Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-07-2006, 02:07 PM   #1
kastkc
Member#: 51141
2013 WRX
PBP
Default Time to change my Timing Belt
I searched and couldnt find all the info I needed. I need to change my timing belt, does anyone have install instructions with torque specs etc....?
Also while I am in there, should I change out anything else (ie tensioner or anything)?
Thanks
kastkc is offline   Reply With Quote
Old 07-07-2006, 05:09 PM   #2
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Depending on what vehicle you have you will need the service manual. Haynes has a manual for '96 and older Legacy and Impreza's for anything newer check out North Ursalias site for a service manual CD.
Many people replace the waterpump, but that depends on mileage, which you didnt include in your post.
I use a small C-clamp or two to keep the belt on the cam sprocket as they have a tendency to kick over and throw the tooth count off.
I also take out the radiator so you will need new coolant for a refill. Make sure the block isnt airlocked when you refill or it will over heat.
I bought a strap wrench that works well for holding the crank pulley and use a breaker bar with a 18" cheater bar to break the crank bolt loose.
Can't think of anything else right now. Good luck, it takes me about 3 hours to do if I have everything ready to go.
Rally_wgn is offline   Reply With Quote
Old 07-07-2006, 05:23 PM   #3
EJ1
Member#: 61296
Do timing belt, water pump, water pump gasket, thermostat, thermostat gasket, crank seal, cam seals, oil pump o-ring.
EJ1 is offline   Reply With Quote
Old 07-07-2006, 05:33 PM   #4
kastkc
Member#: 51141
2013 WRX
PBP
Is taking out the radiator necessary, or just easier?
Old 07-07-2006, 05:35 PM   #5
EJ1
Member#: 61296
Just take out the fans. 4 bolts and 2 connectors. You will need a special tool to hold the crank pulley while you break the bolt loose. Also, make some guides for the water pump. The bolts are very hard to line up w/o guides.
Old 07-07-2006, 05:44 PM   #6
Rally_wgn
Member#: 62629
1996 OBS in Green
Easier but not neccesary, I also second the thermostat they can get stuck after removal a new one is better.
I use a Klein Tools Grip-it Strap wrench on the crank pulley and it works fine. you can also use a 18" piece of angle iron with holes in it from Home Depot and 2 10mm x 70mm Grade 8 bolts to hold it but its a lot harder than the strap wrench.
Old 07-07-2006, 05:48 PM   #7
kastkc
Member#: 51141
2013 WRX
PBP
Thank you. If anyone has the install sheets let me know.
Old 07-07-2006, 06:16 PM   #8
EJ1
Member#: 61296
Post your email address and I'll email them.
Old 07-07-2006, 06:19 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
um, pulling the radiator is 2 bolts and 2 connectors. You have to drain it anyways to do this job, so leaving it in there saves nothing. And taking it out gives one 4-6 more inches of clearance on everything...
The biggest trick with this job is properly compressing the tensioner properly without blowing it...
Old 07-07-2006, 06:25 PM   #10
Rally_wgn
Member#: 62629
1996 OBS in Green
Hey Matt, have you used a Big C-clamp for the compression? I have used it with good success as it compresses slowly versus my arbor press.
Also I use a small allen wrench to pin the piston down before removal if possible, makes this step a lot easier.
Old 07-08-2006, 08:25 AM   #11
Hayes
Member#: 11808
I pulled the radiator & fans as a unit=much easer than seperately. If doing a DOHC you must be able to lock the camshafts from turning or you can/will nick valves. I changed the TB, new water pump and inspected everything else. I used a drill press and reset the tensioner VERY SLOWLY without any problem. Do NOT reset the tensioner in the horizontal position. Go to www.endwrench.com for step by step with pictures.
Hayes is offline   Reply With Quote
Old 07-08-2006, 11:32 AM   #12
Charge
Member#: 3313
http://www.scoobymods.com/forums/showthread.php?t=3837
Direct link with pictures. You'll only see them if you've got an account there.
Charge is offline   Reply With Quote
Old 07-08-2006, 03:15 PM   #13
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
While you are in there... also change the radiator hoses and all of the accessory belts... I would also (as I did) take the radiator to a radiator shop and have them tank clean it... they pull the endtanks off, clean all of the passages and then reseal the radiator...
Texas25RS is offline   Reply With Quote
Old 07-08-2006, 03:39 PM   #14
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
^^^ now that is the best idea I have heard of yet . I will have to consider doing that soon .
imprezzakc is offline   Reply With Quote
Old 07-09-2006, 12:43 PM   #15
Charge
Member#: 3313
How much to have them clean, pull it off and reseal? Cause that's downtime. I imagine, if you can find a place to do that locally, it'd take them a day to do it? Many can't go extended periods of time without their car...as that begins to cost them money too.
A replacement radiator for an RS series seems to run about $150. I'm guessing you could possibly find it for less. Just something to consider, rather than spending a chunk of change getting that work done and having to deal with the time of the car being down(and needing alternate transportation to get the radiator to the shop, too).
Old 07-10-2006, 10:25 AM   #16
kastkc
Member#: 51141
2013 WRX
PBP
You have a pm EJ1, and thanks for the help everyone.
Old 07-10-2006, 12:44 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
That's exactly how I do it, though have taken to using a jeweler's screwdriver to lock it after bending a couple of allen keys...
Old 07-10-2006, 12:48 PM   #18
SOLUTION
Member#: 43602
2005 Outback Sport
Ahhh, that's a good idea. I ended up cutting a thick coat hanger and using that yesterday when I put my belt back on. It was a PITA to pull it out though.
SOLUTION is offline   Reply With Quote
Old 07-10-2006, 10:53 PM   #19
EJ1
Member#: 61296
You've got mail!
Old 07-11-2006, 09:12 AM   #20
Siper2
Member#: 1134
2007 BMW 328xi wagon
Might be smart to swap the tensioner, too. I did the opposite, abut 60K miles ago... My tensioner blew, had them change the belt at the same time.
=S2=
Siper2 is offline   Reply With Quote
Old 07-11-2006, 10:24 AM   #21
kastkc
Member#: 51141
2013 WRX
PBP
How much does the tensioner run?
Old 07-11-2006, 12:24 PM   #22
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I didn't want to start a new thread, but how important are the number of teeth between pulleys? I have the 2.2 SOHC, and the timing belt I purchased had each marking +1 tooth. There was no way to get the tensioner in using the correct (-1 tooth) spacing. Also, There was no way to get the passenger side belt in place with the idler pulley and still retain the correct markings. When I moved to the markings on the belt, everything fit like a glove and the markings were perfectly lined up. Thinking back to mathematics, as long as the pulleys are directly connected, for every one rotation of the crank, it should still rotate the cams the same amount, no matter the tolerance of length, but the length tolerance could affect tension. Is this correct?
BTW, the car pulled nice and strong using this timing. When I put the belt on before, I was off by about a tooth on the cam pulleys.
Plays_With_toys is offline   Reply With Quote
Old 07-11-2006, 12:58 PM   #23
EJ1
Member#: 61296
It's going to depend on the car. What do you have? I work parts at Subaru (where I'm at right now). One for a 00RS runs for $143.65.
Old 07-11-2006, 01:11 PM   #24
JTJ 2.5
Member#: 81572
1968 Subaru 360
2000 RS-H6 Race Car
kastkc,
where is the south burbs are you? Ive done this a few times and would be more than willing to offer a hand if you want.
jeff
JTJ 2.5 is offline   Reply With Quote
Old 07-11-2006, 01:11 PM   #25
kastkc
Member#: 51141
2013 WRX
PBP
02 2.5rs
SFL - Change my timing belt please LionJ5 South East Region Forum 0 10-18-2008 03:55 PM
I need to change my timing belt, MY99 Aaron'z 2.5RS Normally Aspirated Powertrain 6 06-04-2005 10:44 AM
What do I need to change my Timing belt on my 1996 Legacy Outback? osirus23 Service & Maintenance 1 06-29-2004 09:31 PM
Who can change my timing belt tensioner? STEALTH-WRX Southern California Impreza Club Forum -- SCIC 1 12-20-2003 04:38 PM
So I plan on changing my timing belt soon, lag Legacy Forum 7 10-11-2003 02:45 PM
