Old 07-04-2006, 02:11 AM   #1
73bug
Member#: 87182
73 volkswagen
black/silver
Default EJ22 best power mods???
so i have an EJ22 with a bad rear main so im going to rebuild it. ive read some of the stuff about how "universal" all the EJ series parts are. i was just wondering what you guys think are the best ways to make more hp out of the stock 2.2 block.
thanks in advance,
Ben
73bug is offline   Reply With Quote
Old 11-29-2011, 05:15 PM   #2
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
would greatly love to hear advice on this as well. so bringing up an old post. bumpitybump
ScootSpecs is offline   Reply With Quote
Old 11-29-2011, 06:38 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Big turbo. big injectors, big fuel pump, big cams, big FMIC, big gears, BIG tune...high octance fuel....
where did you want to stop?
FuJi K is offline   Reply With Quote
Old 11-29-2011, 06:42 PM   #4
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
EDIT - jesus, I see this is a 5+yr old thread that ws bumped today. oh well, ScootSpecs and others may find it useful I guess.
EJ22 or EJ22T?
If EJ22, then look into the frankenmotors built with EJ25 bottom ends and the EJ22 heads (and all sensors, etc..).
I want to build a new motor for my Vanagon (that I swapped a EJ22E motor into) with a EJ257 block. The Sti SB mated with the EJ22 heads yields ~10.3:1 compression and puts out a good amount of torque (more displacement, higher compression, small ports).
If it's a 22T - then see Fuji above^^
Farfrumwork is offline   Reply With Quote
Old 11-29-2011, 08:15 PM   #5
3MI Racing
Member#: 200987
EJ22NA, I'd just toss in an EJ25 engine. Cheapest bang for the buck upgrade. If you want to make more than just 'perky' power...well I'd start with a turbo motor swap.
3MI Racing is offline   Reply With Quote
Old 11-29-2011, 08:55 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
^^ I would do that instead.
Crap-on-a-cracker what a zombie bump.
~Josh~
Old 11-29-2011, 09:00 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
No reason to dive into an engine build if you can get the same or more power out of the junkyard
Old 11-30-2011, 11:05 AM   #8
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
I was talking about the EJ22 N/A, currently powering my 97 GM4
And I'm interested in best bang for the buck, seems like EJ25 swap is the way to go. My previous vehicle was a 98 Forester, and I loved the grunt of the 2.5, I bet it would be even better pushing 300 less lb or so.
In the meantime I'm thinking Stromung high flow cat, and Perrin lightened pulley, would these mods give me any noticeable results?
Old 11-30-2011, 11:29 AM   #9
Pinned
Member#: 152707
The cat probably won't do much, the pulley will give you a bit quicker rev up so rev matching should be easier.
Pinned is offline   Reply With Quote
Old 11-30-2011, 05:24 PM   #10
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
in that case I think I'll just put the money towards a future ej25 transplant
she is also an auto, so rev matching is very easy
Old 11-30-2011, 06:52 PM   #11
Farfrumwork
Member#: 10202
'07 Spec B
Engine build (2.5 block with 2.2 heads) in this case means no additonal wiring/sensor work.
The EJ25 swap would involve more than just tossing in the motor, right?
Not being an ass here, and granted I have not built a 25/22 frankenstein, but it seems like 6 of one and holf a dozen of the other... maybe the later 2.2's are setup better for a 2.5swap(?)
The 2.5l (no mater how you get there - either way is cheap) will be noticeable in your relatively light car.
pulley and a cat will not be noticeable.
And auto? For more "pep" you may consider a 5spd swap (or a car with a 5spd in it already)
Old 12-02-2011, 05:32 PM   #12
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
Thanks for the advice, I'm really digging this 2.5 block with 2.2 heads idea. I'll look into that some more. What else would I need to do the swap, besides the 2.5 block?
In the meantime I just had a 3A Racing straight thru muffler installed yesterday and lovin it, noticeably louder without being obnoxious, plus shaved off 12lbs to boot
Old 12-02-2011, 07:03 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
A '97 eh. that has them 40cc heads I believe.... drop in a '99-01 SOHC EJ25 NA shortblock and use your heads. It'll bump up compression quite a bit and you should have some grunt!!! You will likely have to run 93oct to keep det down.
Old 12-02-2011, 07:17 PM   #14
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
You'll need the 2.5 head gaskets. I believe everything else is the same. Plan on running premium at all times and keeping up on intake system maintenance.
cal_look_zero is offline   Reply With Quote
Old 12-02-2011, 11:44 PM   #15
ballitch
Member#: 74907
98 cam'd EJ251
I think your motor has the idle control valve on the intake manifold, instead of on the throttle body. This means you can literally swap in an EJ25D with only swapping your engine harness over to the EJ25D intake manifold, and swapping exhaust manifolds as well.
That would be the quickest and the easiest, not to mention cheap. If you can find one at a junkyard, you can rebuild it in your garage on your own time.
~Josh~
Old 12-03-2011, 12:00 AM   #16
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
Raised compression and running premium would be no prob, and the idea of extra grunt just has me wanting this more and more..
Thanks for bringing this thread back to life folks
Few more questions: will my stock 4spd auto handle the extra power? I like auto (daily) and don't plan on swapping to 5spd. I do plan on installing a transmission cooler.
so as far as electronics go, I can use all my stock fuel sys/ecu/injectors? if so this swap sounds like total win
Old 12-19-2011, 11:32 AM   #17
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
EJ22 or EJ22T?
So I have been looking but cannot seem to find this "frankenmotors build", could you maybe show me the thread?
Old 12-19-2011, 11:42 AM   #18
ScootSpecs
Member#: 256739
1994 Legacy TTWagon
Dark red
scratch that, I think I found it, this one here?
http://forums.nasioc.com/forums/showthread.php?t=631527
Old 12-19-2011, 12:20 PM   #19
EmaciatedCow
Member#: 170373
98 Forester
15 wrx pshhh
nothign wrong with building the ej22e.. depending what year, you can get a #5 thrust bearing block. essentially a big bore ej205. im about to assemble the bottom end on the one im using for my gc hillclimb car.
EmaciatedCow is offline   Reply With Quote
My EJ22e+205heads powered WRX Lives thorne Built Motor Discussion 5 02-17-2010 02:09 PM
Next best power mod after Stage2? aboogabooga Newbies & FAQs 36 10-30-2008 11:42 PM
FS: 04 STi, $26.5K, -power mods, +tech mods (Seattle) tails Private Vehicle 'For Sale' Classifieds 0 06-30-2006 04:36 AM
best power mod for 200 bux nomadtw Normally Aspirated Powertrain 27 03-11-2005 10:27 AM
('93-'01) what is the best power mod to do first for a MY99 RS? aarneson Impreza Forum 2 05-21-2001 08:37 PM
