Old 07-03-2006, 06:08 PM   #1
nomex ninja
Member#: 108222
2002 WRX stage-x
Midnight Black Pearl
Default TD04 Cobb St2 > VF39 + PDX map
My ass dyno says that Cobb stage 2 was significantly faster with my stock turbo, than the VF39 and PDX maps I have now. Discuss...
nomex ninja is offline   Reply With Quote
Old 07-03-2006, 06:26 PM   #2
hondaeater69
Member#: 60324
wow that sucks! my vf swap felt 10x better than my stock turbo. Do you mean just down low in power? the stock turbo will have down low power that vf turbos don't have, but the vf will MORE than make up for it once it kicks in. the vf powerband should be much much better than the stock turbo's. . .
Old 07-03-2006, 06:26 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Lag is a bitch
Old 07-03-2006, 06:37 PM   #4
nomex ninja
Member#: 108222
2002 WRX stage-x
Man, I really wasnt expect that much lag I guess.
The car used to take off with the stock turbo.
Maybe Im jumping to conclusions - the maps were written for a GP moto header, and it is still in the mail. So I havent gone full throttle yet, because I'm waiting to put that on. Iv gone probably 75-80% throttle though and Im not too impressed.
Old 07-03-2006, 06:45 PM   #5
Strng1dah
Member#: 7053
[email protected]
Originally Posted by nomex ninja
So I havent gone full throttle yet...
I wonder if that may be why...
Strng1dah is offline   Reply With Quote
Old 07-03-2006, 10:12 PM   #6
TJRCS
Member#: 59199
2008 STI
My recommendation :
1. try to downshift if you have to pass
2. rev it little higher between shift
3. get better boost controller
TJRCS is offline   Reply With Quote
Old 07-03-2006, 10:31 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You GOTTA BE KIDDING
Old 07-03-2006, 10:56 PM   #8
nomex ninja
Member#: 108222
2002 WRX stage-x
why is everyone so rude?
Old 07-03-2006, 11:45 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
WE aren't being rude----YOU are being ******
This thread is ridiculous.....in the extreme.
Old 07-03-2006, 11:54 PM   #10
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Datalog and report back before speculating. The significant increase in lag can make a VF car feel slower than TD04...but I guarantee it makes much more HP. The mid-top end is way stronger.
MF-DIF is offline   Reply With Quote
Old 07-04-2006, 03:13 AM   #11
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Damn I wish the WRX would take a diet and get some better gearing like my RS, I don't have to downshift to pass. Sure the WRX is faster (after a downshift), but it lacks the ability to be thrown around like the RS because of its weight.
Old 07-06-2006, 10:07 PM   #12
Wagun
Member#: 106433
2004 WRX wagon
How much does a two door RS weigh?
Wagun is offline   Reply With Quote
Old 07-07-2006, 09:53 AM   #13
nomex ninja
Member#: 108222
2002 WRX stage-x
I am waiting for my new computer (should be here today) so that I can log data. I am been WOT half a dozen times now, and I'm still not very impressed. I would say its just as fast with the VF39 but not faster. And yeah, the TD04 had way more grunt in the lower RPMs, and I think it pulled almost as hard at WOT.
Maybe I have an up pipe leak.
Old 07-07-2006, 09:57 AM   #14
hondaeater69
Member#: 60324
maybe the 39 you got has a cracked WG and isn't holding boost properly, there were some issues with those. What kind of boost are you seeing on the 39? Should be a nice gain over the td04 so something is def wrong with your setup.
Old 07-07-2006, 10:02 AM   #15
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
PDX map = poop
I had a vf22 pdx map and had to get a protune to get the car running right. Once i got the tune, my dyno butt firmly stated that pdx sucks and a vf22 is faster.
I was running a 11.0 afr, max boost of 17 psi, and only made 225 whp with the map.
Sausage is offline   Reply With Quote
Old 07-07-2006, 10:30 AM   #16
TJRCS
Member#: 59199
2008 STI
... I would say its just as fast with the VF39 but not faster. And yeah, the TD04 had way more grunt in the lower RPMs, and I think it pulled almost as hard at WOT...
That's called torque. How about check this comparison first.
I just made about 10wtq after switching to 18G turbo. BUT, it just pulls all the way to redline. 13T had 19psi @ peak and tapered down and 18G has 18psi all the way to redline). stock turbo just quits doing its job after 5.5k rpm. I'm pretty sure that vf39 is doing its job holding power little longer than stock one.
Old 07-07-2006, 11:46 AM   #17
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
troll?
Old 07-07-2006, 12:03 PM   #18
hondaeater69
Member#: 60324
We need to know how much boost he's running on the vf39. . .
Old 07-07-2006, 10:17 PM   #19
nomex ninja
Member#: 108222
2002 WRX stage-x
At WOT in 3rd and 4th its about 15psi. Same as it was with the TD04. I guess that seems low compared to the above posted 18-19psi. I just tried adjusting my boost control and I cant get it to go any higher. Do you think I have a boost leak somewhere, or does that seem right from a PDX base map? Pressure loss from my huge TMIC?
Is there an easy way to check for boost leak without taking my IC off and pressure testing it?
I'm stupid, humor me
Old 07-07-2006, 10:43 PM   #20
hondaeater69
Member#: 60324
15 is low even for an OTS map. IT's not from a big TMIC. There is a leak somewhere in the system, the turbo is cracked, the turbo has a weak WG, or you need a custom tune.
Old 07-07-2006, 10:54 PM   #21
nomex ninja
Member#: 108222
2002 WRX stage-x
OK, crap. Thanks though. what is the fix for the weak wastegate, I noticed that you cant adjust the arm on the VF? I will check the system for leaks tomorrow.
Old 07-09-2006, 11:02 PM   #22
hondaeater69
Member#: 60324
if the WG is weak, you can "spring" it, or get a custom tune. There is no manual adjustment on the IHI turbos. Let us know how you make out.
Old 07-10-2006, 01:33 AM   #23
F-H
Member#: 79775
What real time map are you running? When you get your maps from PDX you need to load the base map and a real time map. Maybe that might help a little. Good luck.
F-H is offline   Reply With Quote
Old 07-10-2006, 01:43 AM   #24
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
There's several folks I know that are on NASIOC that are only hitting around 15 psi in the Texas summer weather and I've heard several folks say the same comments about the Cobb Stage II vs. the VF39 Cobb OTS map as far as the low end is concerned.
Yoo Shin is offline   Reply With Quote
Old 07-11-2006, 07:36 PM   #25
GC8drifter86
Member#: 57896
try just running a VF30 or VF34 map. ive heard ppl say w/ the VF30 cobb map on a VF39 it runs great.
just wait to get protuned
GC8drifter86 is offline   Reply With Quote
have boost problem with cobb stage 2 map or PDX maps alvinli217 AccessPort 23 12-04-2008 02:59 PM
PDX VF39/FMIC Map rwdCivic AccessPort 0 03-12-2008 02:08 AM
02-03 WRX Cobb AP (v1) w/PDX Maps dlh1999 Engine/Power/Exhaust 1 06-22-2007 02:07 PM
PDX Map VS Cobb Map ender87i AccessPort 2 05-31-2007 12:20 AM
PDX Maps for 06 Cobb Stage 2 WRX sleestak6326 TXIC Private Classifieds 15 07-23-2006 10:34 AM
