Old 07-03-2006, 07:45 PM   #1
tkarabian
Member#: 85786
2004 WRX wagon
Default Finally got an AP, but I'm only boosting to 13 psi???
So I just got a Cobb AP for my 04 wrx. It's stock except for a catback. I flashed my ECU with the Stage 1 CA 91 base map. I used the AP to read my boost levels, and the highest I saw was about 13.7 psi. I did a few third gear and 4th gear pulls and thats the highest number I saw. I didn't notice a huge improvement in performance like I was expecting, but maybe it's because I'm not boosting enough? I thought a stock WRX should be boosting around 16 psi.
So, where should I start looking to fix this problem. Thanks
tkarabian is offline   Reply With Quote
Old 07-03-2006, 07:48 PM   #2
-Kevlar-
Member#: 82378
your almost in range... 14.7 +/- .5 psi...
-Kevlar- is offline   Reply With Quote
Old 07-03-2006, 07:49 PM   #3
REX8
Member#: 24038
Dont trust the AP for your boost levels...
A stock WRX s about 13.5 PSI...you should REALLY feel a difference, even if you are really a couple PSI low...
Old 07-03-2006, 07:51 PM   #4
tkarabian
Member#: 85786
2004 WRX wagon
I haven't taken it on the freeway yet, hopefully I'll see a big difference there.
Old 07-03-2006, 07:53 PM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Since it's using the stock adaptive boost control and timing authority, you will definitely see an increase in performance over the next few drives. When you first flash on the map, it starts you at half the normal dynamic timing advance and the boost control also has some learning to it as well. Soon you should be feeling quite a difference.
nhluhr is offline   Reply With Quote
Old 07-03-2006, 07:57 PM   #6
tkarabian
Member#: 85786
2004 WRX wagon
Should I be driving it carefully, hard, or regular for the next couple of days to see the most gains?
Old 07-03-2006, 07:59 PM   #7
hondaeater69
Member#: 60324
why not? the ap reads boost from the stock MAP sensor electonically, it's about as acurate as it gets (up to about 18.3 when it stops reading of course).
Old 07-03-2006, 07:59 PM   #8
Shadowdane
Member#: 92002
2014 Legacy 2.5i Ltd
Carbide Gray Metallic
yup.. when I flashed to Stage 1 it took a few days until I noticed a difference. The biggest change I noticed was how much smoother the acceleration was. Was smooth and strong all the way to redline.
Shadowdane is offline   Reply With Quote
Old 07-03-2006, 08:00 PM   #9
hondaeater69
Member#: 60324
Drive it regularly, with some spirited runs here and there.
Old 07-03-2006, 08:06 PM   #10
CapeRex
Member#: 81070
My car feels way better at Stage 1,but I'm also not seeing any higher boost than stock on my Omori gauge.
I'm happy with it,but am just curious if it should be better.The longblock and turbo are only 3k miles old,also,and I flashed it after maybe 1k on the new stuff.Could that be an issue? I didn't follow the strict 4k rpm limit during break-in this time,either.
Sorry to hijack if I did....just having a similar issue.
CapeRex is offline   Reply With Quote
Old 07-03-2006, 08:24 PM   #11
Drink
Member#: 102682
... ripper's
sister.
Gm electric boost solenoid & protune FTW
Drink is offline   Reply With Quote
Old 07-03-2006, 09:46 PM   #12
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
is this true? ive gotten the jist from reading on here that the ap boost gauge isnt worth a darn.
rotaman is offline   Reply With Quote
Old 07-03-2006, 10:12 PM   #13
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the AP doesn't have a boost gauge. It has a display that shows the car's own internal gauge.
Old 07-04-2006, 02:27 AM   #14
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
so........... is it, say, more or less accurate than a regular boost gauge. (regular meaning like the stock mechanical one)
Old 07-04-2006, 05:18 AM   #15
Satans_Rectum
Member#: 114947
ReD
You need to adjust the waste gate actuator on the back of your turbo. If you aren't reaching target boost, then the actuator arm has too much slack in it. Adjust the arm with 2-4 clockwise turns.
This thread has information that you may find vital.
Wastegate Actuator Adjustment
READ THIS INFORMATION VERY CAREFULLY BEFORE USEING IT!!!!!!!!!
Satans_Rectum is offline   Reply With Quote
Old 07-04-2006, 05:53 AM   #16
fatgroundhog
Member#: 44942
I wouldn't mess with the waste gate actuator until you KNOW that is the problem. It is too early for that. Over the last few years, many of the people who have tried to adjust theirs end up going back to stock with it in the end. It just seems to create problems.
fatgroundhog is offline   Reply With Quote
Old 07-04-2006, 08:19 AM   #17
-Kevlar-
Member#: 82378
NO!!!!!!!! not yet. give it time to learn...you are only .5 psi away from target.
Old 07-04-2006, 09:22 AM   #18
eatus ravenous
Member#: 26068
1, you are running it on the 91 octane map. do you have access to better gas ?
2,you should definately be feeling a differance no matter what . although it should get better as the ecu learns try the vishnu ecu reset for timing advance .
3, your expectations of what stage 1 were mostlikely too high
4, you could allways try the HWG map from cobb
eatus ravenous is offline   Reply With Quote
Old 07-04-2006, 12:49 PM   #19
hondaeater69
Member#: 60324
Given your stock MAP sensor is in working order, the AP read out of live boost WILL BE more acurate than a mechanical boost gauge.
Old 07-04-2006, 12:57 PM   #20
geargrinder
Member#: 114491
2014 STI 5 door
you are running the "CA 91" map. I think that Cobb lowered the boost levels for the California maps. I am running Cobb CA stage 2, My car (06 WRX) spikes at around 14psi, seems to be a consistent 13.4psi otherwise.
geargrinder is offline   Reply With Quote
Old 07-05-2006, 11:32 PM   #21
ThrawlWRX
Member#: 55878
2013 GR LTD & 03 GD
SWP / PSM
I have an 03 stg 1 91 CA map, my AP reads 14.5 psi. My manual boost gauge reads a hair over 15 psi. But I was getting some boost creep while stock, probably due to the exhaust... (3" borla cat back, IC hoses, pulley, 0 ga wires, stock box W/snorkal)
ThrawlWRX is offline   Reply With Quote
Old 07-06-2006, 09:01 PM   #22
WrxSlvrWgn
Member#: 51799
03 wrx wagon
Make sure you have reset your ecu using the AP at least once and then let it learn doing a few 3 gear pulls. Use your foot on the brake if you need to get the boost maxed w/o gettting up to high reckless speeds. Unless you have a very safe place to run. Try not to get into boost after resetting your ecu until your get to do the 3rd gear pull up to redline if possible. Be safe use a friend to watch boost if you have no gauges
WrxSlvrWgn is offline   Reply With Quote
Why is my turbo only boosting to 8 psi? Hyelude Newbies & FAQs 21 07-23-2009 12:52 PM
Only boosting 5-6 psi!? niblick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 11-16-2007 12:08 PM
Only boosting 5-6 psi... niblick General Community 7 10-29-2007 11:13 PM
Only Boosting at 7 psi!! kmwrx224 AccessPort 12 10-16-2006 01:34 PM
Finally got my UP! But have DP question. the_poser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-14-2006 08:59 PM
