Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 07-10-2006, 02:29 PM   #1
Legacy
Member#: 10188
2007 Forester XT
Default How to check for broken timing belt ?
I have a '97 Legacy GT that cranks but won't start. It really does not sound much different than the usual starting sound in my opinion. The CEL codes were misfires + camshaft + crankshaft sensors. I replaced both sensors and still it won't start. Returns a camshaft CEL.
Local tech says it could be a broken belt and I should check it. The belt was replaced at 156k and the car has 220k. Tech says even so, something else could have seized and snapped the belt. Lovely. There's 3 bolts he says. Would I remove the 3 bolts from the driver's side cover ? And, does the cover just pop off ? Pics would rock.
How will I know if the belt is broken, should it be obvious even from one side ?
Legacy is offline   Reply With Quote
Old 07-10-2006, 03:38 PM   #2
83Rabbit
Member#: 5050
itll be obvious from one side, the belt will have no tension and look, well, broken
83Rabbit is offline   Reply With Quote
Old 07-10-2006, 07:29 PM   #3
#522
Member#: 2185
01 RS
swirly blue
The cover is easy to get to. there is a bolt on the top, and 2 on the bottom. my RS is lowered a little, but I as still able to get under there and loosen the bolts. wish I had a pic, but you should be able to figure it out when you look at it. I know because I just checked mine, I am having the same problem. Mine isn't broken, but it might have jumped a tooth. That I can't tell from looking in the cover.
#522 is offline   Reply With Quote
Old 07-10-2006, 08:45 PM   #4
Legacy
Member#: 10188
2007 Forester XT
I took it off this evening. I had to remove the coolant resevoir to get at the bolt on the bottom. It wasn't that tough when you get down and do it. The belt was slightly loose and from what I was told it should be snug. The car is now on a flatbed to see if something else snapped and what the damage is. Wish me luck !
What does it mean when the belt jumps a tooth ?
Old 07-10-2006, 10:20 PM   #5
chip4761
Member#: 55867
2005 Saabaru
AS
The belt jumps a tooth when it gets enough slack in it to stay in the same place on one pulley, but move over on another. Say the crank is at TDC, and so is one camshaft, but the other is x degrees off. It might be your tensioner.
chip4761 is offline   Reply With Quote
How to hold cam gears...timing belt replacement ratso Normally Aspirated Powertrain 13 12-20-2008 08:33 PM
How to check for available vanity plates? gregaruWRX Off-Topic 5 09-09-2005 06:25 PM
how to tell if a timing belt has skipped teeth BlackoutWRX Newbies & FAQs 4 07-19-2005 09:42 PM
How to fix a broken timing belt engine? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2003 11:30 AM
N00b question, how to check for good ground? TaiChih Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-15-2002 04:55 PM
