Old 07-02-2006, 09:30 PM   #1
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
Default Unable to reflash base map
Im not sure if this is a problem anyone else has encountered, but I hope so because I need some suggestions.
In february I purchased a new accessport, and flashed to stage one. The cable that came with my a.p. wouldnt power the unit, so the vendor sent me a new cable. I tried it briefly, and saw that it powered the a.p. just fine. I had borrowed a friends cable so I had already been able to reflash to stage one. (in other words, I have yet to get a successful reflash out of my new cable)
After installing a new exhaust today, I tried to reflash to stage 2. The green and white clips are both in place. After an hour of trying I am still getting the same message, "initializing ecu", followed by "turn key off completely, and turn back on". I cant get it past this step. I have read the instructions twice today, and double checked things but still no clue.
Here are my guesses:
Another bad cable?
some sort of interference from my aftermarket alarm?
other than that, I am at a loss. I Hope this is something I have simply overlooked. Any help is appreciated.
BenWeavdog is offline   Reply With Quote
Old 07-02-2006, 10:47 PM   #2
hondaeater69
Member#: 60324
i doubt it's anything with the alarm. Simple test: try your friends cable again. If it works it's your cable that would be my guess (it's the cable).
Old 07-03-2006, 08:22 AM   #3
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
Alright, later this afternoon I am going to try to get my hands on another cable and try again. Thanks guys.
Old 07-03-2006, 08:48 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Did you hti the enter button after turning the car back on?
Old 07-03-2006, 08:23 PM   #5
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
yes. In the instructions it also says that on the 05's you can skip turning the car off and just press enter. I tried both techniques. sometimes i got a "error, please try operation again", other times it just continues that "turn car off, then on" loop over and over.
called subaru of dallas, a new cable is on its way. Even though this has been a headache, hot-subaru.com has been pretty good about support. They got me my Cobb heat shield in 2 days.
Old 07-04-2006, 03:13 PM   #6
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
I was in the same exact situation just yesterday. I couldn't get the base map to switch, yet I was able to switch real time maps. I finally started messing with the pins on the end of the AP cable that go into the diagnostic port along with the diagnostic port. Just kinda pushed down on the wires on top of the diagnostic port, thinking there was a loose connection. After doing those two things, everything worked fine!
ihavebettersound is offline   Reply With Quote
Old 07-04-2006, 03:30 PM   #7
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
I was thinking along the same lines as you. I fiddled a little with the connections, but still no luck.
Hopefully my friend will be back tonight and let me use his cable. Otherwise, I will just wait for the new cable to arrive. Its kind of fun to get a chance to drive with just the new turbo-back, to feel the difference before the reflash.
Old 07-04-2006, 04:01 PM   #8
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Oh, and I decided to completely unmarry the AP from my car, then flashed to Stage 2. Maybe that's what did it.
Old 07-04-2006, 08:25 PM   #9
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
Tried that too. I ended up in the same darn loop. Kind of a bummer, but I am almost certain a different cable will fix this problem. I will post the results as soon as I get another one.
Old 07-04-2006, 08:43 PM   #10
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Yeah I would like to know if that works. Hope it does!
Old 07-07-2006, 09:49 PM   #11
BenWeavdog
Member#: 106215
2015 Subaru
Wrx
Update:
Recieved a new diagport cable today from subaru of dallas.
Tried the procedure again, and on first try was able to reflash to stage 2 base and real time. Thanks for the help guys, it was the cable without a doubt.
Old 07-07-2006, 10:47 PM   #12
hondaeater69
Member#: 60324
Originally Posted by BenWeavdog
Update:
glad to hear it worked out for ya
Old 07-08-2006, 01:12 PM   #13
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Good stuff!
Old 03-31-2013, 05:21 PM   #14
2004ImpressYa
Member#: 346668
2004 Subaru WRX
WR Blue
Im going to jump in here so I wont create an entirely new post. I just put on a downpipe and I am about to go stage 2 from stage 1. do I have to connect the test mode plugs and the green plug to flash ECU to stage 2? or can I just do it as its connected to the ECU only as if I was using the logs, etc??? Please help ASAP.
2004ImpressYa is offline   Reply With Quote
Reflashed base map, need to reset ECU? SWRX AccessPort 1 09-27-2006 08:55 PM
Wierd idle with a freshly reflashed base map gozway AccessPort 0 07-12-2006 12:19 AM
how long does it take for you to change base maps with AP? intence Engine Management & Tuning 7 01-06-2006 07:19 PM
Accessport: unable to change realtime maps for 02 wrx sadd16 Engine Management & Tuning 12 09-30-2005 12:54 PM
Any bad exp. with ECU reflash base maps? ChrisF Engine Management & Tuning 4 05-03-2003 04:14 AM
