Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-03-2006, 12:24 PM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default H6 3.0T Tuning, Phase 1 Ė Low Boost Pump Fuel
Since this is an update, but about a different car, I thought I would start a different thread. As most of your know, we put a second H6 into my 2002 WRX recently. I finished up the 1000 mile breakin with a total oil consumption from driving it the first mile of about Ĺ a qt. I was very pleased with the breakin, and the motor runs very smoothly. In an effort to share with the community, Iíll post up not only power, but AFR, timing, and boost datasets.
This is a stock H6 motor except for the addition of Supertec Forged H6 8:1 CR pistons. The stock valve train components are a very limiting factor in pushing the motor, so this initial tune is just to help develop maps. The motor will be pulled out in the next few weeks for internal upgrades. Part of the reason I went ahead and built the car up with the existing motor was to help us build up a list of the work required, custom components, special parts, etc.
The Turbo currently on the car is a GT30R 52Lb with a 0.82 A/R Turbine side. Injectors are modified blues (~810ccs each), and the intake manifold is the first gen H63.0 manifold. FMIC is a modified Perrin, EM is the Hydra-H6.
Given the valve train limitations (the exhaust valve springs are only 15 lbs), I didnít want to push the boost up above 14psi. I started at about 8psi, which quickly netted about 330whp. Upping to 10psi netteted 370whp, and 12psi over 400whp. At about 13psi, I was able to get ~420whp and about ~400 ft-lbf torque. I was very happy to get 400whp at only 12psi on pump 92 octane without the motor even breaking a sweat. At this low boost level, I could run AFRs anywhere from 11.1 to 12.5:1 without knock.
Here are a few data plots to show how the tuning went:
This plot shows the boost, AFRs, and Ignition Timing. With the dyno load at 12 seconds, complete spoolup occurs just past 3000 rpm. As you can see in the graph, you get almost 8psi at 3000 rpm, and 12psi at about 3300. AFRs at the lower end start out in the high 12s, run around 12 in the midrange, dipping to around 11.2 uptop. Timing goes down to about 11, and rises to about 17 at redline. The small cylinder bore is apparent in the timing needed for good power.
Here you can see the injector duty cycle, boost, and knock levels. With a peak injector duty of about 55%, 100% duty would be in the theoretical 730-750whp range.
Here is a look at the 30R at about 12psi compared to a GT30R .82 on a 2.5L STI at about 17psi, both on pump fuel. Note that at 3000rpm, there is a torque difference of 62 ft-lbf.
Here is the H6 with a bit more boost (12.5-13psi) compared to a GT30R .82 on a 2.5L STI at about 18-18.5psi, on pump fuel. Torque difference at 3300 rpm is 75 ft-lbf, and horsepower breaks 400 at 5000 rpm.
As I was tuning I did run into one problem however. At boost levels above about 8.5psi, I would get a misfire right around 3400 rpm. At first I thought this was related to the lift (which was set to turn on at 3500rpm), however further investigation proved that assumption false. The car would routinely misfire between 3300 and 3400 rpm, if the boost in that region was above 8.5 psi. If I tapered the boost so it came on later, the problem would not occur. The problem seemed unrelated to timing and AFRs. I ran that exact spot anywhere from 10.8:1 all the way to 13.5:1, and the misfire still occurred. Timing changes also made no difference We saw a similar problem on Jeffís car, but incorrectly assumed it to be the lift engagement.
I did, however, experiment with lift engagement at a number of different rpm points. See the graph below:
In this graph, there are 4 pulls.
Pull 1: (red) Lift set to 3000rpm. You can see the lift kick in, and torque output drops significantly. Clearly even though there is significant boost at this point, more torque is produced with the lower lift.
Pull 2: (green) Lift set to 3500rpm. Right at 3500 rpm, you can see the dip at the lift kicks in. It seems pretty close, but perhaps just a bit early. Notice the green is the highest between 3800 and 4000.
Pull 3: (blue) Lift set to 4000rpm. You can see the torque advantage over the green from 3500 to about 3800. Above 4000, green and blue are nearly equal.
Pull 4: (purple) Lift set to 4500rpm. Again you can see the crossover at 3800, and significant torque difference above 4000.
From the above runs, the ideal turn on point appears to be around 3800 rpm, which funny enough is what my butt dyno picked on the road a few weeks ago while I was breaking the car in.,
There are a few other weird datapoints to go with the above data. First, the misfire did not happen in the first run case. If the car passes 3400rpm at high boost with the lift on, there is no misfire. Unfortunately, having the lift turn on at 3000 rpm causes the blow off valve to go off and the torque dives when the lift kicks in. With the lift turnon at 3800, there is still a slight misfire at 3400 rpm. While I do not yet know the complete reason, it may be related to the valvetrain springs, which are very very weak. Once we get a motor with the new valve springs back on the dyno, we can confirm this. I suspect the cam and lift design never intended there to be positive boost.
Lastly, here are few snapshots
Engine in car.
Engine in car.
Car on Dyno
Car on Dyno
Jeff Sponaugle
PDXTuning is offline   Reply With Quote
Old 07-03-2006, 12:24 PM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Benís H6 turbo Legacy under construction.
Ben at his favorite place, the welder.
Old 07-03-2006, 12:53 PM   #3
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Sweet!!! Looks like its coming along. We may have something here at the shop that you may be interested in. Shoot me a PM for details.
Keep up the good work as always!!!
-Matt
ShaggyGT is offline   Reply With Quote
Old 07-03-2006, 12:56 PM   #4
pdxsilverwrx
Member#: 54935
Looks very promising Jeff. I have no plans of going this way but innovation is almost always a good thing.
pdxsilverwrx is offline   Reply With Quote
Old 07-03-2006, 01:07 PM   #5
RedlineFl
Member#: 99842
Nice!! 400+whp at 13psi thats like heaven.
RedlineFl is offline   Reply With Quote
Old 07-03-2006, 01:19 PM   #6
roo21
Member#: 108112
05 wrx
Crystal Gray Metallic
wow awesome project you have going there!
roo21 is offline   Reply With Quote
Old 07-03-2006, 01:31 PM   #7
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
The Smurfs Called. They want there turbo back.. Time for a 4088RL!
Great job Jeff! Must feel nice on the road.
Clark
AZScoobie is offline   Reply With Quote
Old 07-03-2006, 01:48 PM   #8
slvr02scooby
Member#: 86628
2002 WRX EJ257
COBB Tuning Surgeline
Very nice Jeff! 400whp at 13psi...mmmmm.... Any chance it'll be back on the dyno this week? I'd like to come see it in action!
slvr02scooby is offline   Reply With Quote
Old 07-03-2006, 01:53 PM   #9
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
how much more does this all weigh compared to a ej207, or ej257?
car_cursed is online now   Reply With Quote
Old 07-03-2006, 01:53 PM   #10
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Clark
HAHAAHA.. Yea, 30R is pretty small for this guy, but it does feel great around town! We are working on the twin scroll manifold right now for the 40R, which I hope will work out well.
It's nice just to have my car running again, and the extra displacement doesn't hurt either!
Jeff
Old 07-03-2006, 02:03 PM   #11
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Nice, just one question for Jared.....Can I have those headlights?
Oh, did you ever find out about the mainshaft and 2nd gear for me? Please send me an email at, Pacobeagle@bellsouth.net
Pacobeagle is offline   Reply With Quote
Old 07-03-2006, 02:17 PM   #12
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
dual dtec solenoids? hmmm...
anyway, good job! could an H6 equipped WRX/STi be the Supra Killer???
def
dug-e-fresh is offline   Reply With Quote
Old 07-03-2006, 02:29 PM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thank you for your honesty and candor.
i found the data wrt valve lift very interesting.
ken
Old 07-03-2006, 03:50 PM   #14
ryanpietro
Member#: 101803
2005 gt35r sti
blue
that is amazing imagine a gt40r at 20psi.
ryanpietro is offline   Reply With Quote
Old 07-03-2006, 04:30 PM   #15
jemar2169
Member#: 88786
2004 wrx
platinum silver
i was messing around and found out that all you need to do is run 32.5 psi of boost and maybe c16 you will be around the thousand hp range, good against ams!
jemar2169 is offline   Reply With Quote
Old 07-03-2006, 05:00 PM   #16
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Jeff,
Congratulations, those are really impressive numbers for only 13 psi.
On the topic regarding your misfires are you running AVCS?
If yes you may have it set too aggressively. If set with too much solenoid duty the car will misfire badly around that area. The amount of duty you can get away with totally depends on the head package and cams. For instance I cannot run anywhere near the AVCS duty cycles with my current cams as I could with stock. Also if you are running the AVCS solenoids in low frequency switch over to high frequency for a quick test.
Also your dwell settings may be off. Iíve spent lots of time fine tuning the dwell on these cars and less is better with the newer coil packs. We have run the stock system to nearly 700 whp and dwell wanted to be very low not high.
I honestly suspect itís an AVCS issue as thatís where my current setup misfires with too much AVCS advance. Let me know if you need any feedback.
Good luck!
Thanks,
Phil Grabow
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-03-2006, 06:44 PM   #17
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Originally Posted by Element Tuning
Jeff,
Thanks,
Phil Grabow
Thanks for the input Phil. The AVCS is not hooked up at all right now, so the cams should be stuck at zero. After some more experimentation, I can confirm that if the lift is active, it never happens. I remember when talking to Supertec about the springs that he commented that the low lift valve spring was very very light, something like 20lbs, while the higher lift was much more.... It could be related to the low lift springs not being strong enough...
I will, however, hook up the AVCS and play around with it some. I meant to get it wired up, but just didn't get around to it yet. I'll play with it and let you know.
I love the hydra btw. The tuning has been fantastic, and MAP based rocks. I'm hooking up my water injection to the hydra right now in fact. We are going to convert Tims 596whp GT37 to the Hydra as well.
def
Yea, I ran two solenoids on the 35R with the 2.5, but I still need to plumb the second one for this setup. Since in the final config I will be doing the twin scroll 40R with two wastegates, I'd need 4 solenoids to do the same dual config per wastegate!
Anyways, I've got to get back to the wire mess in my car, as I am tring to clean up some of the excess wires that have accumulated over the years.
More dyno data later, as I am going to run some VP109 and see if there is more power to be had at 13psi.
Jeff Sponaugle
PDXTuning.com
Old 07-03-2006, 08:31 PM   #18
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Great posts as always, Jeff. Thanks!
WRXRallyBlue is offline   Reply With Quote
Old 07-03-2006, 08:38 PM   #19
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I have wood.
modaddict is offline   Reply With Quote
Old 07-03-2006, 08:50 PM   #20
happasaiyan
Member#: 37731
wow. 13psi at 3250 on a 30R .82...with AVCS off...and weak springs. wow.
happasaiyan is offline   Reply With Quote
Old 07-03-2006, 08:58 PM   #21
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
awesome project and even better right up as usual!
wrxtremeWGN is offline   Reply With Quote
Old 07-03-2006, 09:13 PM   #22
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
awesome write up!
these H6 Turbo build ups are like reading history in the making.
its amazing the car is making so much power at such a low boost, those two extra cylinders do wonders.
kevinh211 is offline   Reply With Quote
Old 07-03-2006, 09:19 PM   #23
Freon
Member#: 88322
2009 BMW 135i
Pretty neat. Wow that timing is low! That's a good 5-6 degrees behind a EJ257 which I would even assume has a better head.
Freon is offline   Reply With Quote
Old 07-03-2006, 09:45 PM   #24
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Yea, the cylinder bore is much smaller (89.2mm compared to 99.5mm). Usually smaller bore motors need less timing, so this falls inline with what I would have expected. I'll drop in some race fuel and see if more timing gains anything.
Originally Posted by kevinh211
awesome write up!
Yea, looking at it in terms of power per cylinder/rod, 400whp/6 cyl is 66whp/cyl, which is equivilent to 264whp on a 4 cylinder. So the power on each rod and piston is not too bad.
Jeff
sponaugle is offline   Reply With Quote
Old 07-03-2006, 10:39 PM   #25
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Is the blue silicone hose around the oil filler neck functional?
jblaine is offline   Reply With Quote
3.0 H6 into 95 Impreza: Phase Two, Wiring anders8 Subaru Conversions 56 02-20-2015 04:31 PM
need advice on how i should change my tune to run low boost on a v34 in my fxt andy87t2 Open Source Reflashes 6 04-12-2009 09:12 PM
Cosworth Engined STI with Dyno Flash Pro Tune - huge low boost pump gas power Dyno Flash Proven Power Bragging 30 10-30-2006 10:37 AM
Hesitation @ high RPM, low boost, and Fuel Cut K.Linchpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-17-2006 10:07 PM
Cobb Tuning Phase 1.....hurtful? Midnightman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-12-2001 12:14 PM
