Old 07-10-2006, 11:07 AM   #1
bpwatts
Member#: 111635
Default UTEC: If the cruise light is flashing....cruise control doesn't work?
So I've got a UTEC in my 04 STi. Its flashed the O2 slow read and some various MAF issue at me since I installed it. No big deal. However, it appears that the vehicle's ACTUAL cruise control doesn't work when the quasi CEL/cruise light flashes....
Is this correct behavior? Does the UTEC really disable/kill cruise control when the CEL/cruise is flashing?
edit: doh, sorry mods....please move to UTEC forum
bpwatts is offline   Reply With Quote
Old 07-10-2006, 12:08 PM   #2
TheMadScientist
Member#: 23717
2005 Big red
It is not the Utec.
It is the stock ECU programming that disables the CC and starts the light flashing. The Utec can not "disable" CEL code in the ECU, it only stops the CEL light from lighting.
TMS
TheMadScientist is offline   Reply With Quote
Old 07-10-2006, 12:54 PM   #3
Freon
Member#: 88322
2009 BMW 135i
Yeah, the UTEC's CEL defeat doesn't actually do anything. Just kills the one light in the dash. You still have the CEL, and it still may affect your car.
I don't recommend using this UTEC feature. Fix the problem rather than cover it up.
Freon is offline   Reply With Quote
Old 07-10-2006, 02:19 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what if your problem is being addicted to the flat foot shift?
p0301
p0302
p0303
p0304
Old 07-10-2006, 07:07 PM   #5
bpwatts
Member#: 111635
That'd be terrific if the CELs weren't bogus. Slow O2 read and some crap about the MAF sensor. Apparently there's some firmware bug that'll just randomly like up the CEL for STi's and the UTEC. It just pissed me off because I had a 90 minute drive and I had to keep a steady foot. I had forgot how tiring that was. I'll just figure out a work around so the CC always works. Thanks TMS and Freon.
I've never had any intention of turning off the CEL indicator using the UTEC. Not sure where that was brought up. The car didn't generate any CELs prior to the UTEC, so I can only assume the UTEC is buggy and generating the issue. Oh well...
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check Engine Light and Flashing Cruise Control Light moose00015 Newbies & FAQs 17 05-29-2011 09:16 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
CEL came on, and Cruise Control light is flashing 07Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-31-2007 12:12 PM
cruise control doesn't work above 90mph pimpwgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 09-13-2004 10:58 AM
