Old 10-18-2001, 10:51 PM   #1
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Talking Got The Whitelines!! install Sat.
sooooooo,
I finally received my *standard-height* Whiteline Selects. Got 'em from Don@ PDM for an increadible $179 shipped !! Sweeeet it took a while but it's was worth it
I will be installing them myself this Sat (I have already taken the back seat and rear top bolts out - then it got dark, and I didn't have the top-hat bolts for the rear AGX's) but anyway..... I'm stoked to have a striffer - less rolllin' - standard dirt-road-height machine in my hands!!!!
I anm actually pleased by the color of the Selects - not as bright as I was thinking. not that it matters much, but a nice grey-blue.
I can give a reveiw after I get the alignment back in and have a chance to really Drive it. (it's gonna snow any day now too... so I gotta get it all donme so I can run it on my now race-depth RE730's before I put the M2's on).
other suspension mods include a FHI 18mm rear sway bar.
later,
Chad
aka. Farfrumgerman
Farfrumwork is offline   Reply With Quote
Old 10-19-2001, 12:54 AM   #2
jacobhorn
Member#: 5122
1998 Legacy GT LTD
'02 HD Softail Deuce
Arrow
Congrats! I am anxious to hear how the install goes. I will be receiving my -3/4 inch Whiteline lowering springs soon and I have not yet deciede whether or not to install them myself. Please post pics when you are finished. Have fun!
jacobhorn is offline   Reply With Quote
Old 10-19-2001, 10:15 AM   #3
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Please post the gory details on the install. I am going to be dropping my Outback with regular Legacy struts sometime in the next month or so. I have done struts before, but not on a Subaru...
Thanks, Doug
dvancleve is offline   Reply With Quote
Old 10-19-2001, 11:58 AM   #4
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default Gory Details Yes!!
Count me in as very interested in this swap as well! Finally got my WhiteLines from Don also, and am ready to do the Springs/AGX swap, but was hoping to do the stainless lines too, as long as I had everything apart. Come on Cobb!!
Chad, Please share as much detail as you can on this swap!!
Glenn O
nuburu2 is offline   Reply With Quote
Old 10-19-2001, 12:59 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Hmmmm
I am also very interested. I was about to buy the Whitelines for my wagon, until an e-mail from them said the drop on the "standard" springs would be ~35mm all around. More than I wanted. Please make accurate before/after height measurements. I hope the drop will be 1" or less.
Doug I dont think youre gonna see much drop in your OB with just a strut swap. The springs are gonna be what you need to swap to see any real drop. I dont know what the difference is between Legacy and OB struts exactly, but you could well end up oversprung also by just swapping the struts (or the strut not even fitting at all-not extending far enough to reach the strut top mount.) Do the OBs have taller springs than the Legacys or do they use blocks? If they use a blocks maybe removing them in combination with a strut swap could get what youre looking for.
Ive been curious what accounted for the OBs higher ride vs the Legacy. Can you enlighten me?
subysouth is offline   Reply With Quote
Old 10-19-2001, 02:22 PM   #6
Mx5racer
Member#: 2629
It looks to me that the outback rides higher because of higher spring perches. If you had coil-overs you would be able to choose any ride height you wanted (within reason). You could have an outback in the snowy winter, and a slamed racer in the summer.
Chas
Mx5racer is offline   Reply With Quote
Old 10-20-2001, 10:39 PM   #7
etam
Member#: 439
www
dvancleve, I remember (correct me if I am wrong) that outback ride height does not come from spring/strut but come from new control arm design.
lowering the outback with spring/strut *might* affect the suspension geometry big time!
etam
etam is offline   Reply With Quote
Old 10-21-2001, 01:44 PM   #8
Farfrumwork
Member#: 10202
'07 Spec B
Talking GOT 'M IN!!!
All right... got it done!
It took me quite a bit longer than I had anticipated - but it was due to my own stupidity. haha. Just remember - better yet mark - where the top hats are in relation to the strut. (they are not too cooperative when going back together)
Total time was about 6 hrs. but If I could do it again it would take probably 3-4 hrs. This all by my lonesome in my carport too, if I had a helper I'm sure it would more than cut the time in half. ( and shops want ot charge for 7-8 hrs ! what a load of crap, I hope their mechanics are faster than me especially with air tools... but I digress).
as far as the installl goes - go to the "Mods" section and read through the STi suspension install for the RS. it is basically the same thing.
here are some hints though...
1) the rear top-hat bolts include one that hides under the seatbelt mechanism. it is a real PITA. A very small racheting 12mm box wrench might help here.
2) Have some xtra tools around. I broke a 19mm 1/2" drive, deep socket on the rear. As well as a 3/8" drive rachet !!
ps. a 3/4" socket works great in place of the 19mm.
3) the rears go back in fairly easily - although it is somewhat of a pain gettin' the top 3 bolts lined up (an extra person here would have been great!). The fronts sat about 1" lower than the mount holes on the struts - you will not be able to compress them by hand to get them to reach. I used the stock jack and my Al breaker bar tube to push them up a bit to align the holes. (See picture at bottom - if I can post it )
4) The front struts top hats have a very tight fit for the socket required for the 12-1.50 metric stop nut the AGX's use (that's a mouthfull) I used some Syn. bike chain lube to get in there nice and easy like.
5) when you are compressing the stock springs to take them off - compress them further than you think you need to - then compress them some more.
6) The front assembly has a tapered, pyramid style washer - in case you don't follow the last hint and can't tell how it was originally - it goes in wide side down ( yes I had to do the first front assmbly completelyover again too. I probably did the equivelent of 8 wheels worth of work -hahahahha).
REVIEW:
totally kick ass!
It is a *bit* more jarring around town - not harsh, but you can feel iregularities more. At speed, 40mph+, it is just as, if not more, smooth than the stock suspension.
This thing will absolutely RAGE into corners now. it is very neutral and controlable.
I only drove around for a bit - including playing with a freind in a '01 OBS - we drove up Flagstaff Mnt road in Boulder (it is steep and narrow, and has a couple 1st gear - very tight- switchbacks) it was awesome. I had to wait a while for the obs to catch up .
This is with the 18mm rear bar and RE730 rubber. I know... not a fair fight for the obs
LOOKS:
It looks pretty much the same. I, unfortunately, didn't measure the rear height before hand (sorry) but I did measure the front. the front was unchanged 385mm -(from center wheel to wheel well)
the rear "looks" a bit lower - maybe 10mm or so. I can only get 1 1/2 finger under there. Now it measures 350mm, using the same methd as above.
Can anyone go out and measure theirs -front an back??? just as a reference.
( I am trying to put pictures up - wish me luck)
later,
Chad
aka. Farfrumgerman
Old 10-21-2001, 01:51 PM   #9
Farfrumwork
Member#: 10202
'07 Spec B
Thumbs up smore pic's
I can't seem to post more than one at a time??
hey, I'm a Mechanical Engineer - not computer!!!!! hahahha
Rears....
Old 10-21-2001, 01:54 PM   #10
Farfrumwork
Member#: 10202
'07 Spec B
Thumbs up and more...
turn sideways to see front strut 'jack up procedure'
Old 10-21-2001, 02:00 PM   #11
Farfrumwork
Member#: 10202
'07 Spec B
Old 10-21-2001, 08:03 PM   #12
dvancleve
Member#: 5211
Thumbs up Thanks Chad!
What kind of spring compressors did you use and where did you get them? Did you use an air wrench?
Thanks, Doug
Old 10-21-2001, 08:51 PM   #13
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Arrow
Old 10-21-2001, 10:27 PM   #14
etam
Member#: 439
www
Chad, do it all by yourself, impressive!! I was at the shop for around 4hrs and waiting for the mechanics to put in V5/H&R on my GT and do the alignment. It looks straight forward WITH air tools. Cheap labour up here and I only paid C$200 including alignment
One thing though, your car looks just like what you describe, no change in front but lowered in the back (kind of tip up to me; any load in the trunk??).
later..
etam
Old 10-22-2001, 11:45 PM   #15
Farfrumwork
Member#: 10202
'07 Spec B
Thumbs up Thanks...
I used hand tools (you NEED a 1/2" rachet, as my deceased 3/8 driver will attest to)
and I used a set of spring compressors I borowed from a guy at work. They are basically a 3/4" threaded rod with a single J-hook with nut on one end, and 2 J's on the other. you have to manualy turn your springs down - it took some work.
I am still lovin' the setup, but need to take few days off of work to go drive around!! haha that would be nice - but anyway, I am going to let it settle for a week or so then get an alignment. After that I will post more reviews and pictures of each wheel gap. We will see if it changes at all? (right now I think it would be good to get the Standard rears - and the Low fronts. That might yeild an overall 1/2" drop or so. With the AGX's anyway -as I think they may raise up the perches a bit in the front?????)
Tha car is MUCH more fun to drive. it even feels faster
next up...Brullen exhaust
-Chad
Old 01-09-2002, 06:22 PM   #16
dvancleve
Member#: 5211
Lightbulb Re: Hmmmm
The Outback height comes from two things for sure: taller tires (205/70R15 stock) and struts that have high spring perches (the spring sits higher on the strut). I don't know if the springs are actually different. If anybody does know, I would love to hear about it since I am still deciding whether to do springs and struts or just struts.
Thanks, Doug
Old 01-09-2002, 10:12 PM   #17
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I've been eyeballing the poor man's coilover setup - AGXs and Ground Control height adjustable springs.
However.... I need some tires for the GT rims I just bought and it will be awhile before I have money for that. No sense in spending money buying suspension parts that won't even fit on the car with stock-size tires.
remarcable is offline   Reply With Quote
Old 02-06-2002, 05:48 PM   #18
traskw
Member#: 9604
2005 LGT '94SS MR2
AtlanticBlue, Red, Silver
Did you use stock height Legacy springs or the Impreza springs?
What other hardware was needed besides the struts, springs, and tools?
traskw is offline   Reply With Quote
Got the lip installed and took some pics Nettalp Member's Car Gallery 42 03-14-2007 05:14 AM
Finally got the VF39 installed and tuned! gotsol South East Region Forum 7 08-04-2006 01:40 PM
well I finally got the whiteline diff lock kit bolts installed... garie Brakes, Steering & Suspension 0 10-12-2005 08:41 AM
Finally got the MBC installed! H8YNERS North West Impreza Club Forum -- NWIC 4 07-05-2002 01:09 AM
Finally got the unichip installed with the new map RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 10-19-2001 10:50 PM
