Old 07-06-2006, 08:45 PM   #1
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
Default Best way to use Realtime maps?
I have Stage 2 basemap and I use a realtime anti-theft map.
What is the best way to revert back to stage 2?
Is it better to load a realtime Stage 2 map or disconnect the battery?
Thanks,
Matt
WrexT is offline   Reply With Quote
Old 07-06-2006, 08:50 PM   #2
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Disconnecting the battery would def. work, but then you would have to keep resetting your clock and radio!
ihavebettersound is offline   Reply With Quote
Old 07-06-2006, 10:41 PM   #3
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Reload the realtime stage 2 map, you will not lose your learning that way. And the clock/radio issue would be very annoying. Realtime maps are designed to work just this way, swap as you need different maps, on the fly.
jebjkey is offline   Reply With Quote
Old 07-06-2006, 10:42 PM   #4
WrexT
Member#: 80169
2004 PSM WRX
cool, thanks!!
The best way to map? uk300bake Open Source Reflashes 2 10-19-2009 06:16 AM
360 Gurus: Best way to use one Live account on two 360s? Nick Off-Topic 7 12-13-2007 11:18 AM
Best way to check fuel trims w/UTEC on custom map.... Project Rex STi Engine Management & Tuning 4 07-12-2005 08:01 PM
Any way to edit Accessport maps using hex editor? zuczek Engine Management & Tuning 7 10-06-2004 12:33 PM
What's the best way to use an airline credit voucher? banman Off-Topic 1 05-14-2004 11:24 PM
