Old 04-09-2001, 12:35 PM   #1
XROLLER
Member#: 1273
98 Impreza
RBP
Post Green Plug...........CE light?
I'm having some problems with my clutch, so i get under the dash to look for anyway to adust the clutch and i notice that there's a green plug just dangleing there so i plug it in and the CE light freaks out.....what the hell is that for?
XROLLER is offline   Reply With Quote
Old 04-09-2001, 12:39 PM   #2
Chirik
Member#: 5320
2002 WRX Wagon
WR Blue Pearl
Post
That's the plug to make the CE light freak out... Okay, actually, I don't recall what it's for, but what I understand is it's supposed to be disconnected, and that's one of the things they do as part of the pre-delivery inspection.
Chirik is offline   Reply With Quote
Old 04-09-2001, 02:08 PM   #3
Sardonic
Member#: 2445
RBP
Post
Wait, this plug is a way to reset the ECU without the usual disconnect-battery-for-30-minutes-idle-car-for-20-more-minutes way? Is this too good to be true??
Sardonic is offline   Reply With Quote
Old 04-09-2001, 02:25 PM   #4
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Question
How do you reset your ecu using this plug???
latinskllz is offline   Reply With Quote
Old 04-09-2001, 02:27 PM   #5
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
That freak'in plug is a total pain in my A--!!!!
Following some obscure advice I found while doing a search I pluged it together to whre it snapped together. Of course the whole car seemed to freak out! And since the plug was in such an akward position and because it was snapped together so tight it took me forever to get the thing apart. My poor car freaking out the whole time.
The theroy at the time was that you could plug it together and the cd light would blink in a certain sequence, giving you a code that would basically tell you what is wrong with the car. Wrong. It turned out the reason I had the ce light to begin with was the o2 sensor, so it may or may not have recet the ecu. But I tell you this, I will deffinatly disconnect the battery everytime rather thatn mess around with that freak'in plug! I had to break it btw.
ChosenWon is offline   Reply With Quote
Old 04-09-2001, 02:30 PM   #6
Adrian128
Member#: 3346
Post
ECU clear memory procedure is as follows:
1) With engine at operating temperature, turn engine off and place gear shift lever into park (auto transmission cars)
2) Locate the two ECU check connectors, for most cars they are located under the steering column and consist of a black plastic male and female connector, and a green male female connector. The exact location of the connectors varies with the different year models, but generally they are located under the steering column on the drivers side. With the ignition OFF connect black to black and green to green.
3) their exact location varies depending on the year model
4) Turn on ignition and cycle the gearshift lever from park to neutral and back to park (auto transmission), depress the accelerator pedal to full throttle and hold for a few seconds, and then release. Start engine and then drive for at least one minute, keeping road speed above 11 Km/h. (Ed. don't have to do the gear shift cycle in a manual car, only the auto)
5) At this point the check engine light should start to flash the all clear signal (steady 1/2 second interval flashes). If the check engine light does not flash, or indicates some other sequence, there is a fault present in the system, and should be professionally checked for necessary repairs.
6) the ecu is now clear and re set!
Adrian128 is offline   Reply With Quote
Old 04-09-2001, 03:09 PM   #7
Tuning Factory Inc.
Vendor
Member#: 3600
Post
So is there a way to get the code using tis method? Perhaps plugging them together and turning key to on and counting flashes?
Tuning Factory Inc. is offline   Reply With Quote
Old 04-09-2001, 03:58 PM   #8
tulit
Member#: 338
09 STi
Post
Adrian, those instructions you have are for UK spec cars. As far as I could tell, there is only 1 black connector, not 2, so we can't do it that way.
My understanding of the plugs is that it causes the motor to go into an extreme lean run condition for short runs (i.e. loading onto/off of the ship for shipping the cars) to prevent gunking up the engine. This theory is confirmed with readings I got from the O2 sensor when I hooked the green plugs together.
tulit is offline   Reply With Quote
Old 04-09-2001, 04:15 PM   #9
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
Post
The dealer ship uses the green plug to trouble shoot your car for any problems. The blinks are codes. When the cars are ship to the usa its plugged in. When it gets to the dealer the look to make sure there are no problems. Dont plug it in to reset you ecu. Unplug your battery (-).
2.5rsMI is offline   Reply With Quote
Old 04-10-2001, 01:47 AM   #10
markoe78
Member#: 5391
Post
you also can reset your ecu doing that
markoe78 is offline   Reply With Quote
Old 04-10-2001, 01:57 AM   #11
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
yeah that plug is to reset the ecu without disconnecting the battery. I saw it working under my dash and almost plugged it in but decided the plug looked too robust for it to have come unplugged... so i left it
Safir is offline   Reply With Quote
ce light after changing spark plugs, etc... Blindeye_03 Normally Aspirated Powertrain 5 05-22-2002 04:57 PM
('93-'01) 1500 miles and CE light comes on. Rubik Impreza Forum 9 06-09-2001 05:15 PM
('93-'01) CE light - crazy fuel gauge Captain Ding Impreza Forum 3 06-08-2001 09:15 AM
('93-'01) Aaaaahhhhh!!! CE light??!! GooseMan Impreza Forum 12 04-19-2001 09:39 PM
('93-'01) CE Light Fyxtion Impreza Forum 3 04-07-2001 08:10 PM
