Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 03-29-2013, 03:32 PM   #1
Myth21
Member#: 246851
2007 UGM
2012 LR
Default Cobb STG1+SF Datalog -UPDATED LOGS
https://docs.google.com/file/d/0B3RN...it?usp=sharing
I let my foot off a little because some car popped out of no where.
Let me know folks..
NEW LOG
1st run
2nd run 5 mins later
I am obviously seeing some fine knocks and HUGE AFR correction on the 2nd run. I'd appreciate it if I can be pointed in the right direction on what needs to be checked or what is going on.
Myth21 is offline   Reply With Quote
Old 03-29-2013, 03:57 PM   #2
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
You need to give public access to it for our viewing.
endrswrd is offline   Reply With Quote
Old 03-29-2013, 04:03 PM   #3
Myth21
Member#: 246851
2007 UGM
2012 LR
Fixed TY
Old 03-29-2013, 04:05 PM   #4
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
You need to hold WOT through the whole pull. But the log looks good based on whats in there.
Old 03-29-2013, 05:35 PM   #5
Anubis80
Member#: 341903
2016 STi
Hyperblue
You can look a couple threads down and see my cobb stage 1 +sf for reference.
Just my suggestion, I would run another log for sure. Your throttle wasn't 100% long enough imo for a proper log. Check mine out as an example.
Anubis80 is offline   Reply With Quote
Old 03-29-2013, 05:36 PM   #6
Anubis80
Member#: 341903
2016 STi
Hyperblue
Yup, didn't see this post until after mine. You need to be WOT from 2.5k-redline or close in 3rd gear for wrx and 4th gear for sti to get as close to a 1:1 gear ratio.
Old 03-29-2013, 05:44 PM   #7
Myth21
Member#: 246851
2007 UGM
2012 LR
It is 3rd gear, I will do a couple more logs tonight, I'll add on the AFR's too because I'm curious if I'm leaking somewhere because I had the PW TMIC on and it was only pushing 7psi!
Old 03-29-2013, 07:37 PM   #8
Anubis80
Member#: 341903
2016 STi
Hyperblue
Yea sounds like that could be one issue for sure
Old 03-30-2013, 12:32 PM   #9
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Yeah you really have to learn how to bolt up that IC. (I have tuned guys with the knock off version and they can be BOOST LEAK CITY!)
Old 03-30-2013, 02:06 PM   #10
Myth21
Member#: 246851
2007 UGM
2012 LR
Can you check my updated log, thanks
as for the PW, I ordered some tbolts.
Old 03-30-2013, 03:04 PM   #11
Cobb Tuning
Member#: 4803
Hey bud, these logs actually look great! What are your concerns exactly?
Cheers
Lance
Old 03-30-2013, 04:20 PM   #12
Myth21
Member#: 246851
2007 UGM
2012 LR
Lance, I'm curious on the 7.00 AFR correction and the 1.04 knock corrections. I'm a rookie to tuning in general so any irregular number looks off to me.
Old 03-30-2013, 04:42 PM   #13
Cobb Tuning
Member#: 4803
The "-7.81" correction is occuring under a transient condition -- you're pressing the throttle getting ready to make a run. It's entirely normal to see changing corrections during those times...nothing to worry about there, totally business as usual.
The FBKC occured either while taking the first log, or even before that. By the time you took the second log, the noise that the ECU heard previously did not occur again, and the ECU has begun learning back to zero. Also normal and nothing major to worry about If you see persistent FKL or FBKC greater than -2 degrees, that would be a good cause for further inspection.
Your car appears to be running great Have fun out there and be safe!
Cheers
Lance
Old 03-30-2013, 04:50 PM   #14
Myth21
Member#: 246851
2007 UGM
2012 LR
Cheers
Lance
Thanks~
