Old 10-18-2001, 05:05 PM   #1
chuckles
Member#: 2955
02 Chuck Wagon
Oh yea its white
Question brakes and Warranty?
I am hearing a squeal in my brakes but only when I hold the Brake pedal at a certain position. any ideas what this could be and if it's covered in my Warranty?
Thank you
oh yeah and my trunk release handle no longer works, but the key in the trunk works.
chuckles is offline   Reply With Quote
Old 10-18-2001, 09:54 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Brake squeal/howl/etc is not covered under warranty since it's considered "normal."
With respect to your trunk release problem, it sounds like you've "cancelled" the trunk release switch (see the following diagram).
Jon [in CT] is offline   Reply With Quote
Old 10-18-2001, 10:09 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Just realized that the "etc." above was too general. If you hear a metal-on-metal scratching sound, that's probably your brake pad wear indicator scratching on the brake rotor. It means your brake pads have worn down and need to be replaced (as a pair - both fronts or both rears). However, this, also, is not a warrantied item.
Old 10-18-2001, 10:53 PM   #4
jamz
Member#: 8725
2013 Black Company
Annalist
Interesting. I wonder if it would be a warranteed item if they wore out in a few months. PRobably not, they might just assume you've been at the track with 'em.
jamz is offline   Reply With Quote
brake pad warranty Jkhak Warranty Issues & SOA Problems 16 07-17-2007 07:40 PM
2005 Subaru Brakes Under Warranty? roback7 Warranty Issues & SOA Problems 5 04-23-2007 06:15 PM
Brake pad warranty totald Texas Impreza Club Forum -- TXIC 8 09-15-2004 09:36 AM
brake pads warrantied? Horten Service & Maintenance 25 08-01-2004 12:45 AM
warranty covers brakes and clutch? Mike Wevrick Warranty Issues & SOA Problems 15 04-28-2004 10:14 PM
