Old 07-03-2006, 12:10 PM   #1
scoooby04
Member#: 119152
Default AP Stg2 HWG 04 WRX Datalog. Help please?
Here is a datalog of my 04 wrx.
Mods:
stromung 2.5" turboback (flat plate, high flow dp cat, 3rd cat delete)
gutted stock uppipe
cobb AP Stg2 HWG 93 1.30
I've never been able to hit target boost on stg 1 or stg 2. I've been planning on adjusting the watgate arm, but figured I would post a log to see if there is anything else that could be wrong.
This is a 3rd gear pull on a very humid >90%, 83F day around sea level.
Code:
time....rpm....tps..timing..speed(KM)..knock..inject..boost....wg..vent....IAM....load
1182	3488	37.65	24	73	9	11.26	7.69	48.24	0	16	2.91
1352	3531	39.61	23	73	9	12.03	8.561	52.94	0	16	3.06
1522	3599	42.35	21	73	9	12.8	9.576	54.12	0	16	3.16
1692	3671	45.1	21	76	9	13.06	10.012	56.08	0	16	3.25
1863	3729	49.02	20	76	9	13.82	10.302	57.65	0	16	3.31
2033	3750	53.73	20	76	9	14.34	10.882	60.78	0	16	3.41
2203	3876	61.57	19	79	9	15.1	11.318	63.14	0	16	3.53
2373	3945	71.37	18	79	8	15.87	11.898	67.84	0	16	3.66
2544	3985	78.43	18	83	8	16.64	12.333	67.84	0	16	3.72
2714	4069	94.12	18	83	8	16.9	13.059	73.73	0	16	3.75
2884	4144	100	18	83	8	17.15	13.204	83.14	0	16	3.78
3054	4223	100	17	86	8	17.15	13.639	86.67	0	16	3.84
3225	4281	100	18	86	8	17.15	13.639	86.67	0	16	3.84
3395	4371	100	18	86	9	17.41	13.784	86.27	0	16	3.84
3565	4456	100	18	91	9	17.41	13.639	86.27	0	16	3.88
3735	4515	100	19	91	10	17.41	13.639	86.27	0	16	3.88
3906	4584	100	19	91	10	17.66	13.784	86.27	0	16	3.84
4076	4644	100	19	95	10	17.92	13.784	85.88	0	16	3.91
4246	4765	100	20	95	11	18.18	14.075	85.88	0	16	3.91
4416	4832	100	20	100	11	18.18	14.22	85.88	0	16	3.94
4587	4886	100	20	100	11	18.43	14.365	85.88	0	16	3.94
4757	4947	100	21	100	9	18.43	14.51	85.88	0	16	3.97
4927	5040	100	18	105	7	18.43	14.51	85.88	0	16	3.97
5097	5147	100	18	105	6	18.69	14.365	85.88	0	16	3.97
5268	5201	100	18	105	5	18.69	14.22	85.88	0	16	3.97
5438	5223	100	19	109	5	18.69	14.22	85.88	0	16	3.97
5608	5319	100	19	109	5	18.69	13.929	85.88	0	16	3.97
5778	5365	100	20	109	6	18.69	13.929	85.88	0	16	3.94
5949	5462	100	20	114	6	18.69	13.784	85.88	0	16	3.97
6119	5511	100	21	114	6	18.69	13.784	85.88	0	16	3.94
6289	5568	100	21	118	6	18.69	13.639	85.88	0	16	3.94
6459	5682	100	22	118	6	18.69	13.639	85.49	0	16	3.88
6630	5716	100	22	118	6	18.69	13.494	85.1	0	16	3.84
6800	5791	100	23	122	6	18.43	13.349	85.1	0	16	3.81
6970	5818	100	23	122	6	18.43	13.059	84.71	0	16	3.81
7140	5891	100	23	122	6	18.18	13.059	84.31	0	16	3.75
7311	5915	100	23	125	6	18.18	12.914	84.31	0	16	3.75
7481	6038	100	24	125	6	17.92	12.914	83.92	0	16	3.72
scoooby04 is offline   Reply With Quote
Old 07-03-2006, 01:24 PM   #2
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Give your WG arm a few turns then report back. It is extremely easy, easier than loading an ecu map.
MF-DIF is offline   Reply With Quote
Old 07-03-2006, 05:10 PM   #3
scoooby04
Member#: 119152
ok, ambient temps have risen to 95F. I did 2 full turns and now I'm pretty much within the 15 psi range in gears 2-4. no spiking, no flutter sound, power feels "smoother" and stronger.
now the question is, "do I do one more turn and reflash to the non HWG stg2 or leave it as is?"
Old 07-03-2006, 06:07 PM   #4
hondaeater69
Member#: 60324
why reflash? If anything just do an ECU reset after turning the WG and see where your boost settles.
Old 07-03-2006, 06:25 PM   #5
scoooby04
Member#: 119152
i dunno, i would prefer to hit taget boost without the extra WG duty cycle since a loose wg was probably the problem to begin with. I'll probably leave it and maybe reset ecu.
Old 07-03-2006, 06:28 PM   #6
hondaeater69
Member#: 60324
oh i missed the part where you said "non" HWG map. tightening the WG and the HWG map act in similar ways, you can use both as long as you're not spiking or overboosting.
Old 07-03-2006, 06:30 PM   #7
scoooby04
Member#: 119152
cool, thanks for the replies. I'll keep an eye on boost levels till it settles out.
Old 07-03-2006, 06:32 PM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Its alot easier to load the Realtime HWG map instead of doing a full reflash. On the 04 we were pretty close to target (15.1 peak), so I loaded the HWG realtime map and was hitting target exactly with no spikes.
But if you can get it to hit target with the regular map and an adjusted wastegate, go ahead and do it. I used the HWG map because it was far easier than removing the intercooler and turbo heatshield to adjust the wastegate. But yours is having an obvious mechanical problem getting to target boost.
Old 07-03-2006, 10:47 PM   #9
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
^^^No need to remove the intercooleer when adjusting the WG arm. After adjusting the WG arm a few times, it literally only takes me 5 minutes MAX to adjust the arm now (thats including removing and reinstalling the heatshield).
boundy3 is offline   Reply With Quote
Mid-range drop in powerband on Stage 1 WRX. Datalogs inside. Please help! BlackPooL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-20-2010 06:52 PM
Mid-range dip in power on Cobb Stage 1 WRX - Datalogs inside - Please help! BlackPooL Engine Management & Tuning 2 01-19-2010 10:27 PM
04 wrx transmission fluid ?, please help! Hanyoung Transmission (AT/MT) & Driveline 1 09-29-2007 08:06 PM
need 04 wrx tail lights PLEASE HELP!!! millcitywrx Private 'Wanted' Classifieds 0 03-23-2007 06:46 PM
Throttle not releasing in 1st gear after WOT, AP STG2 93oct 06 WRX ShagnRS AccessPort 50 11-25-2006 05:50 PM
