Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-06-2006, 09:34 PM   #1
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
Default Stage 2 - Is my boost ok?
I am reading 14.8 psi from my AP in third gear at full throttle. (Has been programmed for 1+ months.)
22 Degrees Celcius
50% humidity
Is this PSI good for the above conditions?
Thanks,
Matt
WrexT is offline   Reply With Quote
Old 07-06-2006, 09:41 PM   #2
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
How many miles on stage 2? I think target boost is 15.8psi, +/-.5psi. If you just flashed to stage 2, give it some more miles. I'm currently hitting 16-16.5psi.
ihavebettersound is offline   Reply With Quote
Old 07-06-2006, 09:44 PM   #3
hondaeater69
Member#: 60324
sounds a little low to me. isn't stage 2 16 + or - 5? I don't know for sure, but depending on what kind of gas and tune you're running, there could be more power to be had.
Old 07-06-2006, 09:45 PM   #4
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Just looked it up, it is 15.8. I think i was reading that low at first(14.8), which is actually the target boost for stage 1, and after ~100miles, I'm at 16ish.
Old 07-06-2006, 09:46 PM   #5
WrexT
Member#: 80169
2004 PSM WRX
Target is 15.8 +/- .5
I am using a 93 octane map on 94 octane gas.
I have probably 500kms on the tune.
Edit - Oh yeah, 3 inch downpipe, stock midpipe, 3 inch catback.
Old 07-06-2006, 09:51 PM   #6
hondaeater69
Member#: 60324
usuing 94 octane that's low. check your system for leaks etc, make sure everything is in proper order. If it is i would start with the waste gate (tighten it up). if that's greek to your search for WG arm adjustment in the 2.0l forum.
Old 07-08-2006, 03:12 PM   #7
mpggomd
Member#: 74167
2011 WRX Sedan WRB
TP Stage 2, w/cust tweaks
Def go with the wastegate arm adjustment...I always thought I had an UP leak because of slow spool and not target boost in 3rd gear. I tightened mine about 3.5 turns and WOW...what a difference...15.8 psi in 3rd by 3200 RPM...16.3 psi in 4th and 5th...
mpggomd is offline   Reply With Quote
Old 07-08-2006, 05:53 PM   #8
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
make sure you're looking at a high gear (4th) under load. It's hard to hit target boost at low load.
06rexwagon is offline   Reply With Quote
Going Cobb Stage 2 w/ stock uppipe ok? Erexxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 55 03-02-2006 04:11 PM
my stage 2 is running horrible! SketchINoc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-23-2005 06:21 PM
Will the UTEC Stage 2 comp chip be ok with these mods waitandbleed92 Engine Management & Tuning 6 03-18-2003 12:52 PM
Stage 2 closed loop boost map koloumb Engine Management & Tuning 8 01-04-2003 01:29 AM
TXS Stage 2/91 Unichip boost levels? MINO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-19-2002 01:34 PM
