Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-09-2006, 01:49 PM   #1
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Default Utec w/ meth setup question?
did some searching but did not find any setup answers. i am currently "stage 2" w/ my utec setup on stock turbo running 17 lbs boost. i have the smc meth kit on the way. my plan is to make another map for the utec, of course protuned, and be able to switch maps on the fly and turn on the meth for the appropriate map. my main question is do i need anything else for this setup? do i need an electronic boost controller so i will also be able to run more boost w/ my meth map. thanks for your help guys.
krambte79 is online now   Reply With Quote
Old 07-09-2006, 05:01 PM   #2
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
bump for any input
Old 07-09-2006, 05:54 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
no...
Old 07-09-2006, 06:03 PM   #4
Rampage180
Member#: 70040
Maybe a GM boost solenoid, Prodrive, or Perrin... All pretty much the same thing.
Rampage180 is offline   Reply With Quote
Old 07-09-2006, 06:05 PM   #5
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
can you elaborate please, i know the utec has the manual boost controller so how does it alter boost when changing maps, i run 17lbs on my stage 2 map and hope to run 20+ lbs w/ the meth map.
Old 07-09-2006, 07:15 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
You shouldn't need anything else. If you have problems reaching the boost you want(after adjusting the abc and boost map correctly), you might wanna look into a helper spring. You should be able to hit the boost you want on different maps just by switching maps though if you set everything up right. If you use some kind of other boost control, you will have to switch that when you change maps. There are advantages to utecs boost control and advantages to other forms of boost control. I would personally save my money if I was you, course I'm cheap.
peace
Old 07-09-2006, 09:17 PM   #7
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
thanks
Old 07-09-2006, 11:37 PM   #8
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
9.0@170mph GTR
You have all you need..
Junior2JZ is offline   Reply With Quote
Old 07-10-2006, 10:11 AM   #9
AaronWRX
Member#: 7194
2011 997.2 Turbo
I wish more utec users would try single stage (utec solenoid) or even dual stage (utec solenoid + pressure switch) WI setup before just running out and buying progressive setups.
They are cheaper, less complex, and I bet just as effective.
AaronWRX is offline   Reply With Quote
Old 07-10-2006, 10:40 AM   #10
Freon
Member#: 88322
2009 BMW 135i
Well, STI owners don't have the 3D solenoid map control yet, but WRX owners do.
Just using the spare solenoid to turn on the WI above, say, a certain pressure is very crude.
Freon is offline   Reply With Quote
Old 07-10-2006, 10:53 AM   #11
AaronWRX
Member#: 7194
2011 997.2 Turbo
Online it may sound crude but in practice I don't believe it is.
In fact i'd bet that if you put up a 3d setup against a 2 stage setup there wouldnt be any mesuasualbe differece in performance.
I think we are a little too quick to over-engineer WI. It's a pump that mists liquid.
Old 07-10-2006, 11:05 AM   #12
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Does that include throttle applications of less than WOT?
BadTrip is offline   Reply With Quote
Old 07-10-2006, 04:09 PM   #13
hippy
Member#: 36528
2002 Impreza Wrx
If you control it with the utec spare solenoid, you can have the first stage(pump) turn on at a given boost(with a pressure switch), and the second stage(solenoid) turn on at a given rpm/boost. Imo this can be very very effective, inexpensive, and easy if done correctly(theoretically ).
peace
Post your water/alky/meth setup! dub c Water/Methanol Injection, Nitrous & Intercooler Cooling 5 03-27-2008 01:29 AM
Advice for my new turbo setup before protune and alky/meth setup 04subyrex Factory 2.0L Turbo Powertrain 20 11-16-2007 12:38 PM
CAI with a turbo swap & Alky/Meth setup worth it?? 04subyrex Factory 2.0L Turbo Powertrain 1 11-11-2007 10:30 AM
Finally got my meth setup dynod - stock turbo 320whp/376wtq wrxtremeWGN Proven Power Bragging 18 09-15-2006 10:18 PM
meth setups on my 05 sti blazin sti Water/Methanol Injection, Nitrous & Intercooler Cooling 8 06-26-2006 10:52 PM
