Old 10-19-2001, 01:38 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Default Behold! The mighty closed deck!
Call it siamese, or closed it's all the same. Got the head off the block. Just some info for the newbies
WRXwannbe is offline   Reply With Quote
Old 10-19-2001, 02:12 AM   #2
kaos200
Member#: 2692
exactly what motor is that?
kaos200 is offline   Reply With Quote
Old 10-19-2001, 02:16 AM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
I think that's the EJ20 he was mentioning a week ago. OMG!
supermarkus is offline   Reply With Quote
Old 10-19-2001, 02:18 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
wow! look how much space is between those pistons!
Eric
Eric SS is offline   Reply With Quote
Old 10-19-2001, 02:22 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
yep it's an EJ20 first gen of first gen.
I took a couple pics of the oil squirters that shoot oil under the piston for additional lubricating. But they didn't come out good at all.
I'm wondering if I can bore and stroke it out to 2.3L
Old 10-19-2001, 02:23 AM   #6
8Complex
Member#: 922
04 FXT
Red
Heh, must be an EJ20.
Old 10-19-2001, 02:25 AM   #7
kaos200
Member#: 2692
Eric
lol
Old 10-19-2001, 02:26 AM   #8
kaos200
Member#: 2692
can the oil squirters be removed and placed on a 2.5 like they can on a 300z motor? (i think it was from the 93s and 94s on but whatever)
Old 10-19-2001, 02:41 AM   #9
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
I think you would need to plumb the oil squirters right through the block, which is actually pretty hard. So I guess it would be no.
Hehe, one of the reasons I got the engine.
closed deck and those snazy oil squirters.
Old 10-19-2001, 02:44 AM   #10
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
The answer is yes. The required oil channels are in fact in the same place in the EJ25 as the EJ20, requiring only drilling/tapping to install them. I know Cobb has done this on EJ25 blocks.
Ben
bsquare is offline   Reply With Quote
Old 10-19-2001, 08:55 AM   #11
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
I don't think the oil squirters are for additional lubrication, they are primarily to keep the pistons cooler, which can reduce detonation...
subarumantoo is offline   Reply With Quote
Old 10-19-2001, 05:58 PM   #12
Gerry
Member#: 1829
The 2.0 blocks can be boared out safely to 2.4L. I talked to Tony Rigoli a while back and that what he has. He has a custom forged crank, rods and cosworth Pistons...Gerry
Gerry is offline   Reply With Quote
Old 10-20-2001, 07:37 AM   #13
5252
Guest
Member#:
My 2.5 cents worth. The Just as mighty 2.5L block with closed deck.
Sold sense of nature Engine/Power/Exhaust 12 06-09-2010 12:31 PM
Open Deck vs. Closed Deck...Whats the diff? braap295 Pre-2002 Factory Turbo Powertrain 4 07-14-2009 10:28 PM
Open deck/ semi-closed deck/ closed deck in the STi? scoobybrande News & Rumors 11 10-23-2008 11:32 AM
open deck, semi-closed deck, closed deck jdiddy Newbies & FAQs 9 02-25-2006 12:25 PM
What is the difference between closed deck, open deck, semi-closed deck? disc108 Factory 2.0L Turbo Powertrain 2 01-07-2002 08:23 AM
Message Board Statistics All times are GMT -4. The time now is 06:12 AM.
