Old 07-08-2006, 02:42 PM   #1
Burnt_Toast
Member#: 97634
96 impreza L
fugly
Default Rear end noise
1996 Subaru impreza L:
I've replaced both wheel bearings.
The brakes are all brand new.
The noise starts around 15mph, gradually getting louder as speed increases. Does not go away if taken out of gear or clutch pushed in.
Tires are ok, not new, but even after rotating, the sound is still there.
It sounds just like a wheel bearing or bad brakes... obviously not them, as they have both been fixed.
Maybe rear differential?
Any suggestions?
Burnt_Toast is offline   Reply With Quote
Old 07-08-2006, 07:23 PM   #2
Burnt_Toast
Member#: 97634
96 impreza L
fugly
Also, there is no vibration caused by the sound. I forgot to mention that.
anyone?
Old 07-09-2006, 10:53 AM   #3
klapdout
Member#: 119664
its your rear end, whens the last time you changed the fluid? try changeing it, if that doesent help it will need to be rebuilt
klapdout is offline   Reply With Quote
Old 07-09-2006, 11:10 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
does the noise continue when you lift off throttle?
Jamie
Old 07-09-2006, 11:18 AM   #5
Burnt_Toast
Member#: 97634
96 impreza L
fugly
Klapdout, I will try changing the fluid. I hope that works, i don't want to rebuild the rear end...
Jamie, Yes, the noise is based on speed, not gearing or throttle.
I'll change the fluid and see what happens.
Thanks.
Old 07-09-2006, 11:29 AM   #6
chip4761
Member#: 55867
2005 Saabaru
AS
How often do the rear axles go bad? I don't know if you have to do this on scoobs, but on older cars, you had to balance the drive shaft sometimes. Just a thought.
chip4761 is offline   Reply With Quote
Old 07-09-2006, 06:50 PM   #7
Burnt_Toast
Member#: 97634
96 impreza L
fugly
Changed the fluid, noise is still the same. not sure where to go from here.
Old 07-09-2006, 07:08 PM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Dude, seriously... wheel bearings, brakes, diff... all not naturally aspirated. I don't want to seem like a jerk, but there are reasons these forum divisions exist.
LetItSnow is offline   Reply With Quote
Old 07-09-2006, 08:17 PM   #9
Burnt_Toast
Member#: 97634
96 impreza L
fugly
Dude, seriously...pushahh... you do seem like a jerk, and a very bored, uninformative jerk at that. My car is N/A. If the mods want to move it, they can. You are not a mod. Go away and try being supportive or productive... or maybe even both.
Rear End Noise BILLY K Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-05-2007 09:39 PM
rear end noise ryzies Transmission (AT/MT) & Driveline 1 01-25-2007 09:15 AM
97 Legacy Outback w/ AT rear end noise in reverse ChayesFSS Outback Forum 6 11-20-2005 08:54 AM
91 subaru awd help rear end noise coryc916 Newbies & FAQs 0 04-11-2005 01:20 AM
Rear End Noise??? sen New England Impreza Club Forum -- NESIC 3 04-17-2003 10:57 PM
