Old 10-19-2001, 04:27 PM   #1
db97
Member#: 7140
2009 WRX
satin white pearl
Angry factory gauge pod...OH SNAP!!!
damnnn, i had my gauge cluster (3 meter dash variety) and short shifter installed today...i got the car back this afternoon around 3. it little while ago (around dusk), i turned the lights on. to my dismay, the oil temperature meter 'switched off' (went back down to 0 degrees) when the lights were turned on???? i know the turbo boost gauge has a sucky ass backlight...which i can live with, but i'm pretty sure the oil temp meter ISN'T suppose to turn off like that when i turn the lights on???? ***!?
s*** is f'ed up...right??
i can't believe this s***!
db97
db97 is offline   Reply With Quote
Old 10-19-2001, 04:30 PM   #2
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
yes. it should show a vacuum during idle
elgorey is offline   Reply With Quote
Old 10-19-2001, 07:31 PM   #3
db97
Member#: 7140
2009 WRX
satin white pearl
Angry bEOTCH!
tell me this s*** ain't right!
Old 10-19-2001, 07:36 PM   #4
procrustes
Member#: 4444
Try dimming your dash lights all the way down - if the gauge goes dim but the gauge starts reading correctly then they hooked up the wrong ground to your gauge. Tell them to read the installation manual.
procrustes is offline   Reply With Quote
Factory gauge pod with aftermarket gauges jimbobrand Newbies & FAQs 1 09-24-2002 02:02 PM
Factory gauge pod on 02 WRX GM991 Factory 2.0L Turbo Powertrain 8 02-13-2002 10:42 AM
factory gauge pod fit 52mm gauges? Subaruist Factory 2.0L Turbo Powertrain 2 01-31-2002 10:56 PM
What size gauges fit in the factory gauge pod face plate? XBD General Community 3 11-08-2001 12:51 PM
Factory gauge pod I Love Turbo Hawaii Impreza Club Forum -- HIIC 3 10-08-2001 10:09 PM
Message Board Statistics All times are GMT -4. The time now is 03:37 PM.
