Old 07-08-2006, 09:56 AM   #1
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Default Problems after cat install
When I did my swap to my RS I bought a custom fabbed 2.5" catless TBE. It was WAY too loud and wouldn't pass inspection.
It ran pretty good but wasn't very smooth and sounded unhealthy.
I bought a 2.5" cat and put it in the 3rd cat location, unplugged the battery pressed the break to get all the electricity out and it ran pretty good for about 30 mins. Power seemed smoother and exhaust sounded more 'normal'. Now sometimes when it gets to about 3500-4000rpm it bogs down really bad and wont go past that RPM very easy. It seems fine if I start from first and go through all the RPMs, but if I start to hit those RPMs from another gear it hesitates to go past, seems to be not boosting either. I searched around but couldn't find anyone with these issues after INSTALLING cats, always after removing them.
I don't have a boost gauge so I don't know what boost it is hitting/not hitting.
Do I need more time for the ECU to learn the new exhaust setup, or do I have a serious problem?
Parsons is online now   Reply With Quote
Old 07-08-2006, 11:19 AM   #2
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Just went to autozone to get my CEL code pulled.
P0328, knock sensor. Read up about it, people reported the same "hesitation".
I know what most people say is replace knock sensor, but how often do those things go bad? My engine has <6000 miles on it, and if I am replacing one already, I think i'll be going through ALOT of them.
Old 07-08-2006, 11:49 AM   #3
Hallis
Member#: 94141
Platinum Silver Metallic
Reset the ECU again, and drive it real easy, try not to boost it for a day or 2. See if that fixes it. I would say to the Vishu relearn but that would require a boost gauge which you dont have.
Shane
Hallis is offline   Reply With Quote
Old 07-08-2006, 12:00 PM   #4
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Gauges are in the future, but this swap has broke the bank so far.
Would have been 10x easier had I not started with a totaled car.
I'll give that a try, thanks.
alignment problems after spring install johnei Brakes, Steering & Suspension 6 09-20-2004 07:12 AM
Hesitation Problems after Downpipe Install Hayaboosted Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-28-2004 09:20 AM
Problem after stereo install... please help WRXVII Electrical & Lighting 1 11-20-2003 02:33 PM
Help car making noise! Problem after uppipe install jbogli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-20-2003 10:25 AM
problem after alarm installed Evil Imports Electrical & Lighting 1 04-15-2003 09:56 AM
