Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-05-2006, 09:20 PM   #1
pictureboy
Member#: 85132
2016 WRX
Default ?? about reading live boost with AP
What is the highest psi the AP will read? I seem to remember somewhere it tops out somewhere in the 18psi range and will not read higher regardless of true boost level. Am I remembering correctly?
pictureboy is offline   Reply With Quote
Old 07-05-2006, 09:31 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
It's limited by what the ECU can measure. I can't remember the exact value either, but I think you're probably right about it being 18psi.
06rexwagon is offline   Reply With Quote
Old 07-05-2006, 10:41 PM   #3
tkarabian
Member#: 85786
2004 WRX wagon
18.3 says the Cobb AP manual
tkarabian is offline   Reply With Quote
Old 07-05-2006, 10:46 PM   #4
hondaeater69
Member#: 60324
IIRC it is 18.3. the stock map sensor can read higher, the limitation of the AP has to do with something else.
Old 07-06-2006, 08:41 AM   #5
pictureboy
Member#: 85132
2016 WRX
Thanks for the input. That would explain why I am hitting a max boost of 18.3 rather than the 19.5 my tuner set up for me! I was wondering what the deal was. duh!
Old 07-06-2006, 09:21 AM   #6
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
18.24 to be exact ECUExplore only logs to that unless you use the Manifold corrected pressure User defined variable.
Valhakar is offline   Reply With Quote
Old 07-06-2006, 11:44 AM   #7
benw
Member#: 103320
1998 swapped
Forester L
manifold absolute pressure FTW! (was told by Tim of PDX to always log this instead of relative)
benw is offline   Reply With Quote
Old 07-06-2006, 01:26 PM   #8
pictureboy
Member#: 85132
2016 WRX
Good info! Thanks guys! Logging was going to be my next step to find out exactly what I'm boosting, but since I just got my old PC laptop up and running I have not had a chance to do so yet so any pointers are appreciated.
Old 07-06-2006, 05:26 PM   #9
rocketrex
Member#: 117623
so you take absolute pressure minus what to find boost?
rocketrex is offline   Reply With Quote
Old 07-06-2006, 06:05 PM   #10
hondaeater69
Member#: 60324
absolute = relative (or gauge) + Atmospheric.
So it would be absolute - atmospheric = relative (boost in PSI).
Atmospheric varies from place to place but is most commonly 14.7.
AP read live boost limit? hettchen AccessPort 2 09-10-2007 08:30 AM
how do u read target boost with the ap ver2 ppericfe AccessPort 4 02-08-2007 06:33 PM
read live boost vs boost gauge? Kenji815 AccessPort 8 08-02-2006 05:49 AM
reading live boost with AP tech AccessPort 26 02-26-2006 11:19 PM
Cant tell if im getting full boost with AP SSsleeper96 Engine Management & Tuning 11 12-15-2004 10:17 PM
