Old 10-18-2001, 08:24 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default Wierd Fuel Delivery
I'm seeing some rather interesting fuel pressures as of late. In the morning, I am seeing fuel pressures of about 37.5psi. That is rather unusual since I have a stock FPR and a 255lph fuel pump. Until recently, my fuel pressure was about 49psi. Before I did the fuel rail mod, I had ~50-51psi though it dropped a couple psi after the mod. Currently, my car will warm up at 38psi and drive around town at that pressure. But, once I jump onto the freeway, the pressure will rise up to 45-47 (lower than it was previously). Any ideas?
The other part of this, though I'm not sure it's related, is my idle is now a hair under 500 rpm (closer to 400) and the car is idling a little rougher. I haven't checked to see if I have a leaky gasket since I removed the intake manifold, but it is something I plan on checking.
-Jon
www.nothingserious.net
Old 10-18-2001, 11:09 PM   #2
kaos200
Member#: 2692
Default Re: Wierd Fuel Delivery
Jon, you DO realize that the first mark on the Tach is 500RPM right?
It wont idle at anything less than that.
kaos200 is online now   Reply With Quote
Old 10-19-2001, 02:40 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Maybe the diaphram in the FPR is made of a material that causes lower pressures when it is colder? It has been getting a lot colder lately...
Old 10-19-2001, 08:51 AM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Jon does this mean you have your turbo on finally?
Scoobyslack1 is offline   Reply With Quote
Old 10-19-2001, 09:04 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Haha, no turbo yet . I am trying to correct my fuel system first.
It's a definite possibility that my FPR is dead. Guess it's time to see if I can locate the SVX FPR. For some reason, my fuel delivery has never quite been on par with others' with a high flow fuel pump.
After looking at my tach again, I do see what you mean kaos200. I guess the car usually idles at 750 and it is now idling around 650 or so. Either way, its not idling quite as high as it was before.
Thanks for the ideas.
-Jon
Old 10-19-2001, 12:21 PM   #6
Delicious Tuning
Member#: 1990
Question
When was the last time you reset your ECU. I am not saying to reset it, but I am just curious if your ECU might be learning and dropping the fuel delivery from the Walbro Fuel Pump. Doubt it though.
In any case that is kind of interesting. I wonder if the cold does it affect it that much?
~Bill
Delicious Tuning is offline   Reply With Quote
Old 10-19-2001, 12:23 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'll try resetting the ECU but I doubt it will do anything either. I have had the pump in there for over 6 months and it is only now acting up. Only things different are the cold and the parallel fuel rails.
-Jon
Question EGTs, Fuel Delivery and Timming control? Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-31-2002 10:14 AM
Explanation of Fuel Delivery - Long RigdenZW Normally Aspirated Powertrain 19 11-20-2001 04:01 PM
Good books on engine fuel delivery and tunning, transimissions etc.. WRXwannbe Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-23-2001 12:56 PM
Fuel Delivery Question MoeRS Normally Aspirated Powertrain 1 10-21-2001 12:37 PM
GAAH! Fuel delivery problems....help! Sauginius Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-10-2001 09:14 PM
