GT Normally Aspirated Powertrain 3 03-30-2001 02:18 PM
