Old 07-05-2006, 04:38 PM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default Where does the ECU Ground? LC-1 related.
I'm installing my LC-1 WB and need to run the ground to the same ground as the ECU. Does anyone know if the ECU is grounded to the body or the engine? I tried searching, but couldn't find anything. How did everyone else hook up their LC-1? Did you use a relay for the heater wire or just tap it into an ignition on wire? Thanks
06rexwagon is offline   Reply With Quote
Old 07-05-2006, 05:38 PM   #2
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Subscribed
Valhakar is offline   Reply With Quote
Old 07-05-2006, 08:12 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The ECU is grounded to the chassis right where it bolts in under the passenger carpet.
nhluhr is offline   Reply With Quote
Old 07-05-2006, 08:21 PM   #4
Spiider
Member#: 13680
The motherboard has two ground planes on either corner of the case near the front where the plugs go in. If you connect to one of those two spots you should get a common ground.
Spiider is offline   Reply With Quote
Old 07-05-2006, 09:22 PM   #5
06rexwagon
Member#: 114730
[email protected]
Thanks! Now I can get it installed and get to the business of tuning.
Old 07-06-2006, 09:32 AM   #6
Valhakar
Member#: 39514
Mostly Blue
Nice. I might have to run a ground wire from the corner to the engine block.
P0037 W/ LC-1 NB Emulation; What does the ECU want to see? lil'redwagon Engine Management & Tuning 18 04-10-2010 05:07 AM
Where does this factory ground point go? Vysirath Service & Maintenance 0 01-17-2006 07:39 PM
Cant tell from the picture in the manual. where does the engine ground go? MrSaabaru Subaru Conversions 3 08-15-2005 10:43 AM
Does the ECU in 90-93 legacies ground where it's mounted? d4d4d4d4 Legacy Forum 5 07-30-2003 06:41 PM
where is the ecu? yes, this is air fuel meter related! Dane Technical Forum Archive 1 05-08-2000 03:42 PM
