Old 07-02-2006, 08:51 PM   #1
Need4speedTC
Member#: 112458
05 WRX Wagon
Default MPG on cobb stg 1 and 2?
What is the MPG you guys are getting on stage 1 and 2? Is it a big diffrence from stock?
Need4speedTC is offline   Reply With Quote
Old 07-02-2006, 10:08 PM   #2
rexmaster
Member#: 90387
05 stg 2 wrx RIP
wrb
It only gets better.
I'm getting 23-25 mpg with stg 2.
rexmaster is offline   Reply With Quote
Old 07-02-2006, 10:42 PM   #3
hondaeater69
Member#: 60324
it won't be anything big. Cobb's maps are a little leaner up top vs stock, but go into Open loop fueling sooner, so they kind of offset each other.
Old 07-02-2006, 11:18 PM   #4
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
I was getting about 27mpg with stage 2, with mixed highway/city driving. With my protune I still get around 24-25
MdWRX is offline   Reply With Quote
Old 07-02-2006, 11:31 PM   #5
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
The last tank I had was mostly city driving and I got 17-18 mpg with stg 1. oh yeah... and I had my A/C on 90% of the time.
ThrawlWRX is offline   Reply With Quote
Old 07-02-2006, 11:36 PM   #6
stirob
Member#: 93631
2014 CTS-V
Opulent Blue Mtallic
I avg. 24mpg on a protuned stg. 2 05 92x.
stirob is offline   Reply With Quote
Old 07-03-2006, 10:42 AM   #7
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Stage 2, my g/f is getting 2-3 mpg more than when stock. She does pretty much only city driving (6 miles to work). Her average before was 19mpg, now it is 21.
Old 07-03-2006, 12:27 PM   #8
coldfire22x
Member#: 77328
2005 WRX Wagon
19-22 on stage 1 cali ... mostly highway at 80mph, with the A/C on half of the time (it gets pretty hot out here in fillmore ca)
coldfire22x is offline   Reply With Quote
Old 07-03-2006, 12:41 PM   #9
gqchynaboy
Member#: 88529
22mph Stage2 Cali Gas w/Protune
gqchynaboy is offline   Reply With Quote
Old 07-03-2006, 08:14 PM   #10
Need4speedTC
Member#: 112458
05 WRX Wagon
Thanks for your input you have now cost me 600 bucks
Old 07-03-2006, 08:15 PM   #11
deuce106
Member#: 118372
03 vf39 wrx
blue
don't know for sure but it seems to be better to me
deuce106 is offline   Reply With Quote
Old 07-21-2006, 08:02 AM   #12
20swrt
Member#: 50186
9804 WRX, RS25 coupe
WR Blue
Based on all the comments above, can i conclude that stg2+TBE has a slightly better milage than stg1+TBE? Has anyone compared this apples to apples?
20swrt is offline   Reply With Quote
Old 07-21-2006, 10:40 AM   #13
warpath
Member#: 84622
2016 TR Golf R
1992 MKIII Supra
Why would someone run stg1 with a TBE?
warpath is offline   Reply With Quote
Old 07-21-2006, 12:30 PM   #14
Master2192
Member#: 83254
98 2.5 RS
04 WRX
You shouldn't, it even tells you not to, and you'd be costing yourself horsepower and engine life.
You could compare Stage 1 - Stock and Stage 2 - TBE.
Old 07-21-2006, 01:49 PM   #15
20swrt
Member#: 50186
WR Blue
Thanks for the advice. I was running stg1 when i had stock tbe all along. I just installed a 3in full tbe last week and have not switched to stg2 maps. I wanted to compare my mpg after consuming a full tank. I also wanted to collect as much logs as possible so i can compare it later.
Old 07-21-2006, 02:03 PM   #16
k mier
Member#: 98000
05 sti [email protected]
Cobb stage2, 27mpg hwy trip w/air, easy driving. Averages around 25.xx combined hwy/town.
Cobb stage2, at the road course, arrived with 3/4 tank of fuel, 60 miles on track, pulled off early last session because car cut out in a turn, little less than 1/8th left in tank. What does that figure out to be?
k mier is offline   Reply With Quote
Old 07-21-2006, 05:11 PM   #17
20swrt
Member#: 50186
WR Blue
27 mpg. Thats incredible for stg2 on a STi nonetheless. Thats it! Im going stg 2 right away! 25/27 was the best i ever got on my 04 WRX (stock). I'll post what i get a week from now.
Old 07-21-2006, 06:01 PM   #18
k mier
Member#: 98000
Notice I said, "easy driving". I-55 from my house to Memphis is flat as a pancake, sure that helped. From my house to St. Louis on I-55 it's much more hilly, usually average, with some in city driving added in, between 25/26mpg's. Another thing, I drive like a grandma most of the time rarely hitting boost at all. If you drive like me, I suspect using Cobb's economy map will be a waste of time for you also. Netted me about .2mpg better mileage, not worth the time.
Now if I had 3/4 tank of fuel arriving at the track and left with 1/8 and only ran 60 miles....3/4~12 gallons?, 1/8th~3gallons?, that would be less than 7mpg's. Has anyone ever checked mpg's they got at the track? Doe's that sound within reason?
Old 07-22-2006, 02:07 AM   #19
Bbasso
Member#: 66235
2005 WRX
I was able to get 33.4mpg (i have a witness) on I80 going thru Ohio on the way to Michigan. I had the cruise control set at 65-68 for one tank of gas. I did not touch the gas pedal except to get on the highway from a rest area. I was impressed! both im myself for holding out and the car stretching it so far.
I have yet to see above 27 from that day, but 25-27 mpg is way better then the stock 19 mpg when I first got the car.
<-- stg 2 93 oct, up& down, IC hoses and automatic
Bbasso is offline   Reply With Quote
Old 07-24-2006, 11:27 AM   #20
4wdwrx
Member#: 72042
2002 V7 Impreza
"Blue Mammoth" Returns
I had better gas mileage on stage 1 than stage 2. I was getting 185 miles out of 6.5 gallons with ac ( I fill up only $20 everytime the light goes on), and now stage 2 driving the same way dropped down to 165 miles. err
4wdwrx is offline   Reply With Quote
Old 07-24-2006, 12:12 PM   #21
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
My friend averages 25 on his 06 stage2.
burritotown is offline   Reply With Quote
Old 07-24-2006, 12:49 PM   #22
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I'm sure my mileage could be better with stage 2, but I can't seem to keep my foot out of it, so I'm averaging about 21 with mixed city/hwy driving.
06rexwagon is offline   Reply With Quote
Old 07-24-2006, 03:39 PM   #23
WildBlueWRX
Member#: 111164
2008 Legacy 2.5GT
Obsidian Black Pearl
now i have something to look forward to...
WildBlueWRX is offline   Reply With Quote
Old 07-26-2006, 11:02 PM   #24
20swrt
Member#: 50186
WR Blue
I used to have a stg1 91 oct map with the stock tbe and gutted uppipe. That got me around 23.5 mpg on my daily commute of (14 city/26 hwy miles traveled daily) minimal ohio traffic. That was 2 weeks ago.
On July 15 2006, I went with Helix d/p + Greddy Evo2. My first full tank refill got me 303.5 miles and added 11.736 gallons. 25.86 MPG. Note that I had a stg1 map up until July 21, when i switched to stg2. My guess is that the increase was mainly due to the exhaust mods.
Old 07-27-2006, 03:25 PM   #25
iamseand
Member#: 117513
I for one am getting horrible gas mileage since i went stage 1, and even worse since stage 2.
Stock i was getting about 280 miles per tank,
now, im getting about 200, thats considerable. Does anyone have any ideas why?? Thanks,
iamseand is offline   Reply With Quote
MPG ? on STG 1 and 2.... jconaty07 AccessPort 24 05-05-2007 12:21 PM
Average MPG with cobb stg 1 brianhill023 Newbies & FAQs 12 06-26-2006 02:24 AM
cobb stg 1 to 2.5 vtownrida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 12-13-2004 07:01 PM
Going from Cobb Stg 1 to 2.5 what stock stuff do I need; gaskets and stuff AdamRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-16-2004 06:43 PM
flashing CEL on cobb stg 1? surfer5567 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2004 02:54 AM
