Welcome to the North American Subaru Impreza Owners Club Thursday September 2, 2010
Old 07-03-2006, 03:58 PM   #1
AMOS GT
Member#: 118969
Default smoked car
hi all again ......
i just boyght my 2nd rs' and the guy i bought it from was smoking ( ) inside it .
i took all the seatis out and clean the car carpet ....... but the roof top still smell like hell
got any isea how 2 get rid of this ugly smell ?
thanx .....
by the way i m from israel so any ideas about going to clean the car in near by garge .......wont help
thanx
AMOS GT is offline   Reply With Quote
Old 07-03-2006, 04:23 PM   #2
ekw
Member#: 92141
2004 WRB STi TiC,RCE
Kartboy &Cobb-Jorge tuned
was going to recommend Febreze, but the website does not show Israel.
not sure what similar products you have access to.
ekw is offline   Reply With Quote
Old 07-03-2006, 04:44 PM   #3
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
I have had good luck with rubbing wet dryer sheets in the fabric. Even take a laundry detergent that you like, powder form works best. Dilute it maybe like a 1 to 5 and used a soft bristled brush and rub it in the fabric. Usually a couple of cleanings gets all the smell out.
mike_b49431 is offline   Reply With Quote
Old 07-04-2006, 09:02 AM   #4
AMOS GT
Member#: 118969
thanx
will try the 2nd idea
Old 07-04-2006, 09:11 AM   #5
broben05
Member#: 116547
2003 Evo 3 16G WRX
If there is a detail shop nearby that offers ozone treatments try that. Otherwise Oxiclean water and a scrub brush spray on the roof scrub then use a shop vac to remove excess water. If oxiclean is not avaliable try a laundry detergant with a nice scent. Also replace the cabin airfilter if there is one. And clean the seats and carpet in simmilar fasion to roof liner. Also take a fabric softener liquid mix 3:1 with water in spray bottle and spray all fabric with that when your done cleaning.
broben05 is offline   Reply With Quote
Old 07-05-2006, 01:43 AM   #6
animes2k
Member#: 91141
2005 WRX Wagon WRB
2000 S2000 Silverstone
Do not spray anything directly onto the headliner. If you get it too wet, you will loosen the glue and have a saggy headliner. Not good.
Use a microfiber towel dampened with a 1:6 dilution of Woolite or similar "fine fabric care" detergent (1 part Woolite, 6 parts water). You don't want it wet, you want it slightly damp.
Rub lightly over headliner, turning the towel frequently and changing out the towel or thoroughly washing/rinsing/squeezing out excess water when it become soiled all over. Follow up with a dry towel to help absorb some of the moisture from the headliner.
The headliner is often the biggest source of smoke smell in a car. If, after cleaning the headliner, your car still smells of smoke, I would investigate the ozone treatment and perhaps vent cleaning. Also consider a new cabin air filter.
See this thread on Autopia for some before/after headliner cleaning pics and process:
http://autopia.org/forum/showthread....ight=headliner
animes2k is offline   Reply With Quote
Old 07-05-2006, 01:47 PM   #7
PS_REX
Member#: 109907
2006 WRX Stg2
SGM
If he smoked in the car then the vents probably blow out smokey smelling air also if he ran the A/C with recirculating air...try changing the HVAC filter behind the glove box. Some people even put in a laundry dryer sheet on top of the filter for that fresh smell, although I'm not sure how this will affect filter flow, might be worth a try. Tar accumulated on the inside of the windows and other smooth surfaces on the car's interior are probably contributing to the smokey odor, so wipe it all down.
PS_REX is offline   Reply With Quote
Old 07-05-2006, 01:51 PM   #8
audio1der
Member#: 77039
'03
opeb a jar of peanut butter and leave it in the car over night...
audio1der is offline   Reply With Quote
Old 07-05-2006, 02:04 PM   #9
disaster999
Member#: 73197
disaster999 is offline   Reply With Quote
Old 07-05-2006, 02:48 PM   #10
animes2k
Member#: 91141
2005 WRX Wagon WRB
I've heard peanut butter, an apple sliced and placed in a paper bag... really you can try that but you need to remove as much of the smell as possible - which means shampooing carpets (remove those seats), fabric, cleaning all plastic and glass, the headliner especially... lots of surfaces.
Old 07-05-2006, 07:25 PM   #11
nicmowrx
Member#: 118253
2006 wrx
WRB 382wtq361whp
meguiars odor eliminator....works great and it smells like new car..
nicmowrx is offline   Reply With Quote
Bookmarks
Smoking car CFL ChrisSpark Newbies & FAQs 1 03-09-2009 02:10 AM
New engine, smoking car only at the track chimchimm5 Service & Maintenance 0 03-02-2008 02:27 AM
Smoking in your car - Removing smoke smell from seats Paraskass Off-Topic 20 01-11-2008 01:24 PM
Another smoking car...hoping for turbo REX8 Factory 2.0L Turbo Powertrain 4 10-20-2005 09:22 PM
Smoking car. GameMastyr Normally Aspirated with bolt-on Forced Induction Powertrain 11 08-20-2003 04:16 PM
Message Board Statistics All times are GMT -4. The time now is 12:38 PM.
