Old 07-08-2006, 02:31 AM   #1
bani111
Member#: 117850
2011 STI
Question 2.5i throttle lag?
I test drove a manual transmission 2.5i and floored it and it took about a second before the engine responded. There's no turbo so it can't be turbo lag. The dealer tried to blame it on "not being in the power band". Is it due to the drive by wire throttle? And is there any way around it?
I expected lag with the WRX and STI, but lag on the 2.5i was suprising.
bani111 is offline   Reply With Quote
Old 07-08-2006, 04:24 AM   #2
NA impreza~J
Member#: 85495
2005 2.5RS
CGM
what gear and what rpm were you at? I notice slight lag in my RS but at low revs. Higher up top seems to respond quicker.
NA impreza~J is offline   Reply With Quote
Old 07-08-2006, 09:18 AM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Lag or just the engine bogging down? Engine RPM is a beneficial piece of information at this point. If you're cruising at 2500 RPM and floor it, the engine isn't going to rocket up through the RPM band in a split second.
Only other thing I can think of is open loop/closed loop transition for the ECU. Otherwise, I'm at a lose for ideas as to why this occured.
AJ711 is offline   Reply With Quote
Old 07-08-2006, 04:35 PM   #4
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
I know a few people who've had problems with the Drive By Wire system not being in full working order and one of their complaints were that the throttle wasn't responsive, but this was coming from cars with atleast 20k miles.
I think that is just the way the RS is, but I notice that the throttle response is decreased sometimes when the A/C is on. Other than that my car responds right when i touch the pedal.
Caplin 2.5 is offline   Reply With Quote
Old 07-08-2006, 06:59 PM   #5
bani111
Member#: 117850
2011 STI
lag. the engine doesn't even RESPOND AT ALL for about a second. I floor it and the engine just doesnt do a damn thing for a second, then it suddenly responds and tears my head off.
happened regardless of rpm, in any gear i tried.
Old 07-08-2006, 07:09 PM   #6
Caplin 2.5
Member#: 71203
2005 2.5rs
probably is a problem in the drive by wire system.
Old 07-08-2006, 07:34 PM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Strange. I'm leaning towards electrical at this point. Might be the DBW bit, but it is hard to say.
Sounds a lot like an automatic. Step on it, let it drop a gear, then go.
Old 07-08-2006, 08:01 PM   #8
3gp
Member#: 111970
04 forester
whitey
i think your throttle was trying to catch up with the rpms....
3gp is offline   Reply With Quote
Old 07-08-2006, 09:28 PM   #9
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
I own a 2.5i '06. First off, it is not an RS. I had an 05 RS too haha, different package options, interior, engine blah blah.
Anyways, the throttle response ordeal (drive by wire excuse) is not really noticeable except for a very in tune driver. I am not greatly in tune, so i don't notice it much, althought 2nd gear 3500 RPMS and punching it, it's hard not to notice the split second hesitation, and I mean split second.
If you were below 3k, that is normal, even for my 6k mile car, it does this. It's just that the engine doesn't respond well to WOT under 3k RPMS. The RS did not exude this as much. I am going to chalk this up to different cams/engine setup.
I have also noticed, a problem with acceleration during cornering before 3500 RPM and it is extremely noticeable, a very large BOGGING feeling. I did not have it that bad in the RS.
Just my info.
~Levi
ScubaruImpreza05 is offline   Reply With Quote
Old 07-08-2006, 10:50 PM   #10
Subyblue
Member#: 107561
2006 2.5i
Regal Blue Pearl
Cool
No hesitation or bogging with my 06.
Subyblue is offline   Reply With Quote
Old 07-09-2006, 03:33 AM   #11
bani111
Member#: 117850
2011 STI
It's definitely the drive by wire throttle. The 2006 Civic Si has exactly the same problem.
Old 07-09-2006, 04:28 AM   #12
Babolat06
Member#: 118833
06 Impreza 2.5i
69 Cougar 351
I have a similar situation. How do you fix the DBW throttle?
Babolat06 is offline   Reply With Quote
Old 07-09-2006, 12:36 PM   #13
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Yes its definately the drive by wire system and soft drivetrain bushings. I'm not really sure there is a simple fix. Maybe a lightweight flywheel?
Subydude81 is offline   Reply With Quote
Old 07-10-2006, 08:33 AM   #14
Bootleg
Member#: 76173
2006 WRX Limited
Steel Grey
intake, exhaust, pulleys, flywheel, motor and tranny mounts, port & polish inatke and exhaust parts, valve train work, all these things will help to decrease throttle lag and help the car to go when you tell it. drive by wire will always be slower than the mechanical throttle cable setup, that's just the way it is. drive by wire has it's pros and cons and there's really no way around the cons at this point.
Bootleg is offline   Reply With Quote
Old 07-10-2006, 10:04 AM   #15
SubaDuba420
Member#: 102793
2016 WRX
Ugly Sedan
I find the combination of this car & DBW does not respond well to a foot stomping WOT at any RPM, I've found much better response with more of a roll on application of the throttle. IMO it's a combination of the engine, DBW & the throttle control tables in the ECU. Other cars I've driven with DBW don't have the same issues, at least not to the same degree I feel in the suby.
I've read a few posts where they mentioned locating the electronic throttle control maps in the ECU, so if we're really lucky and the Cobb N/A Access port ever comes out perhaps it will be able to solve the problem.
SubaDuba420 is offline   Reply With Quote
Old 07-10-2006, 05:40 PM   #16
NA impreza~J
Member#: 85495
2005 2.5RS
CGM
I heard rumors of Cobb making an AP for N/A but they said that they won't even make an intake for the 2.5RS and 2.5i then why would they bother with the AP? I do hope they do come out with something, I would love to have some more engine mangment options for my car.
Are there anyways in improving the throttle response? Would things like the Grounding Mod help?
Old 07-11-2006, 01:18 AM   #17
Subydude81
Member#: 118266
6MT
The Grounding mod won't do anything
Old 07-11-2006, 08:19 AM   #18
Bootleg
Member#: 76173
2006 WRX Limited
Steel Grey
not true. it wont do a lot but it will do something. it will smooth the car out at idle, through the power band and get rid of most noise from the electrical system. i found it to be well worth the time and money to put a grounding kit together yourself. i wouldnt buy one, but DIY is worth it. like i said, it's not a lot but every little bit helps. but dont expect any more power, just a bit smoother car.
Old 08-02-2006, 11:22 AM   #19
moestock
Member#: 121398
2006 2.5i
SRR
I just bought a 2006 2.5i less than two weeks ago, and I was wondering why I couldnt drive this thing smoothly. Just this afternoon I did some extensive experimentation, and realize this throttle lag is the cause of my problems. If I just stab the gas real quick the rpms just burble up a little. ugg. Its really not the instant gratification I'm used to.
Anyone have any advice on how long this takes to get used too?
It really sucks pulling out on a steep hill, I end up reving the crap out of the engine and slipping the clutch like an idiot.
What are the "pros" to the Elec. throttle that someone mentioned above?
moestock is offline   Reply With Quote
Old 08-02-2006, 02:31 PM   #20
bani111
Member#: 117850
2011 STI
it's almost like the dbw/ecu is trying to spin up a non-existent turbo...
Old 08-02-2006, 03:09 PM   #21
Naito
Member#: 114263
2014 Forester XT
For the start lag, you might want to check out this TSB: http://www.scoobymods.com/forums/showthread.php?t=5833
I've never really noticed any lag except if I start the car from a stop at below 1500rpms. It's fine at 2k, which is still a little higher than I expected but then my old car didn't have a tach. Under 1500rpms tho and the car feels like it's just rolling, but it really might just not have any torque that low.
The only thing that's been bugging me about the DBW has been when doing heel-toe. It's also noticable when dbl-clutch downshifting to engine brake. Even if you match the rev perfectly, and have the clutch up all the way, there seems to be a second lurch that happens about a half second after the clutch is fully up. I say second because I feel the first lurch from a bad rev match sometimes, and then a second one after that. This is most noticable going from 4->3 or from 3->2. Feels like I've underrevved, but the clutch is already fully up, and the tach is not jumping. Only when your foot is off the gas after you shift is this noticable; if you get back on the gas after downshifting one gear, i.e. during passing, this doesn't happen.
I'm planning on taking it to the dealer to ask about this next time I go in, I've only had the car a month (well, 2days short of a month actually hehe) but I've spent most of the last 2300km trying to figure out why my downshifts won't stay smooth, and this is the ONLY thing that still bugs me. With the AC on, the lurch sometimes feels strong enough to be putting some really bad strain on the drivetrain.
Naito is offline   Reply With Quote
Old 08-02-2006, 09:39 PM   #22
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ya, I saw that, but I dont think it really helps anyone... There needs to be better software installed to help with this problem, but SOA hasnt come out with anything yet.
Ive been driving around some automatic 06's and the 06 auto forester is just horrible with the throttle lag its not even funny... However, the 2.5i legacy with the auto sportshift in sportshift mode is quite responsive, I actually enjoy it much much more than the 00 legacy GT auto I drive on occasion.
Old 08-03-2006, 10:53 AM   #23
M-e-X-x
Member#: 112089
2007 CDM, CGM GD6 SE
2006 CDM, SGM GG6
laaaaaaaagtacular in my 2.5i 4EAT, and it's not just because it's auto
M-e-X-x is offline   Reply With Quote
Old 08-03-2006, 01:10 PM   #24
moestock
Member#: 121398
2006 2.5i
SRR
For the start lag, you might want to check out this "link"
.. sorry not cool enough to post a url yet.
I just tried the method in this link today, their is still a lag. Its probably my imagination... but its seemed less severe after I stopped the car and started it again. I'll be doing this a few more times to try to "train" the ETC.
Like I said, I'm probably imagining the improvement, just getting used to the car maybe. But regardless, thanks for the placebo effect this had. At least I'm trying something to help!
Old 08-03-2006, 01:33 PM   #25
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What sucks is the Legacy 2.5i with the sportshift is much much better
2.5i throttle response Jay89 Impreza Forum 19 04-27-2009 08:46 PM
08 Impreza 2.5i 5-speed Throttle Hang Fix? rick92008 Newbies & FAQs 15 04-17-2008 12:34 PM
Throttle response for 2.5i Jerry Xu Normally Aspirated Powertrain 5 12-11-2007 03:46 PM
2.5i Engine Lag ! justinkarim Normally Aspirated Powertrain 27 02-08-2007 09:42 PM
06 2.5i Impreza Electronic Throttle 240c Newbies & FAQs 3 08-08-2006 08:38 PM
