Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-07-2006, 07:04 AM   #1
bugeyes
Member#: 64494
2001 V7 sti
Question Dyno tune without egt sensor ?
Is it possible to accurately tune a standalone without an EGT sensor?
Ignition MBT can be found by increasing timing and referencing between dyno results till the extra advance isn't producing any more power. At some point the EGT's will become a factor also, especially at higher boost levels. How can this final point be found without an EGT sensor?
Can someone clarify this to me, or have I got it wrong.
If I must I can fit an EGT before my dyno day.
bugeyes is offline   Reply With Quote
Old 07-07-2006, 10:03 PM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Increasing timing reduces EGT's so unless your trying to reduce timing to produce faster turbo spool at like 1-5-10lbs of boost I don't think it's absolutley nessisary.
Sko is offline   Reply With Quote
Wanted: MAF mass air sensor. 02 sensors. EGT sensor timing cover. tscott915 Private 'Wanted' Classifieds 10 10-07-2009 02:26 AM
Pro Tune without a dyno? MTL_SLVR_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-30-2008 01:58 PM
turbo upgrade without a dyno tune? hirevn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-18-2005 03:37 PM
question about bad egt sensor, the egt fix etc Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-12-2004 03:43 PM
Tune, Dyno, Tune, Dyno..... 2MANYCARS Tri-State Area Forum 11 03-07-2003 10:24 PM
