Notices
Old 07-09-2006, 10:01 PM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Boost leak test??Can't get the system to pressurize?
So, i have a leak somewhere and cant find it for the life of me. I borrowed my brothers pressure tester, hooked it up to the inlet hoses, plugged the 3 ventilation ports on the top and i couldnt get the system to pressurize? My boost gauge didnt even move. I gave up and decided to come to the forums. Thanks in advance!
ScoobySnacker is offline   Reply With Quote
Old 07-09-2006, 10:07 PM   #2
KmanRuffian
Member#: 48360
2011 WRX 5-door
Do you have a stock inlet hose? if so there are 4 ventilation ports...
-D
KmanRuffian is offline   Reply With Quote
Old 07-09-2006, 10:07 PM   #3
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
Did you use an air tank of some sort or did you just try plugging an air compressor right into the intake tract? If you just tried using a compressor, it'll take forever to pressurize it, (especially if you have a leak somewhere! )
You need to fill an air tank up to 15-20 psi max and then tie that into your intake tract to listen for leaks. I found a small compressor with a tank attached in Wal mart that worked well.
Paulie V is offline   Reply With Quote
Old 07-09-2006, 10:07 PM   #4
scooby888
Member#: 64226
2004 Impreza WRX
World Rally Blue
I have tried a smoke machine and Home Depot type test and can't find my boost leak either. Although I didn't try anything involving those 3 ventilation ports...
scooby888 is offline   Reply With Quote
Old 07-09-2006, 10:13 PM   #5
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
It takes a while for the system to pressurize. I was suprized how much air I had to put in to see anything. You need to put in a lot more volume then you might think.
Sausage is offline   Reply With Quote
Old 07-09-2006, 10:26 PM   #6
ScoobySnacker
Member#: 105303
2003 WRX
I have a stock inlet hose and could only find 3 ports on the top? I used a 60 gallon air tank. Put the home made boost leak tester on the inlet and tried to pressurize it. Nothing at all. I could hear nothing and the boost gauge did not move. Do all four ports need to be plugged? Thanks guys!
Old 07-10-2006, 09:55 AM   #7
ScoobySnacker
Member#: 105303
2003 WRX
Bump...I need some help
Old 07-10-2006, 10:52 PM   #8
ScoobySnacker
Member#: 105303
2003 WRX
Bump it up again..i plugged all four ports today and it did the same thing..im starting to get frustrated
Old 07-10-2006, 11:18 PM   #9
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
i havent been able to get mine to work either. I dont see why a compressor wouldnt work. Do you have to take the hoses off the inlet hose and plug them with a cap and then do it, or can i just leave the hoses on?
KAX is offline   Reply With Quote
Old 07-10-2006, 11:58 PM   #10
hotrod
Member#: 14141
2002 Impreza WRX
Did you listen at the exhaust pipe?
You could either have a bent valve that is bleeding boost out the exhaust or the engine is stopped in valve overlap and you losing pressure through a cylinder.
Try bumping the starter to rockthe engine over a part of a revolution and see if the intake will pressurize.
Larry
hotrod is offline   Reply With Quote
Old 07-11-2006, 08:16 AM   #11
ScoobySnacker
Member#: 105303
2003 WRX
Larry
You are starting to scare me, ALOT!...I dont see why i could have a bent valve with only 50K and just a reflash. Doesnt seem like that would be possible, but you never know. I will listen to the exhaust and let you know what happens. Is there any other way to confirm that i could have a bent valve, other than ripping the engine apart? Thanks for the help guys!
Old 07-11-2006, 08:38 AM   #12
ScoobySnacker
Member#: 105303
2003 WRX
To add to my last post..The car runs fine and i think that i would notice if there was a bent valve or something wrong internally. Bump for more help!
Old 07-11-2006, 08:46 AM   #13
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
electronic boost gauge? is your key on?
rjrutzky is offline   Reply With Quote
Old 07-11-2006, 09:21 AM   #14
hotrod
Member#: 14141
2002 Impreza WRX
Not trying to scare you and have no reason to believe you have a bent valve just stating the two most obvious reasons you might not be able to pressurized the intake tract. You have a very big leak the most likely is that not all the valves are completely closed and there are only 2 likely reasons for that to happen. The very benign case where by simple dumb luck the engine stopped with one cylinder at a point where both the intake and exhaust valves on that cylinder are off the valve seats. If that is the case all you need to do is rotate the engine a few degrees and the problem goes away.
If you are applying air to the system and it is leaking past the valves you will be able to hear and feel the escaping air out the exhaust pipe.
I mentioned a bent valve as it is a possibility although very slight.
By the way if the boost gauge is reading pressure off the intake manifold and the throttle is closed it will take a loooooong time for the pressure to build in the intake manifold enough to show on the boost gauge.
Larry
Old 07-11-2006, 10:05 AM   #15
ScoobySnacker
Member#: 105303
2003 WRX
I got what you are saying...I have tried it more than once, so i dont think if had the same dumb luck each time with the intake and exhaust valves of one cylinder is off the seat. I think that i may not holding the compressor on long enough for the system to pressurize. I know that when my brother and i did his SRT-4, we hooked the pressure tester up and almost instantly the boost gauge went up. What makes the Subaru so different? Thanks for all the help I will keep it updated. And i have a mechanical boost gauge, so that is not the problem.
Anyone in SD know how to do boost leak test? somaguchi Southern California Impreza Club Forum -- SCIC 2 01-25-2010 03:29 PM
HELP! System not pressurizing with boost leak testing elhalisf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-27-2009 09:40 PM
Can't get the CEL to reset mr.pessimist Baja Forum 10 07-07-2008 07:26 PM
Tell me how to do a boost leak test? PLEASE!! ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-15-2006 12:00 AM
Help can't get the HU to fit. parrej Car Audio, Video & Security 5 09-11-2002 06:44 PM
