Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-07-2006, 01:19 PM   #1
WoohooRX
Member#: 70296
04 WRX
rally blue
Unhappy How much do you think this should cost to fix?
This is why I hate parking in NYC.
2 questions:
1. How much do you think this should cost? (I got an estimate, but I'm curious as to what you guys think)
2. Can I pop it out myself by taking off the bumper?
(I know I won't be able to smooth it out as well as a body shop, or paint it, but I think I'll be able to pop it out.)
As you can see, the actual dent is pretty small, but it lays right on the crease. I don't know if that makes things easier or harder. If I could pop it out, I wouldn't mind leaving it unpainted because the area I work in/go to school in is pretty bad.
WoohooRX is offline   Reply With Quote
Old 07-07-2006, 01:26 PM   #2
abosworth
Member#: 53856
2012 Speed3
Red Mica
inconsiderate A@#holes. That sucks man. Yeh, i bet if you take the bumper cover off you will be able to pop it right out. Then it won't look nearly as bad, you will just have some scuffed paint. It's worth a shot anyway.
abosworth is offline   Reply With Quote
Old 07-07-2006, 01:26 PM   #3
Dforce
Member#: 93435
2008 STi DGM
+1 Berk Technology!
i'd try popping it out.
Dforce is offline   Reply With Quote
Old 07-07-2006, 04:45 PM   #4
NoCalSubie
Member#: 94301
Yeah, try removing the bumper and then pop it out.
NoCalSubie is offline   Reply With Quote
Old 07-07-2006, 06:45 PM   #5
kyleblix
Member#: 73495
Audi Q5, Ford Raptor
You probably won't have much luck just popping it out, but feel free to try. If you can get your hands on a heat gun try that and it may pop itself out. if you take it to a body shop, make sure they repair it. They may try to replace it, but don't let them, thats an easy fix
kyleblix is offline   Reply With Quote
Old 07-07-2006, 06:56 PM   #6
WoohooRX
Member#: 70296
04 WRX
rally blue
How much does a heat gun cost?
Old 07-07-2006, 07:12 PM   #7
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
IIRC they're pretty cheap at like home deopt and the like.
http://www.homedepot.com/prel80/HDUS...gll.0&MID=9876
Black-Falcon is offline   Reply With Quote
Old 07-08-2006, 01:41 AM   #8
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
The heat gun costs $0. If you have no use for the heat gun other than this go to Home Depot buy a heat gun, fix the bumper and then return the heat gun; Home Depot takes back anything.
Old 07-08-2006, 02:02 AM   #9
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
city drivers are the worst. boston too. some people have no respect for other people's property. makes me so mad. if the dent pops though, a scuffed bumper isn't the worst thing, and later on down the road when the bumper skin is really nicked up and scratched you can replace it with a brand new one for around $400.
doylfish is offline   Reply With Quote
Old 07-08-2006, 02:40 AM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
agreed heat gun and paint has a good chance
Old 07-08-2006, 04:41 AM   #11
silver-RS
Member#: 94447
2005 2.5RS
i would say the bumper itself is about $180, paint is gonna be $100ish
one hour of so of labor
$400-500 if you get it done by a shop
but definately worth a try to try to pop it out first
to see if u can save some $
silver-RS is offline   Reply With Quote
Old 07-08-2006, 03:03 PM   #12
FromEvoToRS37
Member#: 91396
dude fuk takin the bumper off, jus bend back the fender lining and reach in there and push it out, but actually I've seen many wrx and sti bumpers used around, try ebay or here you can find a great quality used one for cheap
FromEvoToRS37 is offline   Reply With Quote
Old 07-08-2006, 03:13 PM   #13
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
Hey, i work in a bodyshop. its easily repairable hoever it would require a bit of flexible finishing putty to be perfect.
take off the bumper, use a heat gun or even near boiling water to heat up and soften the plastic. then just push it out - and hold it where you want it, then pour some cold water on it to cool it down and stiffen it up again. try not to hold the heat gun too close because it may overheat the paint and plastic and liquify the plastic underneath causing the paint to wrinkle badly.
a bodyshop would charge 3-4 hours of labour for that repair. plus remove and install time (R+I) probably about 1 hour R+I time so maybe 5 hours tops.... for everything. paint time is usually ontop of that sooo maybe 1.5-2hrs paint time. not sure what labour rates are like in NYC.
good luck!
Loomin is offline   Reply With Quote
how much do you think this should cost??? wht07sti Southern California Impreza Club Forum -- SCIC 6 10-10-2009 11:21 PM
How much do you think it would cost to make custom single port headers? Malasubidude Newbies & FAQs 1 08-29-2008 01:27 PM
How much do you think it will cost WRBWRXVII Southern California Impreza Club Forum -- SCIC 12 11-19-2004 02:34 AM
('93-'01) How much do you think this costs? MadMax Impreza Forum 10 04-27-2001 12:57 AM
How much do you think I should sell them for? ashtaron14 Vancouver Impreza Club Forum -- VIC 15 04-18-2001 01:30 AM
