Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-18-2001, 03:42 PM   #1
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
Default Apexi ITC question
Just got my ITC yesterday, and in the install book they only have my car with the EJ20. Not the EJ25. Am I correct in assuming that I still want to use those directions?
Thanks,
Mike
Legacy GTR is offline   Reply With Quote
Old 10-18-2001, 05:07 PM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Im with you, I have been looking for info for a while..let me know how you handle this..
STiShawn is offline   Reply With Quote
Old 10-18-2001, 06:16 PM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Mike: here are ECU wiring diagrams that will work for MY97-MY98 Imprezas and Legacies with single-connector ECU:
Page 1
Page 2
Page 3
Page 4
For MY99+ models, there are corresponding wiring diagrams at ForceFed4:
2.5RS FAQ
-WaC
Wayne
wac is offline   Reply With Quote
Old 10-18-2001, 07:26 PM   #4
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
Thanks, but that only has the 1.8L and the 2.2L engines. I'll give it a shot.
Thanks,
Mike
Old 10-18-2001, 08:24 PM   #5
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
Thumbs up
never mind, I figured it out
Thanks
Mike
Old 10-18-2001, 08:25 PM   #6
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Psst... it's the same pinout.
-WaC
Wayne
Edit: I guess you found something else?
Old 10-18-2001, 08:38 PM   #7
inpreza kid
Member#: 3334
i don't know if this is right or not. for the dipswitch's i put the first one down and the rest up. the car select dial i set to 5. can anyone confirm this?
inpreza kid is offline   Reply With Quote
Old 10-18-2001, 09:05 PM   #8
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
wac-no I figured out it didn't matter.
inpreza kid-5 is right. The first one can be in either position, If it's up it won't let you go more then 5*, regarless of what it's set at. If it's down you can go to 15*.
Mike
Old 10-18-2001, 10:00 PM   #9
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
Shouldn't one of the wires go to the Engine speed(RPM) wire?
Mike
Old 10-18-2001, 11:31 PM   #10
inpreza kid
Member#: 3334
for thoes of you searching for wiring diagrams here is the instructions. it was sent to me by another fellow i-club member.
Old 10-19-2001, 01:58 AM   #11
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
The RPM wire is not needed because the ITC can calculate engine speed from the crank or cam sensor.
-WaC
Wayne
Old 10-19-2001, 02:01 AM   #12
kaos200
Member#: 2692
-WaC
Wayne
LOL, the crank (and/or cams sensors in some case) ARE what tell the ecu the RPMs of the motor
kaos200 is offline   Reply With Quote
Old 10-19-2001, 02:19 AM   #13
inpreza kid
Member#: 3334
i'm getting kinda of annoyed of the cel caused my the itc. i'm either going to pull the bulb or cut the line. i did a search and found this is a comon problem.
Old 10-19-2001, 02:28 AM   #14
kaos200
Member#: 2692
yeah it'll do that. it's a misfire code, Id put a hidden switch in so you can turn it on if ever needed and then turn it off while driving for sanity purposes
Old 10-19-2001, 08:09 AM   #15
Legacy GTR
Member#: 9316
1997 Legacy GT
14.767@93.54
That's why I'm getting an OBD-II
Thanks for the diagram, I was a little confused at the one they gave me.
Mike
Old 10-19-2001, 11:09 AM   #16
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
is that diagram good for the 99 RS ecu as well?
Old 10-19-2001, 11:25 AM   #17
inpreza kid
Member#: 3334
the diagram should be good for most if not all of the subaru's.
Old 10-19-2001, 03:04 PM   #18
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Thank you! You just saved me a HUGE nightmare.
Old 10-19-2001, 10:25 PM   #19
inpreza kid
Member#: 3334
another tip for you guys installing the ITC is make sure to pull the power source from the ecu. the ITC itself has to turn on same time as the ecu for it to work.
Old 10-20-2001, 09:22 PM   #20
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
hehe or BOOM!! just kidding... inpreza kid whered you get the ITC from...
HOK is offline   Reply With Quote
Old 10-20-2001, 11:45 PM   #21
inpreza kid
Member#: 3334
HOK. i got me itc from someone on i-club. they are a little hard to come by because apex usa stopped importing them. i think ISR might still have a couple left. if your looking for something to control your timing i think the split second TMC might be a better buy to get since it can retard timing by boost.
check it out at http://www.splitsec.com
Old 10-21-2001, 03:51 AM   #22
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
thanks dude...
split sec seems interesting... but 555 tho...
Hok
Old 10-22-2001, 02:48 AM   #23
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I am working with a company to produce a boost referenced timing controller that doesn't cause the CE lights like my APEXi ITC. The prototype is coming along nicely with ZERO CE lights, and the company is being set up so the device can go into production.
Stay tuned to my website for the initial release in a few months.
ImprezaRS dot com is offline   Reply With Quote
Old 10-17-2005, 06:50 AM   #24
markyen01
Member#: 98739
Could anybody send me the manual or install instruction of ITC?
But the system doesn't allow me to post my email....
"Members are required to make 10 posts before they are allowed to post URLs."
Or could anybody who has it leave your email and I email you later?
Thanx!
markyen01 is offline   Reply With Quote
LI: Apexi SAFC2 AND Apexi ITC Pat L.I. Private 'For Sale' Classifieds 5 01-31-2005 05:42 PM
apexi ITC manual??? bondango Engine Management & Tuning 4 06-25-2003 09:45 AM
Is anyone using an Apexi ITC on their WRX? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-01-2003 02:51 PM
J & S safegaurd and apexi ITC cvcsmkr Normally Aspirated with bolt-on Forced Induction Powertrain 16 09-02-2002 04:18 PM
Apexi ITC? racerwad Normally Aspirated with bolt-on Forced Induction Powertrain 17 04-16-2002 03:33 PM
