View Poll Results: Can you downshift from 2nd to 1st at 15 mph?
Yes. 53 42.40%
Yes - but not without double clutching. 37 29.60%
No way. 30 24.00%
First gear grinds even when I am in neutral. 5 4.00%
Voters: 125. You may not vote on this poll
Old 10-19-2001, 02:30 PM   #26
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Space Gray with Coral Red
Unhappy
The sychros for 1'st sure are loud... Going about 15/20 mph, if I FORCE the thing back into first, even before I let out the clutch I can hear the things spinning up to speed and going nuts.
Jeff C.
ezatnova is offline   Reply With Quote
Old 10-19-2001, 02:41 PM   #27
subarurabbit
Member#: 4083
2011 OB 3.6R
Parts manager at a loacl dealer said it's bad for any Subaru to go into 1st unless at a dead stop.
Roger
subarurabbit is offline   Reply With Quote
Old 10-19-2001, 02:42 PM   #28
GOT_WRX
Member#: 7241
Originally posted by datdudedennis
how does matching revs help a downshift? i could downshift into first at 15, i just really gotta push it up hard.
dennis
There goes your synchros screaming. You SHOULDN"T do that. If the transmission doesn't let you go into first by increasing the resistance, there's a reason.
REV match(while clutch is engaged, gear in neutral) will help shifting into the first gear, and after that, it's all about how smoothly you engage your clutch completely.
I hope you don't screw up your synchro and ask for warranty work because if this keeps happening, SOA is going to do something about it. (driver's fault)
GOT_WRX is offline   Reply With Quote
Old 10-19-2001, 03:58 PM   #29
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
I can, I just tried this earlier this week. That is the only time that I have, to my recollection. If I couldn't I would take it to the dealer to look at the synchros.
SlideWRX is offline   Reply With Quote
Old 10-19-2001, 06:22 PM   #30
Cupholder
Member#: 10666
So far, the majority here states that they either can't or they can only do it with double clutching
Cupholder is offline   Reply With Quote
Old 10-19-2001, 08:41 PM   #31
Ebarb01
Member#: 11390
2002 Impreza WRX
Just so long as the revs are hight enough, I can slip it into first up to about 25, but i don't recomend it. I try to take it easy on the tranny, from what I hear they are not all that strong on the WRX.
Ebarb01 is offline   Reply With Quote
Old 10-21-2001, 12:22 PM   #32
Suba-RAW
Member#: 2831
It seems lately that even at a dead stop, unless I double clutch, I'm grinding into 1st. I usually don't go to 1st until under 5mph when coming to a stop, or after I have stopped completely. Do you think my 1st gear synchros are going/gone? Anybody have this problem and have it covered under warranty? I just hit 30k.
Hopefully I'll find out in the next week when I go in to have my CE light reset again most likely due to a "loose gas cap." I know it's off topic but does anybody know about that problem? I've been in twice and have been told the same thing, and now my CE light is on again.
Suba-RAW is offline   Reply With Quote
Old 10-21-2001, 01:55 PM   #33
z0s0
Member#: 7146
2015 Forester XT
I don't really like downshifting into first gear and avoid it. On the other hand second gear seems too tall for those slower turns through intersections - lag out of the turn.
z0s0 is offline   Reply With Quote
Old 10-21-2001, 02:09 PM   #34
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Wink My cup is half full, not empty.
On the other hand, the majority of people state they can or can only with double clutching.
David
Bradus is offline   Reply With Quote
Old 10-22-2001, 02:35 AM   #35
jmullan
Member#: 230
2008 Impreza 2.5i
Generally, I wait till I am at a complete stop, but under the red mist in rallycrosses I have been known to jam it into first. It never grinds, but if I don't rev match it has been known to make loud banging noises at me as the engine and tranny mounts get jerked around.
To sum up:
I can shift into first at 15mph
I have folding rear seats in my Impreza LX coupe
I have a factory trunk light
I have a chance at second or third overall in the season championship if I do really well at the last rallycross.
That doesn't make the wear and tear any easier on the tranny.
jmullan is offline   Reply With Quote
Old 10-22-2001, 03:47 AM   #36
Flacco
Member#: 6673
2001 Impreza RX
Blue Black Mica
You could probally downshift into first when you are doing 60, if you didnt car for the concequences
Flacco is offline   Reply With Quote
Old 10-22-2001, 07:44 AM   #37
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Cough* REV match...
1st is a nearly useless gear... it's ratio is nearly 2k lower than 2nd... that means when down shifting from second at 2k, you need to be about 4k to get -smoothly- into gear. Yeah you can force it, or double clutch, but rev matching will work. I think most people were just questioning the reason to use first...
m750 is offline   Reply With Quote
Down Shifting from 2nd to 1st hoku123 Newbies & FAQs 51 04-15-2004 10:00 AM
Shift from 2nd to 1st on tight turn. How?? Rally Punx Motorsports 56 04-09-2003 11:09 AM
('93-'01) Test drove a WRX (again) - No problem downshifting from 2nd to 1st Cupholder Impreza Forum 4 10-21-2001 08:04 AM
Can you force the 4EAT to downshift to 1st gear? Tell me how, please! Jessie James Normally Aspirated Powertrain 43 03-18-2001 12:03 AM
